Question about The Office Equipment & Supplies
I sent a job to printer HD5000 in the process it display error 273 Reboot required and refuse to print, i also observed that the ribbone cartrage is stuck in it
SOURCE: Printer not receiving jobs
I have a Mac Book/Leopard & when I try to print to my HP 2410, it works for 2-3 weeks & then I can not get it to print.  I call Tech Support thru Apple & they reroute my Airport Extreme & change passwords, & reinstall " Mac Os X Install Disc 1" which sometimes means being on the telephone for a couple of hours only to have it last a week or two & we have to go thru the same thing again.  They tell me that my HP 2410 must be going into the "sleep mode" & the printer will not print.  I don't know if going in & "waking up" the printer each time I want to print would solve the problem or not.  Do you have any suggestions??    Thank you---Leon
Posted on Mar 23, 2008
SOURCE: Xerox Phaser 8550 Won't Print
I was having the same problem. Turns out the IP address in the printer was incorrect. Once I changed the IP address the printer works just fine through our network again. Find your IP address off your server and follow these steps:
1. Choose Info on display menu, press okay button
2. Choose Info pages, press okay
3. Configuration pages-printer info, press okay
4. IP address should read: Correct IP Address number should be displayed on screen.
If not follow these steps to change it:
1. Find printer setup on display menu, press okay
2. Go to connection setup-press okay
3. Network setup-press okay
4. TCP/IP setup-press okay
5. Auto should show as “Off”
6. TCP/IP should show as “On”
7. DHCP/Boot should show as “Off”
If any of these are not listed on display correctly press ok, reset to either On or Off and then enter correct IP address.
Press okay button and follow steps on display menu to exit back to main menu display screen.
Posted on Mar 26, 2009
  • 79 Answers
SOURCE: Printhead (R), Check Printhead - Canon IPF5000
first of all print a nozzlle check....then see all the color patterns.
The second you can do is to update the firmware to the latest version.
But i think that you have to replace the print head.
Posted on Apr 16, 2009
quannd
SOURCE: oki b6200 printer error
How did it get error? In the most case that error shows the time to replace another Fuser part.
The Fuser was ruined if you print over maximum number of pages (200,000 pages for eg.). If not the component of printer's Fuser is ruined, such as sensor, this is the most case that I have usually seen.
I think it's simple. But how to find it is a little difficult.
Posted on Jun 04, 2009
  • 313 Answers
SOURCE: My printer is stuck on processing job and will not
I need more details
Posted on Mar 17, 2010
Fargo hdp5000 error 273
ERROR 273 does not come up in the manual but I might have nailed it. This error is a generic error which applies to several issues but most likely if you've just recently fiddled with the printer it could be a motor or other cable not connected.
In my case I swapped out the laminator sensor and had forgotten to connect the cable back on the laminator motor. After I connected it all worked normally with no errors.
Surely hope this helps someone out.
May 27, 2015 | Fargo Office Equipment & Supplies
Hp 2840 won't stop printing
power off the printer. removed the network cable only. power on until it display ready. now print a config sheet or menu map. if it print without error then connect the network cable and print config sheet again. wait and observed. if it will start printing garbage then KILL the print jobs queued on the printer. after deleting all print jobs power off and power on printer with network cable connected. I hope that will fix the problem. by the way. was there any error display in the panel display like "49.4C02". etc.
Feb 21, 2013 | HP LaserJet 2840 All-In-One Printer
I get error message "Unable
Computer messages provide the presciption of the condition requiring attension. For example, the message unable to clean has an identification number also as reference to the the condition specified. An attempt to clean the printer would require preparotory measures described.
1. Examine the printer device qeenly to ascertain complementary requirements before further processes are achievable. For example, printer cleanup may require replacement parts, ink cartridges, ribbons, perhaps papers.
2. Acquire the printer cleaning kits. For example, cleaning solvent specificed for printer devices, cleaner clothes, and brushed tools for reaching into corners.
3. Acquiring the printer user guide as instructions provider to achieve the process. For example, prior to the cleaning activity, familiarise with the user guide of the printer. Take qeen attention to printer diagnostics found on the references catalog area because may have provided the means to acheiving the problem encounter as message.
How to clean up the printer with tools provided.
First, the printer require dismantling the removeable components. For example, the lose areas usually printer ink stations, paper feeders, printer out document holders would require removal before commencing printer ceanup.
Second, Take care in the process of removing part components. Meanwhile observe any broken parts that may require replacement on the compartmentalisation process.
Third, Cleaning the printer includes external areas, internal areas, and finally only components that require cleaning should be cleanedup. For example, the ink cartridege is delicate would leat require tempering with, especially should be stored at delicate area to prevent contact with moisture, or ink floating sepage.
What to expect duringg the clean up process
First, clean any noticeable particles, dusty, paper remnants etc.
Second, replace every component parts soon after the cleanup is complete
Third, printer accessories like printer paper, ink, ribbon soon after replacement would require reallignment. For example, powering on the printer, attaching to a computer, attempting to print a document should initiate the allignment procedures. A. The printer sends messages to the computer requiring test sheet printouts. For example, it is likely for the printer during this stage to produce malallighed printer out sheets. Also likely is several mesages requirng approval as users authority to reestablish printer. Every process taken until the first appropiate printer out is acheived is called an allignment process.
Jan 11, 2011 | Brother Office Equipment & Supplies
Error 79.00FE
In order to fix the 79.00FE printer error, first you have to print a configuration page. Then remove the jet direct and power on while holding the go button down on the printer. After display reads offline, the reset process is complete. After the cold reset, remove the jet direct card and see if the 79.00FE error goes away. If the 79.00FE error appears before a job is sent then it may be the DIMMS, try removing them to see if the error persists.
Dec 08, 2010 | HP LaserJet 5100dtn Printer
Card keeps jamming and ribbon breaks
Download the Fargo Diagnose Utility .
But Requires Windows 98, 2000, NT, XP, Me; 16MB of RAM (Recommended); SVGA Monitor (800x600 or higher is required); and at least one printer drivers installed.
If a card becomes jammed inside the printer, the LCD Display will indicate
approximately where it is jammed. At this point you can either try to correct the
problem and continue printing with the same card, or remove the card completely
and continue printing with a new card. Refer to the following steps for instructions
on doing either:
1. Leave the power ON, and open of the printer?s Top Covers.
2. Remove the ribbon and overlaminate as needed.
3. If you would like to try to correct the problem and continue printing with
the same card, do so by pressing the On/Cancel button to advance the card or
the Pause/Resume button to reverse the card. Use these buttons to help free the
card from its jam. Try not to move the card too far from where it was just
before the jam occurred. Once the jam is cleared, replace media, close the Top
Cover(s), and press the Pause/Resume button to resume printing.
4. If you would like to remove the jammed card completely, do so by using the
On/Cancel and Pause/Resume buttons to manually eject the card. Then,
replace media, close the Top Covers, and press the On/Cancel button. At this
point, the LCD Display will prompt you to either press the Pause/Resume
button or the On/Cancel button. Pressing the Pause/Resume button will cause
the printer to feed in a new card and reprint the job which originally jammed
along with all subsequent jobs still being sent. Pressing the On/Cancel button
will reboot the printer and cancel all jobs within the printer?s memory. In this
case, you must also cancel and resend the print jobs from your computer.
CLEARING A RIBBON OR OVERLAMINATE JAM
If the ribbon or overlaminate becomes stuck to a card or jammed inside the printer,
the LCD Display will indicate that it is jammed. Refer to the following steps to clear
the jam:
1. Leave the power ON, and open the printer?s Top Covers as necessary.
2. Remove the Take-Up core (the side with used ribbon or overlaminate on it)
from in between the two black Drive Hubs.
3. Steadily pull the ribbon or overlaminate free from where it is jammed. If stuck
to a card, pull the ribbon or overlaminate off the card and throw the card away.
If it is jammed underneath the rollers, press and hold down the printer?s
Pause/Resume button as you gently pull up on the ribbon or overlaminate. Do
not **** the ribbon or overlaminate to free it, since this will increase the chance
of breaking it. If it does happen to break, simply tape the broken end of the
supply roll directly onto the take-up roll. Then, wind a few inches worth of
ribbon or overlaminate from the supply roll onto the take-up roll. Be sure the
ribbon or overlaminate is passing beneath both the supply and take-up rolls.
4. Once the jam is cleared, replace media, close the Top Covers, and press the
On/Cancel button. At this point, the LCD Display will prompt you to either
press the Pause/Resume button or the On/Cancel button. Pressing the
Pause/Resume button will cause the printer to feed in a new card and reprint
the job which originally jammed along with all subsequent jobs still being sent.
Pressing the On/Cancel button will reboot the printer and cancel all jobs
within the printer?s memory. In this case, you must also cancel and resend the
H. CLEANING THE CARD FEED ROLLERS
To assure consistent printer operation, all of the gray card feed rollers within the
printer should be cleaned during every ribbon change (every 250 prints) or if the
rollers are noticeably dirty. To clean these rollers, use the special adhesive-backed
Cleaning Cards from the Printer Cleaning Kit. Refer to the following steps to run a
Cleaning Card through your printer:
1. Open the Top Covers and remove all print supplies from the printer. Leave the
printer power ON and the Top Covers open throughout this procedure. The
Cleaning Roller Assembly can also remain within the printer during this
cleaning process.
2. Remove the Cleaning Card?s adhesive backing paper.
Nov 12, 2010 | Fargo Pro L ID Thermal Printer
Card jams and ribbon keeps breaking
CLEANING THE INSIDE OF THE PRINTER
As you use your printer, dust and other foreign particles may accumulate inside
the printer?s case. These particles are attracted to the underside of the ribbon by
static produced during printing and can cause voids on the printed image.
Periodically, use the following procedure to remove dust and other foreign
particles:
1. Open the printer?s Top Covers.
2. Remove the ribbon and overlaminate from the printer.
3. Use a Cleaning Pad from the Printer Cleaning Kit or a soft, lint-free cloth
slightly moistened with isopropyl alcohol to wipe out all visible areas inside
the printer. Remove any debris that may be inside. Be extremely careful not to
let any alcohol drip inside the printer!
4. Once the cleaned areas are completely dry and free of foreign debris, re-install
the ribbon and overlaminate, and close the covers.
F. CLEARING A CARD JAM
on doing either:
Section 7: Maintenance 53
Pro-L Card Printer User?s Manual
G. CLEARING A RIBBON OR OVERLAMINATE JAM
the jam:
cleaning process.
I have problem in canon ir5000i the problem is waiting to print error how to solve this problem
Have you deleted all the pendding jobs in your print Q and reboot your computer & copier? Some one may have sent a print job on a odd size paper? Did you see if some one sent a job to the by pass tray. Try to put paper there and let the job run out.. Good Luck
May 11, 2010 | Canon imageRUNNER 5000 Copier
Solid orange light and blinking green lights
To check the light Pattern of your printer
Click on Light and Error HP Laser jet 1012 Printer
Check the error details from the above link
Condition of the printer Action/Description Ready
The printer is ready to print. No action is necessary. Processing
The printer is receiving or processing data. Wait for the job to print. Processing...(job name) Ready LED is blinking.
This message is displayed while the printer is processing a current job, but has not begun to pick pages. Processing...(job name) From Tray XX Ready LED is blinking.
This message comes up for any job, once the printer starts to pick paper. Manual Feed or Continuable Error
The printer is attempting to Manual feed, media is not loaded in the paper tray, media loaded is the wrong size or type. Verify that the correct media is loaded.
Press and release the GO button to continue printing. Out of memory
The printer is out of memory. The page you are printing might be too complex for the printers memory capacity. Try lowering the resolution. See Understanding print quality settings for more information. Door open, media out, no print cartridge, or media jam
The printer is in an error state that requires operator intervention or help. Check the following:
  • The print cartridge door is completely closed.
  • Media is loaded.
  • The print cartridge is correctly installed in the printer.
  • There is no media jam.
Printer initialization
A printer initialization is taking place. No action is necessary. Fatal error
All lights are on.
  • Unplug the printer for 30 minutes, and then plug it back in.
  • If the printer still has an error, contact HP Support.
All lights are off.
  • Verify that the printer is turned on.
  • Make sure that there is power.
  • Unplug both ends of the power cord, and plug them back in.
Job Cancel
All the LEDs cycle. Canceling...(job name)
The Job Cancel button was pressed and the job is aborted. Power ON
All the LEDs cycle. Checking Paper Path and Checking Printer
This only occurs at power up. Cleaning mode/Engine test
A cleaning page or engine test page is printing.
All the LEDs cycle. Cleaning Page prints
Wait until the cleaning page is finished printing and the printer is in Ready mode. This could take up to two minutes.
Wait until the engine test page is finished printing and the printer is in Ready mode. Clearing Event Log
All the LEDs cycle.
This will happen automatically during an NVRAM Init and a cold reset. No message will be displayed. No Action is Necessary. Power On
Initializing
This occurs when the product is powered on and coming out of EDOS. No Action is Necessary.
Jan 03, 2010 | HP LaserJet 1012 Printer
After a ps print job is sent and printed by the
There is probably nothing wrong with the printer, but it may not be be receiving all the dope it needs. Usually the printer needs a CR/LF signal at the end of the file to print. If it doesn't get that it will assume that it hasn't got all the file and will hang. This may be a setting in the application producing the file, or a setting on the printer itself (i.e needing either a full CR/LF signal or just one of these). Don't like the idea that it doesn't print its own test page though....
Dec 01, 2009 | Ricoh Aficio CL7000 Laser Printer
HP 1510 all in one printer won't print black.
It might be the cable ribbon to the black cartridge. If thats the case see if there are any rips in the line itself.
Jun 30, 2009 | HP PSC 1510 All-In-One InkJet Printer
19 people viewed this question
Top The Office Equipment & Supplies Experts
Gareth Cockram
Gareth Cockram
Tygh Duval
Tygh Duval
Jerry Greenberg
Jerry Greenberg
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
