How to factory reset a Technika LCD tv can anybody help please
  • Televison & ... Master
  • 1,525 Answers
Hi on the remote control press menu 4725, select reset, thanks
shaun
Posted on May 15, 2017
5 Suggested Answers
SuperTech-11
  • 1591 Answers
SOURCE: i have a technika lcd tv model:lcd191d-107/207
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you repeatedly turn it on, eventually it'll probably stay on, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for 5 mins, then try.
If you aren't tech savvy, this unit needs to go in for repair.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for different brand, but same issue) on youtube.
utube.png You-Tube video "BNHHrgX_6cs&feature=related" placeholder
utube.png You-Tube video "8l0AUj8QUkg&NR=1&feature=fvwp" placeholder
utube.png You-Tube video "Y7b_nTaZYcU&feature=related" placeholder
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors.
The parts are cheap, and skill required is minimal.
Posted on Mar 10, 2011
kevin_getz
  • 1031 Answers
SOURCE: need a manual for a technika LCD 22-18 TV
www.servicemanuals.net
Posted on Apr 30, 2012
gopakumarg43
  • 73619 Answers
SOURCE: How can i factory reset my ganzklar lcd tv
There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Posted on Nov 08, 2014
  • 1680 Answers
SOURCE: Sharp LCD TV
Factory Reset Sharp Aquos LCD TV
3 ways to reset TVs Sharp TV fix review
i understand some models need remote and other codes
Posted on Sep 15, 2016
Sky codes rev8 for technika LCD22-218
0065
065
0335
reset code back to factory for the remote as sometimes it needs to be reset on numbers.
TV
Hold Select + Red (flash flash)
999 (flash flash)
Select
206 is engineer code.
2011
hope this helps.
Jul 08, 2017 | Televison & Video
Need factory reset for Technika lcd 26-920
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
May 25, 2017 | Televison & Video
I have no remote and I think the TV is on child lock, it is a technika tv LCD 40" the stand-by light comes on but you can not get the tv to start. Is there a way to "factory reset" this tv without using a...
not sure it this will work on ur tv but try to unplug the tv, and push the power button on the TV and hold for 30 or more seconds,, on some TV's this little trick resets back to Default.
Jan 26, 2015 | Televison & Video
Technika lcd 32
Probable power supply failure.
Jan 13, 2014 | Televison & Video
I have a Samsung LE32R71B 32 in. A small red light at the bottom blinks but you can not turn it on Can anybody help me???
try factory reset switch tv to standby the info menu mute red standby button go to reset wait few mins then swich on
Aug 17, 2010 | Samsung LE32R71B 32 in. HD-Ready LCD...
Technika tv volume is up full when tv is switched on initially, how can I prevent this from happening?
Hi
I think this would be in your menu under audio settings, reset them all to factory settings and this should cure the problem.
Hope this helps
Apr 04, 2010 | Televison & Video
Technika SC500172 tv/dvd won't come out of standby.
my lcd screen is broken , i need a lcd screen for model no. SC 500172 , can i get it in india, singapore or dubai or anyother place and what is the cost.
Sep 01, 2009 | Televison & Video
Blank white screen on my technika lcd tv...please help
if you have your receipt or bank statement and bought it from Tesco, then give the helpline a call on 0845456676 and they will issue a otm (over twelve month) form, this will allow you to hopefully claim back either partial exchange or partial refund
Nov 26, 2008 | Sony KDF-E60A20 60 in. LCD HDTV
Need code for technika tv
i have bought a one for all tv controller and it doesn't have the code for a technika tv
Jun 21, 2008 | One For All URC 7740 Remote Control
I want to reset my TV
well when the blue light is on and ur tv is on standby, just use the channel changing button, simple!
Dec 06, 2007 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
