Question about Vizio Televison & Video
No picture on a Vizio E550I-A0
I have replaced the power board, main board, and LED strips on a Vizio E550I-A0. The back lights come on but there is no image. I am working on it for a friend who said there was a loud pop before the image went out. Any advice or help is greatly appreciated
eagle338
  • 4889 Answers
SOURCE: Loud Pop Vizio P50HDTV10A 50 in.
Just to add to the above post it can also be popped Ceramic fuses. Its worth a try. In most sets I fixed there are about 6 of them and cost you about 10$. Check the specs on the fuses and get the same ones. Pop the old ones out and the new ones in and see if it works.. If it doesn't you have to get a new PS board as WeListen2You has suggested.
Posted on Oct 20, 2008
  • 4134 Answers
SOURCE: So my vizio led picture went out. There were no back lights but you could still see picture on the tv if you shine a flash light at the tv. I replace my power supply board But it didn't work. Help!!!!
The backlighting has failed. If it is an older fluorescent bulb type you most likely need an inverter board.
Posted on Jul 16, 2015
gopakumarg43
  • 75169 Answers
SOURCE: Model e550i-b2. Backlight comes on but why no picture?
T'Con board fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
If you wish to get assistance over phone, visit this site. https://www.6ya.com/
Posted on Nov 02, 2015
AJIN G
  • 6694 Answers
SOURCE: I have a Vizio TV model E550i-A0. Most of the screen has darkened considerably but has a narrow horizontal lighter stripe near the top of the screen.
LCD panel of the tv is faulty.
http://electro-medical.blogspot.com/
Posted on Apr 07, 2016
AJIN G
  • 6694 Answers
SOURCE: 55 Vizio LED e550i-b2. Confirmed no back lights. Unplug for few hours, replug and works again for a few days. Is best bet led invertor going out? Visually the boards and connections look ok.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Posted on Jun 11, 2016
Hi I have a VIZIO E550i-B2 the TV has no pictures not sure if it has backlight but it does have Audio the only way to see picture is to shine a flashlight on it.
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Feb 18, 2017 | Vizio E550i-B2 55" LED TV 1920x1080, 120...
Vizio e550i-b2
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Feb 15, 2017 | Vizio E550i-B2 55" LED TV 1920x1080, 120...
I'm trouble shooting my Vizio e550i-2b It has power no backlights, image can be seen with a flashlight, I've replaced led driver board and problem persists, do you suggest main board next?
If you can see an image with a flashlight and you can control the tv with the remote then the main board is not the problem. You've replaced the LED driver board, so that leaves the LED strips inside the LCD panel as the likely problem.
Feb 11, 2017 | Vizio E550i-B2 55" LED TV 1920x1080, 120...
Vizio e550i-b2
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board....
Dec 27, 2016 | Vizio E550i-B2 55" LED TV 1920x1080, 120...
Vizio e550i-b2 no led backlight
May 03, 2016 | Vizio E550i-B2 55" LED TV 1920x1080, 120...
Vizio TV has sound but no picture
Dec 02, 2015 | Vizio Brand Original Remote for E320i-B0...
How to fix my led screen, it has no picture i have purchase and replace the led driver.
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Command voltage to switch ON the LED driver section, should come from the main board's system control section. It do not come now.
Aug 07, 2015 | Vizio Smart TV keyboard remote control for...
To fix no video Vizio E470i-A0 TV
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
May 21, 2015 | Vizio Televison & Video
Televison & Video Logo
29 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
