I have a 26 Technika LCD tv all that comes up his no signal nothing wrong with the aerial
    Master:
  • 923 Answers
That's funny ... I though Ariel was a cartoon character in a movie, and therefore the term should be capitalized!
Posted on May 15, 2017
Technika 17 inch tv manual
Its a main board issue, generally with this issue its a 3.2 volt regulator that fails but sometimes its easier to replace the board unless your quite knowledgeable in electronics and have the proper test equipment
Nov 25, 2017 | Televison & Video
I have a brand new technika tv 216/54g. It has freeview built in. I have a brand new indoor digital amplified aerial also technika but I cant get it to pick up any stations. Do I need anything else? please...
You don't necessarily need anything else, but you may not have a strong enough signal to pick up the digital/freeview channels using an indoor aerial. It could also be that the indoor aerial is not correctly aligned.
If the signal strength is lower than approx. 50%, the TV may detect them during the automatic channel scan but it wont store them. When the signal strength for any digital channel is 50% or lower it's more or less unwatchable - the picture would be constantly breaking-up or freezing and the audio drops out continually. Trying to scan for channels using an indoor aerial is rather hit and miss. Numerous attempts may be necessary before you get any channels.
Assuming you have a roof aerial, it is far easier to temporarily connect the TV to a fixed aerial point while you run the automatic channel scan. The TV will store all the channels and you can then move it to it's permanent location and connect the indoor aerial. You can then adjust the indoor aerial with the channels already stored until you find a location for the aerial where you have a good signal.
Doing it this way also eliminates the possibility of a fault with the TV and confirms that you are performing the channel scan correctly. If the TV is connected to a fixed aerial point and you are still unable to receive or store any channels, then it's likely that you are performing the channel scan incorrectly or there is a fault with the TV.
Please try scanning your channels using a known working fixed aerial point. If you are still unable
to receive any channels - or you don't have any fixed aerial points - please post back for further assistance.
Hope this helps.
Regards,
BElectric
Feb 28, 2011 | Televison & Video
Have connected up my Technika freeview box to my RF aerial and when I try and finish installation I get a message that the antennae signal is too strong. Do you have any ideas what is wrong?
Yes, fit an attenuator to the input lead. I suspect the signal is overloading the digi box. Attenuators are available and widely used by aerial contractors. Try a -6DB first.
Jan 04, 2011 | Televison & Video
Technika 26'' lcd tv long time to warm up
the reason maybe a bad capacitor that is taking time to charge up to the nominal voltage. check for capacitors (electrolytic) in the power section (probably smps). it may appear bulgy than the others.
May 31, 2010 | Televison & Video
No TV signal
try a different aerial if that doesnt work do a factory reset and then redo your first time installation
Jan 02, 2010 | Televison & Video
No picture sound only
your lcd tv is most likely not getting enough reception for the visual signal, try switching your tv back to analog signal (not digital) if you can by switching off av on remote, do you get your picture back, if yes thats your problem check your aerial, aerial leads and plugs, also do you have an aerial amplifier plugged into a power point, is it turned on to aplify signal.
Jun 22, 2009 | RCA L26HD32D 26 in. LCD HDTV/DVD Combo
I must be doing something wrong !! My Technika 22" LCD TV goes through the set up process and only picks up the BBC channels , Can anybody tell me how I can view any of the freeview channels ???. They dont...
Hi I am Vortash .. usually the problem is aerial the digital aerial is diffrent to the old UHF aerial and you will need to change it should you still be using it .. from what you say the set is working fine and you didnt do anything wrong .. it is just like unlike the old annalouge signal where you would get a picture even if it was poor .. digital systems are less forgiving of low signal and just blank the low signal channels out .. to check for sure if your not already , use a set top aerial.. and move it about to find the best signal if you get more channels problem found so update your aerial ( Or stand the kids in the corner holding the aerial ?LOL ) I hope this helps and that you will be on freeview soon .. oh and check with the ITA that your area has full Freeview transmissions .. there is a 24 hour call line .. on 0800-40 85 902 and they will give you all the information you will require hope this helps Regards Vortash
May 20, 2009 | Sony Televison & Video
Ive just been given a Technika television LCD19DVDID 308 and I can't find out how to watch analogue channels,can anyone help me please?
have fitted a new aerial as tv was connected to sky and now cant get any freeview channels keeps saying no signal what am i doing wrong
Mar 16, 2009 | Sampo PME-50X7 50 in. HD-Ready Plasma...
Technika 15.4'' tv/dvd can't find antenna that is plugged in
When almost all TV stations went digital, analog TV signals received via an antenna all but disappeared in the United States. So you will not be able to get much, if anything at all without a digital TV connected to a cable system or a satellite system. Welcome to the new economy! You want it? You will PAY for it! Radio (first FM, then AM) will most likely be the next casualty of the new economy!
Apr 19, 2017 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
