Question about Ovens
Bush besc60w oven fan not starting untill oven switched on for a few minutes, what's the problem
2 Suggested Answers
Larrysito
  • 73 Answers
SOURCE: noisy fan once oven at temperature, this continues
copper rings (used as bearings) r out that is the problem od the air flo is jamed that is y is then owen fan owerheated....and copper is loose not tight anough
Posted on Jun 08, 2009
Oven and works but fan not working bush ad66tb
The fan could be greasy and "stuck", you'd have to take it out to check.
Unfortunately replacement fans are quite expensive:
Bush AD66TB Fan Motor 230V 23W Cl
Jul 15, 2016 | Ovens
My oven fan has recently started to make a very loud rattling noise for around 30 seconds once every few minutes while the oven is turned on in fan mode.
The fan needs be cleaned and lubricated. To do this: Turn off stove/oven. Remove fan cover plate. Remove fan. Clean and lubricate the shaft bearings with 3 way oil. Install fan and cover plate.
May 16, 2016 | Smeg Ovens
I have a Bush AE56DA electric oven, the main oven has stopped heating up. Also the oven light and thermostat light have stopped working. Everything else works fine. Any idea's? Thanks.
This sounds like a regulator problem, now there are the switch or a built in behind the cooker. WARNING DO NOT OPEN ANY PART OF THE OVEN ISOLATE THE MAINS FIRST.
You will need a tester, multi-meter would do. check the switch for continuity check the heating element there may be a hole in it, its very difficult to see slight Gray Colour just at the hole, find and inspect the fan motor if there is no continuity after disconnection of wiring between the winding terminals, on most models you have to remove the fan before you can inspect the heating element, but there are a few the other way round. Hope this is helpful .
Regards
John
Nov 02, 2014 | Ovens
I have a bush AE56DW oven bottom oven was working, but now only the fan works and there is no lights or heat coming out?
have the very same problem on my bush stove though have just found the problem out, on the oven switch looking inside has all the wires but what hidden and needs taking out it s fuse near the knob and cannot be seen until taken out and your see this thermal fuse blown this stops all power to inside stove light no power then to thermostat oven temp everythings dead,
ive tested everything untill ive looked at replacment parts and then your shown a fuse of 240 vol when do they put this in such a place clear to have use all have to call out an engineer, ive beaten the system
Apr 05, 2014 | Ovens
Have A Vulcan VC44gd oven that when you turn it on it trips the breaker. Where should I start.
Blower mtr would be a good start will it sit there until you turn on the power toggle switch.You could isolate the blwer mtr by un wiring directly at mtr.Beware there is a few wires in the junction one set of those wires are for the centrifugal switch(ie the fan has to be runnin for the oven to lite)
Feb 20, 2011 | Vulcan VC44GD Gas Double Oven
Bosch HBN 455 Oven Cooling-Fan Issue
After the oven is switched off, the after-run of the cooling fan is controlled by an electromechanical thermostat switch. The fan can switch back on, due to residual oven heat that accumulates within the oven's outer case and reactivates the cooling fan temperature switch. Considering yours is making buzzing sounds and activates on and off, the fan's thermal switch may have dirty contacts or just be defective and require replacement.
Sep 12, 2007 | Bosch HBN 455 Stainless Steel Electric...
Oven cuts out after ten minutes and comes back after cooling down.
We have the same problem with our oven, AEG B2190-1.It started on on Christmas day[worst day of year]gets up to temperature after 10-15 minutes cuts out everything switches off until the oven has cooled down, The oven is only 18 months old. We have been told that it is a thermostat problem.
Dec 10, 2006 | AEG B2100-4 Electric Single Oven
Ovens Logo
26 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
