Have a 26 LCD and keeps saying no signal but works through a set top box
3 Suggested Answers
SOURCE: LG 26 inch lcd. Recently it loses the signal from sky remote eye
hi! maybe there is a problem on power supply section or loose connection.
Posted on Sep 01, 2009
SD Tech
  • 14553 Answers
SOURCE: my box keeps saying no signal
If its a cable or satellite box first remove power from it and the set it is connected to for a while and then power back up as this will allow the box and or the set to try to reboot.
not sure what kind of box you have but replace it if you can or test it on another set.
Posted on Dec 06, 2012
My brand new lcd tv keeps saying no signal when cable is plugged in?
Check the input setting and make sure it matches where it cable is plugged into.
Jan 22, 2013 | Dynex Dx-26ld150a11 26" 720p Hd Lcd & Dvd...
Connected 26LV2500 into cable dvr box, but get no signal
Have the cable company (should be able to be done over the phone) check and boot the box (reset it) and some can have this done by unplugging box and letting it self boot.
More likely the box than the set.
Mar 25, 2012 | LG 26 26LV2500 26 LCD TV
My 26LG300 works for about a minute and then screen goes blank and says no signal. I change channel...same thing happens?
Tries unplug,replug the tv and cable box back like an hour later.The tv now,should reset itself back to the factory setting.The cable box will,reseting itself and updated it softwares.The tv should work now.
Oct 21, 2010 | LG 26LG30 26 in. LCD TV
LC-26DA5U 26 in. HDTV-Ready LCD Television: i connect a hdmi cable 2 my hd cable box - the pic...
The cable box needs to be set to send different signals when using hd tv and standard tv. Usually a good setting would be 720p in hd and 480p in standard. The tv is working fine it is the cable box sending the signal. If you have another hdmi source such as a dvd player you may hook that up to show the tv is working just fine.
May 07, 2010 | Sharp LC-26DA5U 26 in. HD-Ready LCD...
I have a Hitachi 26LD8000TA LCD tv - does it have a built in digital tuner or do I have to get a set top box to receive the new digital channels?
The Hitachi 26LD8000TA is HD ready which means it has a digital tuner. You do not need a set top box unless you are getting your signal from a cable company that encrypts their digital signal.
Oct 09, 2009 | Hitachi 26LD8000TA 26 in. LCD TV
Sep 01, 2009 | LG 26LG30 26 in. LCD TV
VGA connection just reads "no signal" Brand new TV and VGA cable.
i have a 26" insignia lcd tv that i use as a montor uou musr set the screen resolution on your computer to 1024x768. if you use a higher resolution it will say no signal.so use your montor to set the resolution to 1024x768 then hook it to the vga and it should work. bob griggs
Jun 15, 2009 | Insignia LCDTV26 26 in. Television
My dtv keep saying nosignal antina hooked up .protron tv was working fine ran scan station. stop playing
dtv needs a strong signal to keep track of the channel. The antenna is good inside the room but tends to be affected for interferences. to catch signal (as in the past with ear rabbit antena) is difficult inside the room. and roof antenna is better but needs a good installation. the cable channels can work digital without the dtv. Is hard to give you any idea besides this ones because i don't know how the set up[ is in your case problem, but i hope i could help you a little. Now if the antenna is rasonable good and still having problems with your channels the suspect the dtv failure.
Apr 24, 2009 | Protron PLTV-26 26 in. HD-Ready LCD...
"Weak or No Signal" message on Samsung 26" LCD TV
I pressed mute on my television and about 5 minutes later it said weak or no signal.What do I do?
Feb 24, 2009 | Samsung LA26R71BD 26 in. HD-Ready LCD TV
When I plug in my hdmi set top box my monitor says no signal
If an HDMI cable won't work, try Component Cables.
I went through the same hassle as you.
Jan 25, 2009 | Hannspree 22" widescreen LCD Flat Panel HD...
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
