My ken more top load washer model 2002 leaks water after it finishes washing.What is the problem?
    Master:
  • 923 Answers
The problem is, water is not contained within the machine or the hoses, so you have a leak, which may require seals or other parts being replaced.
Posted on May 15, 2017
Leaking and saying overflow
it could be the air sensor for water level but more detailed info would help. is it still going through all cycles even when it leaks out and is water still being put in? or is it empty going through the cycles?
Mar 28, 2014 | Maytag Atlantis MAV6000 Top Load Washer
Washer machine
Sounds like the hot water solenoid is stuck.
Feb 11, 2008 | Kenmore 22422 Top Load Washer
Water underneath unit?
Check your water hoses may be leaking behind the machine or at the tap.If the hose is leaking turn all taps off. the alloy crimp needs to be cut off & put a hose clamp on the hose.turn all taps off when machine has finished the wash.
Feb 01, 2013 | Fisher and Paykel GWL11 Top Load Washer
Kenmore 27841 Top Load Washer has developed a water leak
Hi, Check the pump. Tip the washer back after the load finishes and see if the pump is dripping. The pump is located on the front side of the motor. If the leek seem to be in the front center of the washer, it is probably the pump. I hope this helps. Please let me know if I can assist you further.
Vic
Jun 27, 2009 | Washing Machines
Water level high when spin/drain cycle begins.
The water level is higher when in the rinse mode; but it should never leak. Examine the interior through the rear, there should be a loose hose somewhere. Or at the filter area. Plug off the mains caution.
Feb 28, 2009 | Kenmore 22932 Top Load Washer
Kenmore series 80 washer leaking.
about the #1 leak on ken more/whirlpool washers are the pump.it is in the frount middle.you can dry up around washer and slide news paper under it then run load.that will narrow your surch area unless just over filling thats another matter.God bless,tom
Jan 03, 2009 | Kenmore 24032\24036 Top Load Washer
Small amount of water from washer
ck around pump at place motor shaft connects ..that is mot likely place
Sep 12, 2008 | Kenmore 24032\24036 Top Load Washer
Washing machine
Depending on the age of the unit:
Possible minor leak at the pump.
Possible leak at the spin bearing/boot seal.
Dec 30, 2007 | Fisher and Paykel IWL12 Top Load Washer
Leaking Washer
Changing this solenoid could solve your problem. Also try to turn off your faucet if possible after you hv finished your washing.
Dec 24, 2007 | Fisher and Paykel GWL11 Top Load Washer
Cold water continues to run during entire wash cycle
Adrea, sounds like you need a new valve. When it's doing this leaking, unplug the washer. If it's still leaking you know for sure it's the valve. Part number for the model posted is 22002360. Catriver..post back.
Sep 30, 2006 | Maytag LAT3600A Top Load Washer
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
