Question about Dryers
HOW CAN I CHECK THIS OUT Defective high limit sensor WILL IT BE OPEN OR CLOSED IF IT IS BAD
    Master:
  • 923 Answers
It is a dangerous assumption to conclude that a "defective" sensor will be open or closed, because third and fourth possibilities exist. The 3rd possibility is that there is a resistive connection in the sensor, and the 4th possibility is that there is an intermittent connection which comes and goes, or a combination of those last two, meaning that the resistance can change wildly ... as you would expect with a cracked resistor!
Posted on May 15, 2017
The dryer will not start. it seems the thermal fuse is good. (2.5 ohms on Ohms meter)
Hello Rusty,
Try holding the Start Button for more than 3 seconds.
  • Check that the door is closed properly. Check the door Catch & Switch with an ohmmeter for continuity when close.
  • Make sure the High Limit Thermostat is good
  • The Thermistor can be open.
  • Check the Heating element for continuity.
  • Idler pulley might be bad.
  • The Control Board my be defective.
  • The Moisture Sensor can also be bad.
  • Last but not least the dryer Motor might also be defective.
Here is a link to Sears Parts. Most of the parts you may need are in the Bulkhead Diagram.
Best of Luck,
JP
MAYTAG RESIDENTIAL DRYER Parts Model MED9700SB0 Sears PartsDirect
Jul 19, 2015 | Maytag MED9700S Electric Dryer
Pilot wont stay lit falcon dominator fryer
There are several possible causes of this problem, aside from a loose or damaged wire, which is uncommon. The cause in about 95% of the cases is a thermopile that has gone bad. The thermopile is the small cylinder that is attached to the pilot assembly where part of the pilot flame can contact it. It has a cable or wire going to the gas valve, high limit switch, or both. When hot enough, it produces and electrical current that keep the pilot on and allows the main gas valve to open. This is not hard to replace in most gas fryers and not too expensive. This often starts as an intermittent problem. The second possible cause is a defective high limit. The high limit is a small rectangular device with wires going to the gas valve and a tiny stainless tube that goes through the bottom of the kettle to a sensor bulb, like the thermostat has. These are usually self resetting, but may have a small red reset button. If present check the reset. If no reset, jump the two wires and see if the fryer will now light. If so, the high limit is defective, assuming the fryer is not over temperature. If defective, replace. Do not operate the fryer in this condition as there is no over temperature protection. The next cause is if the oil is too hot, in which case the high limit will shut off both the main burner and the pilot. The pilot cannot be relit until the fryer cools down and the high limit resets. If the oil is too hot, usually over 425F, replace the thermostat. If the high limit trips when the oil is in the normal operating range, replace the high limit. The final cause is a bad gas valve. This is not too common, but the gas valve is expensive and a bit difficult to replace. Check all of the other causes first.
Sep 19, 2014 | Kitchen Appliances - Others
Nearest engineer to Stamford
Sep 16, 2014 | Pitco Frialator Kitchen Appliances -...
Frymaster troubleshooting
Aug 24, 2014 | Kitchen Appliances - Others
Why Deep Fryers pilot goes out all sudden?
There are several possible causes of this problem, aside from a loose or damaged wire, which is uncommon. The cause in about 95% of the cases is a thermopile that has gone bad. The thermopile is the small cylinder that is attached to the pilot assembly where part of the pilot flame can contact it. It has a cable or wire going to the gas valve, high limit switch, or both. When hot enough, it produces and electrical current that keep the pilot on and allows the main gas valve to open. Be sure that you have a good pilot flame. The pilot may need to be cleaned or adjusted. The thermopile is not hard to replace in most gas fryers and not too expensive. This often starts as an intermittent problem. The second possible cause is a defective high limit. The high limit is a small rectangular device with wires going to the gas valve and a tiny stainless tube that goes through the bottom of the kettle to a sensor bulb, like the thermostat has. These are usually self resetting, but may have a small red reset button. If present check the reset. If no reset, jump the two wires and see if the fryer will now light. If so, the high limit is defective, assuming the fryer is not over temperature. If defective, replace. Do not operate the fryer in this condition as there is no over temperature protection. The next cause is if the oil is too hot, in which case the high limit will shut off both the main burner and the pilot. The pilot cannot be relit until the fryer cools down and the high limit resets. If the oil is too hot, usually over 425F, replace the thermostat. If the high limit trips when the oil is in the normal operating range, replace the high limit. The final cause is a bad gas valve. This is not too common, but the gas valve is expensive and a bit difficult to replace. Check all of the other causes first.
Aug 22, 2014 | Kitchen Appliances - Others
Pilot will not remain on Imperial deep fryer model ifs 40
Aug 12, 2014 | Kitchen Appliances - Others
The burner will not be lit and the ignition goes out
Aug 07, 2014 | Cecilware Kitchen Appliances - Others
Why does the deep fryer pilot goes out
There are several possible causes of this problem, aside from a loose or damaged wire, which is uncommon. The cause in about 95% of the cases is a thermopile that has gone bad. The thermopile is the small cylinder that is attached to the pilot assembly where part of the pilot flame can contact it. It has a cable or wire going to the gas valve, high limit switch, or both. When hot enough, it produces an electrical current that keep the pilot on and allows the main gas valve to open. Be sure that you have a good pilot flame. The pilot may need to be cleaned or adjusted. The thermopile is not hard to replace in most gas fryers and not too expensive. This often starts as an intermittent problem. The second possible cause is a defective high limit. The high limit is a small rectangular device with wires going to the gas valve and a tiny stainless tube that goes through the bottom of the kettle to a sensor bulb, like the thermostat has. These are usually self resetting, but may have a small red reset button. If present check the reset. If no reset, jump the two wires and see if the fryer will now light. If so, the high limit is defective, assuming the fryer is not over temperature. If defective, replace. Do not operate the fryer in this condition as there is no over temperature protection. The next cause is if the oil is too hot, in which case the high limit will shut off both the main burner and the pilot. The pilot cannot be relit until the fryer cools down and the high limit resets. If the oil is too hot, usually over 425F, replace the thermostat. If the high limit trips when the oil is in the normal operating range, replace the high limit. The final cause is a bad gas valve. This is not too common, but the gas valve is expensive and a bit difficult to replace. Check all of the other causes first.
Jul 14, 2014 | Vulcan EF4 Deep Fryer
Maytag elec. neptune dryer won't heat
The first thing I would check would be your high limit thermostat. It is located near the heater and is wired in series with the heater. The contacts in a high limit thermostat remain closed at temperatures below 250 degrees. The contacts will open and interrupt the circuit to the heater when the operating thermostat, thermistor or electronic control fails to cycle properly. The most common condition that causes the high limit thermostat to operate are vent restrictions, blower failure or a defective operating thermostat or thermistor.
If those are good, then,
Check your dryer heater. With both heater power terminals disconnected you can check for resistance. The typical dryer heater resistance is around 20 Ohms.
If you can not read resistance on the dryer heater then it is an open circuit and needs replaced. Also if your meter indicated an electrical path between either of the heater terminals to the heater frame (ground) then it’s bad. The heater must be isolated from its mounting frame.
Jul 06, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
21 people viewed this question
Top Dryers Experts
