Sewing Machines Logo
Posted on Jul 25, 2009
Lost the manual bernette 75 bernina ( swedish version)
I have lost mine too, and I dont know if I can trust the different sales sites for manuals
Anonymous
Level 1:
Problem Solver:
  • Contributor 11 Answers
  • Posted on Jul 29, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
11
Questions
0
Helped
7538
Points
19
Hey if you need a new manual go to this link www.ifixmachines.com and dont forget to put this code (150t) so you can get $1.50 discount. Hope this help.. By the way the manual cost only $10. BYE
I need a manual for a bernina 006D
I'm not able to locate a manual but the following may be helpful. Although the manual is for an 004D serger, it is probably similar enough to your machine to be useful.
Bernina Funlock 004D Instruction Manual
Bernette for Bernina FunLock 006D
If you search for:
Make Model manual
you may get lucky and find a manual for sale on sites like eBay.
I need a service manual for my Bernina Bernette 340 Deco embroidery machine
Service manuals are difficult, if not impossible, to find as they are intended only for technicians. You may be able to find one for sale somewhere, ie eBay or some other web site, but the likelihood is low.
I am looking for a user manual for a Nina 150 Sewing Machine, was told it is a Bernina model, but cannot find anything. Serial no. 828006565. Mine was lost when we moved by the moving company. Martie
Am unable to locate a manual for your Bernina 150 on Bernina's web site. You may want to take a look. Perhaps you will find a model close to yours that you can use.
Here's one for purchase:
Instruction Manual Bernina Bernette Virtuosa 150
However, did find this but know nothing about this web site:
Bernina 150 160
2answers
Where can I get power cord, foot pedal, and manual?
About 17,700 results (0.94 seconds) Search Results
    Bernette Sewing Machines - BERNINA Support: Machine ...
    www.bernina.com/...Manuals/bernette-manuals/Bernette-Sewing-Machin...
    Bernette Sewing Machines Within this section are the Bernette series of sewing machine manuals that are no longer ... bernette 50 / 60 / 70 / 75 Manual (7.4 MB).Missing: power
    [PDF]Manual - Bernina
    www.bernina.com/de/.../BERNINA.../bernette.../Manuals/deco340_EN_...
    Congratulations on your decision to buy the bernette Deco 340. By owning .... Insert the power supply plug into the wall outlet and turn the power switch on. 1.
    BERNINA Support: Machine and Accessories Finders, and ...
    www.bernina.com/en-US/Support-US
    Out of Print Manuals. Out of ... BERNINA FAQ - Find answers to frequently asked questions. ... Please note: this service can only address SOFTWARE questions.
    www.bernina.com/.../BERNINA.../BERNINA.../Manuals/0333017104_2...
    You've decided on BERNINA, a reliable choice that will delight you for years to come. For over 100 .... Power cable. · .... control the sewing speed by pressing the foot
How can i get a manuel for Bernette 600 deco
Currently, I saw a Bernette 600 Deco manual for sale on eBay; also he Bernette 500 Deco manual is available for download on the Bernina site. Before I purchased one, I would call Bernina to see if they have one you can either download or purchase. Their number is 630-978-2500. I also found one for sale for about $14.00 here: Bernina Sewing Machine Manuals Instruction Manuals
1helpful
I have a Bernette 335ds serger and one of the needles fell out (plus I need to take the second needle out. The thread has broken in that needle a dozen times, also. I can't find my manual, and don't...
I have a Bernette 334D serger - I'll make a guess that your 335DS is similar.
There is a manual for your model for sale on www.ebay.com right now, item number is 150565998515.
Assuming your needle assembly is the same as mine, you switch off the engine, turn the flywheel until needles are at the highest point, then take the green small straight blade screwdriver from your machine kit and use it to unscrew (righty tightly, lefty loosey) the needle screws a little (never unscrew all the way out!!!) so you can remove the needles. I use my tweezers for this job as it makes holding the needles easier. You may also want to unclip the pressure foot and raise the upper blade out of the way for a bit more room.
Then slide a new needle into each holder, flat shank to the back and tighten up the needle screws again. Remember that the two needles sit at different heights from eachother so make sure each goes fully up into the needle seat, then retighten with the screwdriver.
I hope this helps you with your Bernette, I've had my 334D since 1990 and its still going strong.
Lost Manual for Bernette 75
Here it is www.fabricland.ca/Bernette_Series_209b.pdf
Hope this will help you.
Thanks for using fix ya
Top Bernina Sewing Machines Experts
ZJ Limited
ZJ Limited
Jesse Walters
Jesse Walters
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
