Question about Brother DCP 7010 Multifunction Laser Copier
Canon Pixma MX300 says paper jamed but there is no paper jamed. There was paper jamed but I pulled it out
    President:
  • Brother Master
  • 1,447 Answers
Dear sir please chack paper delivery sensor
i gues it was broken or displace
Posted on Aug 16, 2009
Canon Pixma MX300 printer had a paper jam. I took out the paper, and it was all there with no missing parts. It continues to say there is a paper jam - there appears to be no reason for the jam. I...
Try checking that a foreign object is in the paper feed rollers- do this by inserting a thin piece of plastic about 2 cm wide through the rollers from the paper exit side. Plastic like that from a shirt box (about 2cm wide by 20 cm long and 1 mm thick works well. I have solved this problem many times with my mx300 and it clears out objects which have droppped into the paper feed, such as Pens , yes pens. and paper clips etc which are otherwise hard to detect on this printer.
Sep 25, 2010 | Canon PIXMA MX300 All-in-One Printer
Paper jammed removed paper but still saying paper jammed
here's a link to the manual good luck
http://iusermanual.com/printer/canon-pixma-mx300-printer-manual.htm
Jul 25, 2010 | Canon MX300 Office All-In-One Printer
How do I pull out jammed paper?
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 01, 2010 | Canon PIXMA MX300 All-in-One Printer
How do I remove paper jamed in the printer?
Paper Jam :
Cause 1 : Paper jammer in the Paper Output slot or the Rear Tray.
Action : Remove the paper following the procedure below.
a) Slowly pull the paper out, either from the Rear Tray or from the Paper Output Slot, whichever is easier.
* If the paper tears and a piece remains inside the machine, turn the machine off, open the Scanning Unit (Printer Cover) and remove it.
Be careful not to touch the components inside the machine.
After removing all paper, close the Scanning Unit (Printer Cover), and turn it back on.
*If you cannot pull the paper paper out, turn the machine off, and turn it back on. The paper will be ejected automatically.
b) Reload the paper in the machine, and press the OK button on the machine.
If you turned off the machine in step a), all print jobs in queue are canceled.
Reprint if necessary.
If you canot remove the paper or the paper tears inside the machine or if the paper jam error continues after removing the paper, contact your Canon Service representative.
Cause b)Landscape credit-card-size paper jammed inside the machine.
Action : Do not load credit card-size paper in landscape orientation.
Slowly pull out the paper from the Tray and remove it.
If you canot remove the jammed paper or if the paper jam error continues after removing the paper, contact your Canon Service representative.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Nov 25, 2009 | Canon PIXMA MX300 All-in-One Printer
Recurent paper jam on Cannon Pixma MX300
Some printers have a certain paper height or paper load you can have loaded at one time. I would try loading a smaller amount of paper and see if that helps. If it still does the same thing your paper thickness lever may be damaged.
Sep 07, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Canon Pixma mx300 printer has paper jam message.
Canon Pixma MX300
- new cartrige for Black ink
- can scan
- can photocopy documents
BUT can't print documents from my MacBook eventhough the paper feeds and goes out at the other side
Aug 10, 2009 | Canon PIXMA MX300 All-in-One Printer
Canon mx300 printer feeder pulls unevenly causing paper jam
the left side of the printer pulls the paper causing the printer to jam when trying to print
Apr 03, 2009 | Canon PIXMA MX300 All-in-One Printer
My printor is not taking in the paper
there is a paper jam att the back of the printer
Mar 14, 2009 | Canon PIXMA MX300 All-in-One Printer
Canon MX300 printer shows jam and no paper in
I got hold of Canon support & he had me give him a # behind the white ribbon inside & after that he asked when purchased (7-28-08) Now I will be getting a new unit and have to send back old one at NO cost to me. Who knows???? Was happy with the outcome & surprised!
Nov 16, 2008 | Canon PIXMA MX300 All-in-One Printer
Brother DCP 7010 Multifunction Laser Copier Logo
115 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
