Question about The Office Equipment & Supplies
My ir photo copier display load correct paper whiles there is paper in the cassette
  • 2072 Answers
SOURCE: Copystar 1635 copier/printer set up problem
What the problem sounds like is that the machine and print driver are set to diifferent paper types.
One says plain paper and the other bond paper.
Or something like that, the machine says bond and the printer plain paper.
Chech the size setting and paper orinentation.
Most of the time the paper type is wrong. Also check paper color etc etc. Something between the machine and driver is mismtached.
Posted on Feb 12, 2008
SOURCE: CANON MF4140 'LOAD CORRECT PAPER CASSETTE : LTR'
I had same thing happen after a fresh Windows install. It was hard to figure out since it had been working fine until then, but luckily it is simple to fix. Open the Start Menu > Settings > Printers and Faxes folder. Then right-click on the Canon MF4100 Series printer and choose Printing Preferences. In there, change the Paper Size to Letter (instead of A4). You may also have to do this in the Print setup for whatever program you're using to print.
Posted on Nov 14, 2008
I had the same cr@p of the problem yesterday. The problem was not in the paper. You have to do 2 simple things, from which one will solve the problem.
first, download the latest drivers and install them.
And the more important thing, the problem occurred due to incorrect paper format. Solution is very simple. Open MS word or something similar, file->print.. and before you print open Properties menu. There for the Output Size will be selected "Match Page Size". you don't want that (i don't know why it doesn't work), but the solution is manually select A4, or whatever your page size is.
Posted on Dec 27, 2008
I had the same cr@p of the problem yesterday. The problem was not inthe paper. You have to do 2 simple things, from which one will solvethe problem.
And the more important thing, the problem occurred due to incorrectpaper format. Solution is very simple. Open MS word or somethingsimilar, file->print.. and before you print open Properties menu.There for the Output Size will be selected "Match Page Size". you don'twant that (i don't know why it doesn't work), but the solution ismanually select A4, or whatever your page size is.
And there it is... printer starts throwing pages out like crazy :)))
SOURCE: "paper-feed error"
Had the same problem with mine, very intermittent. Remove all the paper and open the feed tray lid so you can get access to the three grey pinch rollers. Start printing then push on the roller with your finger to try and 'rough it up' (if it clicks you are pressing too hard).
The fault appears to be that the pinch rollers are loosing their grip and can not pull the glossy paper through. I dare say using a mild washing up liquid solution would be better but this is a safe quick fix.
Did this to mine and it has worked fine ever since.
Posted on Aug 02, 2009
Canon ir 3030 paper loading problem in cassette
The problem could be one of several things.
1) Check your "printer preferences" setting and make sure you have selected the CORRECT SIZE OF PAPER. For example; Letter, Legal, etc.
2) Un-install and re-install the drivers.
Hope these suggestions help.
Nov 03, 2014 | Canon imageRUNNER 3030 Black and White...
Red light flashes, screen says "load correct paper: A4." The paper is alreay loaded. I cannot print.
When <LOAD CORRECT PAPER> appears on the display, the size of the paper in the paper cassette or multipurpose tray is different from that of the paper specified in <PAPER SIZE> for <CASSETTE> or <MP TRAY>. You need to load the correct size paper or change the paper size in <PAPER SIZE> for <CASSETTE> or <MP TRAY>.
Check if the size of paper loaded in the paper cassette or multi-purpose tray meets the paper setting specified in the machine.
check the following:
1. The paper size specified on the printer driver screen
2. Paper loaded in the machine
3. The paper size set in <PAPER SIZE> for <CASSETTE> or <MP TRAY>
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Jan 16, 2013 | Canon ImageCLASS D1120 All-In-One Laser...
Keeps saying paper cassette no set correctly or objects blocking path
I was also stuck with this error message for a while. It turned out to be a 4x6 photo paper got stuck in back in a place that was not easily visible. I had to detach the double-sided paper module from the back, tilt the printer on its side and reach in with fingers and pliers to pull it out. The error message was correct, that something was blocking the cassette tray even though you could push the tray all the way in!
Jan 31, 2012 | Epson Artisan 800 All-In-One InkJet...
Trying to print - got Warning message THe paper cassette is no set correctly. Check for any objects in the cassett of block the cassett path and insert correctly
This can also be caused when the upper cassette tray (for small paper stock / photo paper) becomes detached from the lower tray. There is a gear attached to the lower paper tray which handles movement of the upper paper tray. Make sure that moving this gear causes the upper paper tray to move. If it doesn't, then you need to snap the upper paper try on a little better.
Jun 26, 2011 | Epson Stylus Photo 810 InkJet Printer
I tried to copy with my canon ir 2018 and my canon copy a half of the contents,and tell me load correct paper
I believe you don't have the paper size slide on the front of the paper cassette correct. Look at the slide carefully because it also has the paper direction picture along with the size.
Jun 14, 2011 | Office Equipment & Supplies
Please describe your cannon laserbase 5630 showing paper check error after printing one print problem:
Hi mani4u58,
After the print,does the alarm indicator show?
Are the papers loaded and aligned in the correct way in the printers cassette?Please align them well and also note that the cassette can hold only around 250 sheets at a go.Remove the cassette completely when loading the papers and after paper load,insert the cassette as far as it can go.Does the printer feed paper correctly?If not,there may be a paper jam.To clear the jam,open the front cover by pulling it towards you.Remove the cartridge and inspect the compartment.Also make sure the orange adhesive tape around the cartridge is full removed to free its connections.You can also unplug the printer and leave it for a while and then plug it back to clear jam.
Hope it helps.Thanks!
Mar 27, 2011 | Office Equipment & Supplies
Problem ir 5570
First check the settings in the paper cassette of the machine and make sure it is correct paper setting set for the tipe of paper.Check the paper detection sensors on top of the dadf and test -if you push them down they must return instandly.If the sensors take a while to return to home possition,the copier calculate a diffrend papersize.
It also help if you blow the dadf with compressed air.
Good luck
Jul 03, 2009 | Canon imageRUNNER 2270 Copier
19 people viewed this question
Top The Office Equipment & Supplies Experts
Gareth Cockram
Gareth Cockram
Tygh Duval
Tygh Duval
Jerry Greenberg
Jerry Greenberg
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
