Question about Dryers
My swimpure+ w/turbo cell #TU40,stopped working however power goes to the unit but no further, is there a fuse or circuit breaker type unit that would need to be replaced?
yalmer
  • 552 Answers
SOURCE: GE Monogram ZV750SY Kitchen Hood
http://www.appliance-parts-warehouse.com
first examine part #166 and related parts for visible damage.
If the circuit board is burned out, then the above website is a suggestion for ordering.
Posted on Jun 14, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: LG Microwave LMVM2055ST Just stopped working!
We have the service manual for this model and have uploaded it to our site here to help you.
You will need the
free Acrobat Reader to view or print it in case you don't have it.
It may be the fuse, which is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking TCOs or thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If the cavity thermostat needs to be checked or replaced you'll need to pull the oven from the wall.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
To order Goldstar / L.G. parts, visit Vance Baldwin Electronics. You'll probably have to call them.
Posted on Dec 13, 2008
  • 8 Answers
SOURCE: Power windows dont work
If all windows stopped workin at once it's a relay ... You can usually find them under your steering wheel ... You more than likely have to remove the panel under the steering wheel and you'll see them... I forgot which one it was but call a BMW dealership ... And let them know what relay you need...
Posted on Aug 24, 2009
SOURCE: 2002 F150 SuperCab Power Windows via 5A radio fuse. Wierd!
The location for the circuit breaker is in the fuse box under your hood number 601. Its a 30a CB.
Posted on Sep 07, 2009
  • 127 Answers
SOURCE: pass. side front and rear power windows stopped working
if they only stoped working on the passengers side I would check the wirring going into passengers side door for a broken wire, or right at the passengers side kick panel.
Posted on Nov 18, 2009
Boiling water in my GE Spacemaker Microwave it stopped working and looks as if it is at half power. When activated it makes a half power type noise and the light goes dim. Is this a fuse issue?
Probably not a house fuse. Typically good or bad!! Have you tried it in a totally different outlet?? Could be a bad connection of your circuit breaker to the bus bar in your circuit breaker panel. Try it on an outlet on a different breaker. Or have someone check the power at the outlet when it is running and see if the voltage is dropping.
Sep 13, 2017 | GE Microwave Ovens
Spa just stopped threw circuit breaker replaced fuse still no power
I assume you mean you replaced the Circuit Breaker...?
Spa Breakers are typically "GFI " types... they will trip if they sense power going to ground. Please confirm this.
Is this a self contained unit with a plug in Cord? Please confirm this.
Did you install this unit yourself... including the electric?
If you installed this yourself, then kill power, and disconnect the power from the spa and see if breaker still trips.
without knowing the size and ampacity of the system, I cannot instruct you to safely troubleshoot.
Self contained units with a 20 amp conventional plug... would not know unless we get specific "year-Make-Model"
Mar 25, 2017 | Pool & Spa
Dr Mercola Pure & Clear air purifier model# PC_AP2000. Unit stopped working, will not turn on. Cannot find a fuse in this unit. All else is in perfect working order. Thank you for your help.
The unit would be fused through the circuit breaker it gets power from in the main box of the house or in some cases a sub box to the main house circuit breaker box. If it is tripping the breaker something is seriously wrong and to reset over and over causes a fire risk, call a repair person.
Jan 24, 2017 | Heating & Cooling
Power windows
First check the power window fuse and relay.
The fuse is located in the underhood fuse box, it is maxi-fuse G (30A) {actually its' a 30A circuit breaker}. Make sure that power is getting to the circuit breaker using a testlight. Also check to see if power goes through the circuit breaker by checking its' other terminal while a partner operates (or attempts to) the power windows. If power goes in to the circuit breaker but does not come out, replace the circuit breaker. (some circuit breakers reset after a while, but I'm assuming you've have this problem for a while, so you're past the time it needs to reset)
Jul 08, 2014 | 1998 Ford Windstar
Swimpure chlorine generator not working
Did you figure this out ? I have the same problem.
Sep 03, 2012 | Hayward Industrial Products SwimPure Salt...
My cooler just stop after spark on the socket it was working fine now i change the wire but it dont turn on
check the fuse in the plug. check your fuse board also. a circuit breaker may have tripped down, or you may have blown a circuit fuse if its the really old type. plug in another electrical device to check.
May 21, 2012 | Refrigerators
06 DODGE STRATUS WINDOWS INOP, NO POWER TO FUSE OR CIRCUIT BREAKER
If no power to the fuse panel for that fuse and circuit breaker, you may have a maxi-fuse burnt out in the power distribution box by or near the battery. Check all your fuses under the hood.
Apr 05, 2012 | 2006 Dodge Stratus
If the power window circuit breaker goes bad , will all of the windows stop working,, on a 1997 grand am
YEP MAIN FUSE OR CIRCUIT BREAKER BLOWS IT WILL STOP POWER WINDOWS FROM WORKING.ALSO IF THE POWER WINDOW LOCK OUT SWITCH IS ON POSITION ON THE DRIVERS SIDE MASTER SWITCH THAT WILL ALSO STOP POWER WINDOWS FROM WORKING.
Oct 26, 2010 | 1997 Pontiac Grand Am
Oven has been working fine. Heating a cup of coffee it just stopped dead. No display. Nothing. Power to outlet working fine. Is there a reset somewhere?
Mine did this when my wife had it on full power for over 10 minutes. We left it set for 15 or so minutes and it came back on. It did the same thing when my niece was heating a liquid with some metal in it. It eventually came back on. There must be a thermal circuit breaker inside the unit. Yours may have a fuse or some sort of circuit breaker inside it, that needs replacing or resetting. Then again some units have a fuse that goes out when the Magnetron shorts out, or goes bad. This would require replacing the Magnetron as well as the fuse.
Sep 12, 2009 | Sharp R-326FS 1100 Watts Microwave Oven
1995 nissan quest GXE: Power seat belts stopped working.
the passive restraints control module is behind the panel by the gas pedal.
The fuse is a 30 amp fuse taht also controls power window. in battery box under hood in front of battery. chart on cover.
then it goes through left hand circuit breaker which is behind leftkick panel above fuse panel I think. there are 2 circuit breakers next to each other.
May 22, 2009 | 1995 Nissan Quest
Dryers Logo
19 people viewed this question
Top Dryers Experts
