Question about HP Office Equipment & Supplies
How to fix hp printer 4250 Error code 0x80070057
The Machine
  • 788 Answers
SOURCE: hp printer problems
Error codes starting with 13 usually indicate paper jams. Open all the doors on the printer and remove any removable modules and check for stuck paper.
Posted on Jan 11, 2008
  • 148 Answers
SOURCE: error 51.10 hp 4250 printer
This is what that code means.
51.1 Laser beam detect error
Clean laser beam reference mirror and associated components or replace laser assembly the laser reference mirror in located inside the laser housing.
You are probably going to need a tech to do this.
Hope that helps...
Posted on Jun 16, 2008
  • 22 Answers
SOURCE: hp 4250 error code 50.3
FALSE FUSER OVERTEMP INDICATION, POWER SUPPLY THAT DRIVES THE FUSING UNIT. MODEL 8150 DOES THE SAME THING. TRY TO GET A REFUND ON THE FUSER?
Posted on Jun 24, 2008
  • 22 Answers
SOURCE: HP 4350 downgraded to a HP 4250
Is this affecting performance? Try new firmware. www.hp.com/go/lj4350_software.
Posted on Jul 06, 2008
  • 489 Answers
SOURCE: `permanent storage full error` what does it mean????
The internal storage system is full. You need to run the HP Web Jetadmin software and delete unnecessary files from the EIO disk device. When done, press the select button on the printer to return it to a ready state. You should be able to print small jobs yet as long as it doesn't require any temporary (or permanent) storage on the EIO disk.
Posted on May 27, 2009
How to fix Error 60.02 for hp 4345
Britt Goes Raw! -- Stardate: 60.02 - YouTube
? 3:22
www.youtube.com/watch?v=zFxinPcg1bg
Nov 8, 2011 - Uploaded by VlogsOfSeven
Stardate: 60.02 ... HP LaserJet 4345 M4345 ADF (automatic document feeder) Cleaning ... How to fix HP Printer Error 13.20.00 in HP 4200 4250 4300 4350 Series Printer - Duration: 3:52. by ValstarPrinters 176,929 views.
Sep 08, 2015 | HP Office Equipment & Supplies
Error 0x80070057
problem your os please
Jul 25, 2014 | HP LaserJet 1320n Printer
Hp 4250 error code 55.4
error code 55.4 on HP Laserjet 4250:-The dc controller is not communicating with
the formatter. The problem could be caused
by a timing error or an intermittent
connection
Repair:-
switch off the unit - disconnect power cord
unsrew the two screws holding the formatter in place
( silver plate to rear right)
remove the plastic side panel by sliding
remove the formatter ( silver box you just unscrewed) by sliding toward the rear.
reinstall the Formatter
and re-test
more often than not just reconnecting the controller is enough to clear the problem. theres a good chance it has moved out of position as time has gone by.
Jan 22, 2013 | HP LaserJet 4250n Printer
Error 50.1 hp 4250 printer
This is a fuser error, it could be a faulty thermal sensor on the fuser but can also be caused by a faulty power supply.
This model commonly has dry joints in the power supply which can be fixed depending on your level of skill.
Mar 02, 2012 | Office Equipment & Supplies
Laserjet 4250 error 59.00
I've found this specific error code leads you to a main motor failure, Ive found some decent priced motors if you need them: HP 4250 Main Motor
Aug 30, 2011 | HP LaserJet 4250n Printer
My hp 4250 laserjet printer displays an printer error 57.4 message when i switch it on. what could be the problem? since it can not continue the printer checkup progress.
<P><A href="http://www.printertechs.com/tech/error-codes/error-codes-index.php">http://www.printertechs.com/tech/error-codes/error-codes-index.php</A></P><P>&nbsp;</P><P>Plz check the the link for the detail error codes.</P>
Aug 28, 2010 | HP 4250 Monochrome LaserJet Printer
59.40 error code
That's a main motor error, something could be jammed in transport, or a generic toner cart. that is too hard to turn, try powering on with toner removed...
Aug 20, 2009 | HP 4250 Monochrome LaserJet Printer
Error code 59.40 on laser jet 4250
Do you mean an HP 4250. If memory serves me right that error number refers to the main drive or cartridge drive. You may have broken the gear on the cartridge while installing it. Especially if your the type to slam it in there. It can happen with genuine and remans so don't go bemoaning reman cartridges...lol. Turn it off...put another cartridge in there...and see if if boots up. I work on printers for a living and had( I'm 95% sure ) that same error code a couple of weeks ago and fixed it for the customer over the phone this same way.
Mar 24, 2009 | Office Equipment & Supplies
Hp 4250 error code 50.3
Apr 15, 2008 | HP LaserJet 4350 Printer
Seeker5211
Seeker5211
