Question about HP Office Equipment & Supplies
Error code 0x80070057 hp printer 4250 - HP Office Equipment & Supplies
The Machine
  • 788 Answers
SOURCE: hp printer problems
Error codes starting with 13 usually indicate paper jams. Open all the doors on the printer and remove any removable modules and check for stuck paper.
Posted on Jan 11, 2008
  • 148 Answers
SOURCE: error 51.10 hp 4250 printer
This is what that code means.
51.1 Laser beam detect error
Clean laser beam reference mirror and associated components or replace laser assembly the laser reference mirror in located inside the laser housing.
You are probably going to need a tech to do this.
Hope that helps...
Posted on Jun 16, 2008
  • 22 Answers
SOURCE: hp 4250 error code 50.3
FALSE FUSER OVERTEMP INDICATION, POWER SUPPLY THAT DRIVES THE FUSING UNIT. MODEL 8150 DOES THE SAME THING. TRY TO GET A REFUND ON THE FUSER?
Posted on Jun 24, 2008
  • 22 Answers
SOURCE: HP 4350 downgraded to a HP 4250
Is this affecting performance? Try new firmware. www.hp.com/go/lj4350_software.
Posted on Jul 06, 2008
  • 489 Answers
SOURCE: `permanent storage full error` what does it mean????
The internal storage system is full. You need to run the HP Web Jetadmin software and delete unnecessary files from the EIO disk device. When done, press the select button on the printer to return it to a ready state. You should be able to print small jobs yet as long as it doesn't require any temporary (or permanent) storage on the EIO disk.
Posted on May 27, 2009
Model 4225 shows error code only
'Ink System Failure,' or a '0x...' - HP Customer Support
support.hp.com/us-en/document/c03081973
Example: "Laserjet P1102w driver" or "HP Pavilion 17-f002na will not turn on" ... For example, 'Error 0xc18a0001' or 'B8000094' might display on the printer ... The error code or message is not 'Problem with Printhead,' 'Printer Failure,' or 'Ink ...
[PDF]hp officejet 4200 series all-in-one user guide
www.hp.com/ctg/Manual/c00095626.pdf
Hewlett?Packarduse the attached handset (hp officejet 4250 series only) . . . . . . . . . . . .50 answer incoming calls ..... Help button that appears on some error messages and in the. Troubleshooting .... a call waiting (handset model only). 9. Photo Fit to Page: ...
HP Notebook PCs - Troubleshooting LED Blink Codes or ...
Dec 18, 2015 | HP Office Equipment & Supplies
Error 0x80070057
problem your os please
Jul 25, 2014 | HP LaserJet 1320n Printer
Hp 4250 error code 55.4
error code 55.4 on HP Laserjet 4250:-The dc controller is not communicating with
the formatter. The problem could be caused
by a timing error or an intermittent
connection
Repair:-
switch off the unit - disconnect power cord
unsrew the two screws holding the formatter in place
( silver plate to rear right)
remove the plastic side panel by sliding
remove the formatter ( silver box you just unscrewed) by sliding toward the rear.
reinstall the Formatter
and re-test
more often than not just reconnecting the controller is enough to clear the problem. theres a good chance it has moved out of position as time has gone by.
Jan 22, 2013 | HP LaserJet 4250n Printer
Laserjet 4250 error 59.00
I've found this specific error code leads you to a main motor failure, Ive found some decent priced motors if you need them: HP 4250 Main Motor
Aug 30, 2011 | HP LaserJet 4250n Printer
Hp printer 4250 is error 50.0
Fuser Error, Replace the Fuser (Part Number RM1-1082) In the rear behind the door very easy to do.
Dec 29, 2010 | HEWLETT-PACKARD Hewlett Packard 21A - HP...
I am getting 60.02 error on my HP laser jet 4250 printer
this error comes from tray 2 lifter assembly check the wires harness of motor sitted properly in dc controller pcb
Sep 21, 2010 | HP LaserJet 4250 Printer
My hp 4250 laserjet printer displays an printer error 57.4 message when i switch it on. what could be the problem? since it can not continue the printer checkup progress.
<P><A href="http://www.printertechs.com/tech/error-codes/error-codes-index.php">http://www.printertechs.com/tech/error-codes/error-codes-index.php</A></P><P>&nbsp;</P><P>Plz check the the link for the detail error codes.</P>
Aug 28, 2010 | HP 4250 Monochrome LaserJet Printer
59.40 error code
That's a main motor error, something could be jammed in transport, or a generic toner cart. that is too hard to turn, try powering on with toner removed...
Aug 20, 2009 | HP 4250 Monochrome LaserJet Printer
Hp 4250 error code 50.3
Apr 15, 2008 | HP LaserJet 4350 Printer
Hp printer problems
Jan 11, 2008 | HP Color LaserJet 2600n Printer
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
