Question about Troy Garden
My troy bilt TB330XP will start but stalls after about five minutes. I have replaced carb and fuel line and cleaned fuel tank. would appreciate any other suggestions. Thank you.
    New Friend:
  • 48 Answers
Changed the fuel filter? Make sure the fuel cut off is working? Did u change or clean carb? Change the plug?
Posted on May 15, 2017
  • 10865 Answers
SOURCE: Troy-Bilt Chipper Shredder won't start
It takes good gas, good spark, and good air for a gasoline engine to run well. The next thing I would do is put a new air filter in it.
Posted on Apr 23, 2009
  • 376 Answers
SOURCE: Need a fuel tank for a Troy Bilt mower
You won't find the fuel tank on MTD's site because it is part of the engine. MTD makes the mower, Briggs and Stratton makes the engine. Get the model and type number off the engine and search Briggs and Stratton's site or post it here and I will tell you the part #. Dwain
Posted on May 21, 2009
#1 Taper
  • 1041 Answers
SOURCE: wont start, not getting fuel, checked lines,carb and used starter fluid, runs but won't continue to run
You may need to do a more detailed cleaning on the carburetor. I like to use a Den Tek Brush, (used for cleaning teeth), to get into the small ports. They work great for this job. You may also need to check the small screen in carb. It gets blocked with debris.If you need further assistance, please contact me.
Jim
Posted on May 25, 2009
#1 Taper
  • 1041 Answers
SOURCE: Troy Bilt TB 465SS Pony 4 cycle weed trimmer won't start
Sounds like you need to take the carb. apart and clean it. I like to use a Den Tek Brush, (used for cleaning teeth), to clean the small ports in carb. they work great for this job. Make sure to either clean or replace the small screen in thcarb. as well.
Jim
Posted on May 26, 2009
#1 Taper
  • 1041 Answers
SOURCE: started stalling after last usage. then it would not start
When cleaning the carburetor make sure the small screen is free of debris. (Should be able to see daylight through it.) Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. These portals can become blocked and will keep the mower from running. Reassemble and start. Good luck!!
If you need further assistance, just let me know.
Jim
Posted on Jun 21, 2009
My Troy Bilt pressure washer has a good engine and runs fine without the sprayer. However, when I squeeze the sprayer the engine runs for about 4 minutes and then it stalls and dies.
indicates a problem with fuel supply
at idle just enough fuel is getting through but at full rpm there is a lack of fuel
remove the tap to the fuel tank , make sure it is not corroded inside, clean/replace any filters put about a cup full of methylated spirits in the fuel tank
That will break down any water in the fuel bowl and allow it to go through the combustion process
have the carby overhauled
Mar 19, 2018 | Troy-Bilt XP 3000 PSI 2.7 GPM Gas Pressure...
I have a Troy Bilt 3550 Generator and when i start it up it only runs for about a minute or so and then it shuts off. I checked for clogs replace spark plug and filter still shuts off. Please help
Odds are it's a fuel delivery problem.
Fuel check list??????
- Fresh fuel
- Clean carb
- Clean fuel filter
- Good fuel flow at carb
- No contaminates in fuel tank
Jul 27, 2015 | Troy Garden
Troy bilt generator
pull the carby down and clean out the corrosion blocking the main jet
Jun 07, 2017 | Electrical Supplies
I got a no start on a troy bilt 31cc leaf blower. I've replaced the carb, fuel lines, fuel filter and cleaned spark arrester. The spark plug is always dry as a bone so i know its not drawing fuel. Im at a...
See if you have spark to the plug, if not replace coil. You did everything else it should start, make sure start switch is to the on position. You replaced carb are the lines connected to the correct places and not kinked. Is your clunk clean. not much else to go wrong. Good Luck......
Sep 12, 2013 | Troy-Bilt Blower/Vac 31cc, 200 MPH, 405...
Troy-bilt 34322 343220110815 mower will not start
Dump out old gas. Fill with fresh gas. Always use Stabile in gas. Clean or replace park plug and air filter. Check oil level. All mowers have a low oil start cutoff. 30w oil. If any grey in oil moisture contaminated, dump out old oil and refill. Check fuel line for cracks or leaking. Check primer bulb for cracks, replace if required. Clean outside of carb with carb cleaner to ensure easy choke operation. Remove carb bowl from carb, ensure float hangs down freely. float down fuel flow, float up fuel flow stops. Check bowl screw for hole thru bolt, if so clean out hole.
Sep 11, 2012 | Troy Garden
Troy pony will not start without priming carb
sounds like the choke is not working I would clean the carb. as well as check the fuel line, tank and hoses for restrictions
Sep 04, 2012 | Troy-Bilt Garden
Troy Bilt Rear tine tiller model 643 Bronco, won't start,it ran out of gas, put in new gas and it started but wouldn't stay running. Put in new spark plugs, cleaned filters, changed out gas,still won't...
did it run out of gas when you added gas it could be that the fuel line has plugged up with something from the bottom of the tank take the fuel line off and try blowing threw it and take a air hose and blow out the carb and carb cleaner
Jun 05, 2010 | Troy-Bilt Pony Garden Tiller
How do I clean the fuel line on troy bilt 5hp chipper vac?
unscrew the nut on the bottom of the carburetor and remove the float bowl it must be emptied and cleaned , debree and water gets into the bowl and blocks of fuel flow reinstall the bowl and start, some carbs don't have a float bowl requiring you to remove the gas tank and carb which is a more involved cleaning.
Jul 14, 2009 | Troy Bilt 24b - 060f766 5hp Chipper...
Jim
May 24, 2009 | Troy Bilt Tb70ss Gas Trimmer
Apr 23, 2009 | Troy-BiltĀ® Briggs and Stratton Chipper
Garden Logo
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
