Question about Incase Computers & Internet
I have two tablets, that I need to have the same information on incase one should lose power as in flat battery.
I have tried to synchronize the two, but somehow I am doing something wrong as none of the settings correlates and the gmail account setup is even incorrect
dugiehowsa
  • 114 Answers
SOURCE: Do I need a battery to run the PC Tablet?
THe manual for your specific model can be found here: http://support.fujitsu-siemens.com/Manuals/ShowDescription_KMT.asp?DokuID=202607 Documents for othe models and languages can be found here: http://support.fujitsu-siemens.com/com/support/manuals.html
Posted on Sep 25, 2006
  • 35 Answers
SOURCE: Won't power up, flat line across screen - battery problem?
Yes, this sounds like you'll need to replace your back-up batteries. That will probably resolve the problem.
Posted on Aug 27, 2007
SOURCE: Iphone 3G Mail Account Set-up
can't send or recieve on the iphone
Posted on Jul 16, 2008
Bajanguru
  • 7752 Answers
SOURCE: deactivate call barring
the default is 0000
if not then take it toa mobile store/shop to have the code reset
Posted on Aug 21, 2008
krohiti
  • 78 Answers
SOURCE: Mozilla Thunderbird setup
    Google Gmail Outgoing Mail Server (SMTP): smtp.gmail.com
    The Gmail SMTP server requires authentication (use the same settings as for the incoming mail server)
    The Google Gmail SMTP Server requires an encrypted connection (SSL) on port 465.
    GMail uses POP3 over an SSL connection, so make sure your email client supports encrypted SSL connections.
      Google Gmail Incoming Mail Server (POP3) - pop.gmail.com (SSL enabled, port 995)Outgoing Mail Server - use the SMTP mail server address provided by your local ISP or smtp.gmail.com (SSL enabled, port 465)
Posted on Sep 25, 2008
Why doesn't my tablet turn on?
If your tablet will not power on, try holding the Power Button and the Volume Down button at the same time for 10+ seconds and it should boot up.
Feb 16, 2016 | Tablets & eReaders
Kobo won't turn on, screen blank
This can happen if the battery is very, very flat. Try charging it overnight.
If charging it doesn't help, try using a paper clip in the reset hole to force a factory reset (you may lose any user-installed books).
Mar 01, 2015 | Kobo Glo E-Reader
Received an Irulu tablet for Christmas have no idea where it was bought and need to know warranty information
All of the paperwork should have been included in the box it came in. There is also a way to find out where it was purchased by going straight to the manufacturers website and talking with someone.
Simply could ask the person who bought the gift for a "gift recepit" that way you can prove it was bought not stolen, and get the warrante online.
Good Luck
Jan 08, 2015 | Irulu 7" 4gb Mid Google Android 2.3...
My apple ipad is not reponding when iam charging it how do i reset it
If you charge your iPad on a power adapter, the iPad should respond while charging, except if your iPad battery is so low the apps need more power to run.
If you charge your iPad on the USB port of your computer, it is normal you cannot use your apps as the iPad is not only in battery charging mode but also in synchronizing mode with iTunes in the computer. You should lose the habit to charge the iPad on the PC and use a dedicated power adapter instead, as dedicated power adapters charge the iPad battery 2 to 4 times faster than the USB port of most computers.
USB port power: 2.5 Watts in general (5 volt x 0.5 A = 2.5 Watts)
iPhone charger: 5 watts
iPad charger: 10 or 12 watts
Jul 26, 2014 | Apple iPad 32 GB WiFi Tablet PC
Cant get my samsung tablet to turn on
Your tablet's battery is probably dead. This may be because you have a bad battery, a bad charger, or a bad charging cable. Try using a different cable first and let it charge for a few hours - even if it doesn't look like it is charging.
If the new cable doesn't do it, try using a different charger. Samsung devices are picky about what charger you use, so try to use one made for your tablet. If you don't have another charger, plug it into a PC's USB port with the PC turned on. Leave them on and plugged in over night. That should trickle charge your tablet.
If neither of those work, try holding down the power and the Volume Up buttons. Keep them both pressed until the Samsung logo/boot screen comes up - should only be a couple seconds. Once the logo comes up release the power button but keep holding the Volume Up button. That will boot you into Recovery Mode. If that comes up, it means you've got power and your tablet isn't broken, but there is something wrong with the Android OS that is keeping your tablet from powering up normally. Use the Volume Up and Down buttons to move the selection highlight to the Factory Reset option. This will wipe all the info off your tablet and put it back into a "brand new just out of the box" state. You'll lose your information on the tablet, but this should fix the boot problem. Press the power button to chose the Factory Reset option. It will take a few minutes. Once it says that it is done, select the Reboot or Restart option. It should reboot. This boot will take longer than normal, since its wiping things out. But not more than a few minutes.
Jan 02, 2014 | Samsung Galaxy Tab Tablet PC
What do i do
My tablet has done this before. Honestly i just let it die out of battery and then recharged it totally before turning on. Then i set it to factory re-set just incase of any bugs in it. Hope this helps.
May 12, 2013 | Nextbook Next3 tablet
Losing time settings
When it lose time settings? When you gets connected with internet or power off your PC?
If it is case of power off your PC, then it's all about your CMOS battery of your motherboard. It looks like a small button type battery. Generally it supplies power to PC clock when your PC is turned off or power off. BIOS settings also gets power form this battery. You have to change it if this is the reason. It takes little price.
To change CMOS battery please read:
http://www.computerhope.com/issues/ch000239.htm
If it happens in case of When connected with Internet, It changes date and time automatically if internet time zone selected with "automatically synchronize with an Internet time server".
To deactivate it like windows xp ( go to control panel, select date and time properties, select Internet Time tab and unmarked "Automatically synchronize with an internet time server" check box.
Click apply and ok to save changes. Now your date and time will not be changed.
Jun 25, 2012 | Lenovo ThinkCentre Computers & Internet
Iam unable to turn it on, any help would be great
does the light come on when you plug in a charger? if so try turn it on with the charger in and on. and hold the power button for at least 5 seconds, if theres a light to indicate charge then theres power to it but could be some other fault internally, you have to try the tablet with the charger in and hold the power button for 5 seconds and you can leave the charger plugged in for an hour to see if it says charging just incase its a bad battery.
Oct 16, 2011 | Coby Kyros Internet Touchscreen Tablet...
I have a nextbook next6 tablet. it comes up with an error reading android.process.acore. all the time. can you help me.
This Android OS acore error seems to lie within contacts synchronization going wrong.
Because of that we need to clear all contacts (and restore them). This is how to do it:
Step 1 - clearing all contacts information
1.First of all, make a backup of all your contacts. You can do this easily by downloading ExportContacts from Market, fire up the app and export contacts to a csv file on your phone memory card. To be sure, copy the csv file to your hard drive too.
2.Then go to Menu -> Settings -> Data synchronization and turn of all synchronization.
3.Go to Settings -> Applications and tap Manage Applications. The list of applications will now take a while to load. When it's finished, find Contacts Storage, tap Clear data and tap Clear cache.
Note: all your contacts information will now be wiped out - but you're safe - you've already exported the contacts.
4.Turn on synchronization again (Menu -> Settings -> Data synchronization).
Step 2 - restore contacts information
Now we just need to restore the contacts information, which is saved in the csv file we created before. We will do this by importing the csv file to Gmail and let Gmail synchronize with the Android phone.
Note: You can import csv files to almost any email program or service, preferably Outlook or Gmail.
1.Login to your Gmail account -> Go to Contacts -> Click Import (top right corner).
2.Click Choose File -> Choose your csv file -> Click Import.
3.Done!
Now it might take a short while (a minute or so) for the phone to synchronize your Gmail contacts.
When the synchronization is finished you've got your contacts in Gmail and in the phone.
Shut for tablet down for 30 seconds. Boot it back up.
Sep 06, 2011 | Computers & Internet
Every time I turn it on, I have to reset all setting, It will not save setting after it is turned off. I.E clock, and date: some times wireless settings depending on how long it was off. Cmos batterie?
YES. The CMOS battery (complementary metal-oxide semiconductor) is low off charge or dead and needs to be replaced.
The CMOS typically is a battery-powered memory chip in your device that saves information needed at start up (before any software or program will run). If the battery is low of charge or is dead, you will eventually lose your personal settings and even some factory settings. The CMOS battery can be discharged if you have not used your device for long time.
Hope this helps.
Jun 25, 2011 | Sharper Image Literati Reader 16375680042...
Computers & Internet Logo
24 people viewed this question
Top Incase Computers & Internet Experts
David Payne
David Payne
Are you an Incase Computer and Internet Expert? Answer questions, earn points and help others
