Question about Dryers
Can i use my PF to by a house while am still working?
When washer starting to spin it faults out with code pf. Then washer just powers down. What does this mean?
Hello!
Code PF means that a power failure occurred on the control board during the program run.
In most cases, the reason for the code PF on the display is not in the washing machine, but in the problems of electricity supply of your house or apartment.Turning off the electricity or a power surge most often results in this error.
May 18, 2017 | Washing Machines
Oven has a PF by time what is that for
PF is telling you that there was either a power failure (utility) or there is a problem with power coming to the unit from the house wiring. (Circuit Breaker) If you have a stop /pause /cancel button press it and then set the clock again. If the problem persists, just reply here and I will help you.
Kelly
Sep 21, 2010 | Kenmore 95002 / 95004 Electric Kitchen...
Kenmore Elite Oasis 110.67087600 Dryer will not power up. No power at all. Prior to this it had a PF flashing. House power checked good.
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle.
Press and HOLD start to continue the cycle, or press off/pause to clear display.
If no-go.. the timer is failed due to a power spike and must be replaced.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 26, 2010 | Kenmore Elite Oasis 6808 Electric Dryer
I have a Whirlpool Duet sport dryer that came with the house I bought a year ago so I have no manual. What does it mean when the display says PF? Clothes were dry but display waid PF
The only PF I am aware of means power failure. Try unplugging the unit for awhile then try it again. This may reset the computer.
Feb 14, 2010 | Whirlpool Dryers
Line fuse rating?
usually fuses have voltage and current ratings mark on them you just have to look for it or sometimes near the fuse housing.or you can use the formula power consumption of the unit divided by the voltage rating of the unit. I (amp) = Power(watts) divided by Voltage(110V) X power factor(PF). use 0.866 for PF
Feb 02, 2010 | KLH Audio Players & Recorders
I have a solis crema sl-70 whose portafilter leaks and actually flies off if I don't hold it in place as I pull a shot. Is this is small repair problem, or should I replace my machine?
You may just need a new grouphead gasket. This is a rubber ring that fits in the space between the outside of the grouphead and the interior area that houses the dispersion screen. If it's worn or dried out, the pf may not be sealing properly (which would cause the leaking and instability)
The portafilter (pf) handle should line up with a pre-printed indicator line on the group head when it's "locked" in. If you're looking at the machine straight on, and the far side is "12" on a clock face, the handle should be at 6 or 5 o' clock. The pf should "ease" in to the grouphead, not stop with a hard feeling.
The problem might be with the portafilter "ears", or the metal tines that wedge into the grouphead. If they're excessively worn, the pf might not be secured snugly enough to make a seal. A new pf will solve this.
So, first, try a new gasket. Then a new portafilter. Then a new machine :)
Dec 15, 2009 | Solis Crema SL-70 Espresso Machine
When I plug the machine in it either does nothing or flashes PF then acts as if there is no power. It is the machine not the outlet.
PF just means your house has experienced a power failure since you last used the machine.
Unplug it for 40 minutes to reset.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
May 03, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Neptune washer show PF and clicks off, door unlocks, and won't restart. House power is fine and the dryer works.
PF = Power Failure.
Unplug for 40 minutes to reset the ECU.
Jan 11, 2009 | Washing Machines
Dryers Logo
21 people viewed this question
Top Dryers Experts
