Question about Champion Garden
I have a problem with my Champion mower CR534WSPB the pull cord needs replacement. Do you have a diagram showing how to change it.?
    Top Expert:
  • Champion Master
  • 40,418 Answers
Check YouTube for something similar or contact Champion directly to request the diagram.
Posted on May 15, 2017
Rewind starter cord
How To: Rewind a Recoil Rope (Fix a Broken ... - YouTube
? 2:52
Feb 16, 2012 - Uploaded by Champion Power Equipment
How To: Rewind a Recoil Rope (Fix a Broken Recoil Rope) .... Back off until rope hole in pulley lines up ...
How to Repair a Small Engine Recoil Starter - YouTube
? 4:49
Jul 15, 2011 - Uploaded by
How to Repair a Small Engine Recoil Starter ... Would like to now use the pull cord on the mower but it won ...
Nov 28, 2015 | Garden
Belt route diagram for simplicity champion xt 48"
Goggle it. belt diagram simplicity champion xt 48
Sep 04, 2014 | Garden
How to change the pull reel
Just click on the link below and it will have videos that will show you how to change the pull reel. Good Luck and I hope this helps you out. : > )
How to replace a lawnmower pull cord - YouTube
Jul 24, 2014 | Toro Super Recycler 21" 159cc Personal...
How do i replace the coil on my sears craftsman power gear drive push mower?
Go to you tube. On the line type in how to repair lawnmower pull cord
Jun 27, 2014 | Briggs & Stratton Briggs Stratton...
Replace pull cord
Go o you tube on line, how to replace pull cord mower
May 24, 2014 | Champion International Champion& Small...
I own a champion 35 petrol mower that starts first pull but seems to be searching for revs when running , don't know if I have some how set the two springs up wrong (the ones at side of carb) as I...
Hi its called "hunting" and is caused by a fuel block in the main jet of the carby. Pull the carby down and blow out all jets with compressed air. regards Phil.
May 30, 2012 | Briggs & Stratton Garden
Have 2 problems with my 2006 Toro lawn mower model 20070. I have used a total of 15 times and don't understand how it could fail with so little usage? 1) The engine will start with the cord but not...
The starter gears engage the bottom of the flywheel when starting the mower with the electric start if you can see that some of the teeth on the flywheel are stripped , you definitely need a new flywheel, parts diagram shows that it has a 'plastic ring' gear on the flywheel and doesn't show that the part is available seperate. Below is a picture of the assembly. About the running condition of the mower, I would start by removing the carburetor and cleaning it, get a common twist tie and remove the outer paper so you have a bare wire, use that wire to clean out the small hole in 'brass bowl nut' located on the bottom of the carburetor, then dry out with compressed air. The diagram below also shows the carburetor.
Sep 24, 2011 | Garden
Model #911503 ,serial #000278 The pull
Here a couple of links with instructions on replacing your rope... Text Good Luck
Jul 03, 2011 | Ariens 21 In Classic Walk Behind Push Lawn...
the recoil dawgs in the cover housing are either shot or not engaging into the top starter cone
Apr 14, 2010 | Garden
Oil coming out of my champion lawnmore r484
you likely will need a new air filter and a carb cleaning. when mowers are turned on their side. oil will seep past the piston and if your intake valve was open it can pass thru into the carb and also spoil your air filter. I am assumeing you have a paper air filter. start by taking off your air filter. then you should also pull the spark plug, place a rag covering the hole. then pull the cord a couple times. chances are that you will blow the oil out of the cylinder. I would recommend a oil change.
Apr 08, 2009 | Garden
Garden Logo
27 people viewed this question
Top Champion Garden Experts
Lawrence Oravetz
Vernon Taylor
john h
Are you a Champion Garden Expert? Answer questions, earn points and help others
