Unable to change setting from cable to tv. - Televison & Video
We went from cable tv to a dish. which changed our internet service. I am unable to change the service on our Hisense TV
You have to reset the set electronics to erase all prior settings. Look for reset button on unit or contact Hsense. Also, in the settings area for internet there may be an area for a totally new network.
Sep 22, 2017 | Hisense Televison & Video
My tv remote is not working inasmuch as I am unable to change channels. Tv is on BBC 1 and that is all I can watch
You go buy a universal remote and test your patience by typing in each of several codes for you TV until you find one that works. Some TV sets or attached boxes allow cable changing manually. Others do not.
But before you do that, make sure you have pressed either CABLE or TV at the top of your remote. You possibly have accidently pressed a button to control the DVD or some accessory device, rendering the remote unable to control the TV.
I might try to "autotune" the TV, i. e. preset the setup menu that causes it to search for the channels which the TV can receive. Something possibly may have happened in that realm.
And, you might even call your cable provider and ask them to reset your cable connection. You see, the problem might not be in the TV or the remote.
Good luck.
Aug 08, 2017 | Televison & Video
I have started setup for hd cable. Am connected to hdmi and have picture and sound but am unable to change channels. What do I need to do.
With the HDTV set for an HDMI Input that matches the HDMI Jack that you've connected to the cable HD STB (set-top-box or "converter"), use the cable STB remote to change channels on the STB - not the TV.
You can not change channels of the STB with your TV remote. You may however, be able to program your STB remote to operate your TV. Most will allow you to power the TV on / off; volume up / down / mute; change input (HDMI1 / HDMI2 / ANT / Composite / etc.) and even some of the more complex functions as well. Contact your cable company for more details.
Feb 25, 2016 | Sylvania Televison & Video
Hi! My mother gave me an Insignia HDMI TV, and I can't figure out how to hook either my Wii console or Sony DVD player to the TV. I transfered all of the audio/visual cables from the old TV to the new TV...
Hey there!
Is there a button on the set or remote that says "input" or "source"? That will change the input settings from cable, to HDMI or RCA (aux).
Mar 08, 2011 | Televison & Video
Unable to view TV programming on TV, able to utilize set for viewing DVD/VCR movies. Cable company says their Cable Card is 'OK' and the TV needs updates (assume software) in order to work correctly with...
U get a channel numder and menu screen do show up?Not the tv,it the incomming broadcasting signal cable plug in or the cable box itself have problems.Tries unplug,replug the tv and the cable box back in like about an hour later.The tv will reset itself to the factory setting and the cable box should upgraded it softwares.Should work now.If have the same problems,tell the cable company change the cable box or check the incomming broadcasting cable wire with another tv,see the incomming broadcasting signal cable wire,with a new cable box,see if it work.
Oct 21, 2010 | Toshiba 46HM95 46" HDTV
How do you change picture size without the remote control
I have a 47 inch Toshiba lcd tv. I lost my remote control and am unable to change the picture size on the screen. Is there a way to change the hd settings from 480i to higher definition through my digital cable box?
Feb 28, 2010 | Toshiba 37WLT58 37 in. LCD TV
Unable to to get cable channels in modulator. Set to cable, channels 73/75 but "connection" grayed out. Cable signal strong. Able to read Digital channels on Local set up with same i/p.
The connection button is not utilized from the "Modulator Setup" screen. When changing the channel for TV 2, you can arrow over to either air or cable and pressing select. This will select that option and change the channel to either 60 for air or 73 for cable. Once this selection is made then you would move to the "Done" button and press select. You will return to the "Installation" menu, then cancel out till you are back to the TV screen. I hope this helps.
Ray Calo
DISH Network
Dec 16, 2009 | DISH Network ViP622 DVR DTV Receiver /...
Unable to connect dell precision m50 to tv monitor
Go to Control Panel - Display - Settings - Advance - Monitor Tab change Monitor Type to Generic Television click Apply
Apr 10, 2009 | Dell Precision M50 Notebook
Acer aspire 4315 connect to TV problem
you should be able to right click on an empty space on your desktop and choose graphics properties and then the output option should be able to be set and the resolution changed if needed, set your tv for AV3 or s video and connect a seperate audio cable as s video is video only
Sep 10, 2008 | Acer Aspire 5050-3242 Notebook
Tuning problem
Your TV is set to Antenna. You need to go into the menu and change it to Cable. Then do an autoprogram.
Jan 30, 2008 | Symphonic ST419E TV
Televison & Video Logo
Top Televison & Video Experts
