Question about Astec Computers & Internet
Hope wiring a astec - Astec Computers & Internet
How to hotwire a 2004 astec
Gidget,, please do not "hot wire" this vehicle.. if you lost your keys.. go to the dealer or call a locksmith,, you will have more issues later if you hot wire it...
May 15, 2017 | 2004 Pontiac Aztek
Would anybody have an Installation Manual for Astec alarm panel.
Feb 11, 2013 | Vehicle Parts & Accessories
Ref ASTEC power supply from old computer model SA 147-3505 I can pick up the logic 5 volts but not the +12 volts and -12 volts .FAN not energised so I guess there needs to be an elec link via the computer...
You can jumper on an ATX power supply by using a wire to connect pin 4 (green wire) to any of the grounds on the 20 pin ATX connector. The grounds are normally a black wire. You will need to put some sort of load on the power supply such as a hard drive to keep it running.
Feb 25, 2011 | Dell PWR,SUPPLY,145 WATTS,ASTEC SA150-3411...
I am looking for a product data sheet and/or manual for the Astec SS500-3405 power supply. Might you be able to assist? Thanks,Tony.
The three I have inspected, all of them failed due to the vent. It breaks down and makes the power supply to stop.
Jan 04, 2011 | Astec Computers & Internet
My astec atx202-3515 power supply blew up. I accidently changed the watt to 115. It was 230 watts before. Will the power supply still work oe will I need to purchase a new one?
just flip it back to 115v hook it up and see if it works. if itdoesnt work replace it . I did that once it was fine the comp didnt turn on til i turned it back 115v
Mar 09, 2010 | Astec (ATX202-3555) (ATX2023555) 200-Watt...
Got a astec sa302-3505 power supply . . . need to know how do you add a switch to turn it on if its not connected to the motherboard
Simple, Just connect a switch to Green wire and one of black wire.
When the green wire got connected with negative (Black wires are negative) the SMPS Fan starts which is also a visual feedback to you that SMPS starts.
----------------------O /
Grean /
So simple..
Jan 26, 2010 | Astec 300w AT Power supply 190170-01...
I need an ASTEC power supply model SA147-3506 for IBM P-2 computer, Can anybody help me??!!
145 Watt power supply with the old style AT motherboard power cable connectors. (2 Each)
I just put Astec SA147-3506 in my browser search bar, and came up with a number of search hits. Prices ranged from $50 to $170!
And it's a 145 Watt power supply! Astec is a cheap quality power supply manufacturer, to boot!
You know, there is a way to use a newer reliable power supply, and the AT power supply motherboard connectors, off of the power supply you have.
It's not for the squeamish, but can be done.
The power wires are removed from the ATX power supply motherboard cable connector, of the new power supply, and inserted into the AT power supply connectors.
(ATX 12V power supply is the newer one. AT power wires removed from the P8, and P9 connectors of your old power supply)
Jan 20, 2010 | Computers & Internet
Hello, i have a Astec 110s central vac that shut down today.
That means that either the motor or the relay is bad.
Dec 04, 2009 | Vacuums
I am looking for a manual and troubleshooting manual for a astec 73-180-0029 POWER SUPPLY
Look it up on the internet you should be able to find one. Try the website first.
Nov 19, 2009 | Astec Computers & Internet
Computers & Internet Logo
23 people viewed this question
Top Astec Computers & Internet Experts
David Payne
David Payne
Are you an Astec Computer and Internet Expert? Answer questions, earn points and help others
