Question about Sony CDX-GT310 CD Player
Player has been working fine for about a year. Now, it turns off and comes back on periodically. At times it will turn off and loose all previously programmed settings.
Not enough power to the cd player. maybe you need a new alternator for the car
Posted on Jan 27, 2010
  • 9 Answers
If its loosing all memory settings then the constant voltage supply is faulty (yellow wire on rear of player) try tracing it back to the fuse box checking for bad connections
john
Posted on Aug 06, 2009
Vaillant boiler leaking only when heating switched off.
It would seem a joint has come a bit loose from the heating and cooling cycle. put a drip pan under the leaking area( the drips would evaporate quickly), then next time you shut it down go through all the joints in the area with wrenches to find the loose joint.
Oct 27, 2014 | Water Heaters
Hitachi 28LD5200E will not turn on after long periods of time
There are various reasons for this. Moisture inside the TV, dry solder on boards, dry/leaky capacitors on the board etc. Try changing the power outlet and ensure that it is giving out the voltage required. If nothing works, better refer it to a qualified service technician.
Jul 18, 2012 | Hitachi 28LD5200 28 in. HDTV-Ready LCD...
NAD C326BEE amp problem. Connected to recommended Wharfdale speakers and NAD CD player and previously working fine for a year. Now red light flashing on amp and no sound when system is turned on.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for ntermittent shutdown.
http://nadelectronics.com/products/hifi-amplifiers/C-326BEE-Stereo-Integrated-Amplifier
Page 6 and 13
May 27, 2011 | NAD C326BEE Amplifier
I have a ten year old 37" Sony XBR TV that works fine until you turn it off and then go to turn it back on. The picture does not come back, but sound does. The only way to solve this is leave it off...
most likely it needs repiars, (replacement of capacitors in the power-supply.)primary and secondary side.
Or loose conections (dry joints)
Apr 20, 2011 | Sony KV-27V22 TV
My cd player turns off and then on randomly
this specific model alpine was famous for that pull the radio out and check the red yellow and black wire were they go into the harness on the back of the radio sometimes the pins in the harness loosen up
Feb 27, 2010 | Alpine CDA-9811 CD Player
No power to ACT car video
Those player are very low price and quility, about $25 each. I would go with an indash touchscreen unit from Pioneer or Kenwood and send signal to the flipdown screen.
Mar 08, 2008 | Car Audio & Video
How to unfreeze mp3 player
We have a toshiba gigabeat f20. today it worked fine, listened to it for hoursbefore turning it off. turned it on within a hour to play it and got a blank screen. nothing in the environment could have caused this. battery had been replaced a week before. so, took the case off to opened it and take a look. realized that one of the plug ins for the screen had come loose or slightly lifted inside. it did not totally unplug, just not pressed down tight. pushed it back in. put the case back on. hit the power button and it's back on, nothing that had been previously loaded was lost.
Nov 13, 2007 | Audio Players & Recorders
Screen shuts off
my screen will turn on right after unit is plugged in and stay on for a short period of time, then it shuts off and the red light near the power button blinks and teh tv will not turn back on. there might be problem of loose contact in power supply Thanks
Sep 11, 2007 | Toshiba 32AFX61 32" TV
Oven touchpad doesn't work
sometimes it may just be a build up grease and dirt on the pad over a period of time.try taking it apart as much as possible and cleaning it with some type of spirits and the clean with some eucalyptus oil as both of these have capabilities of breaking down oils and fat.
Jul 15, 2007 | GE JBP90 Electric Kitchen Range
Sony CDX-GT310 CD Player Logo
124 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
