Question about The Office Equipment & Supplies
I have matric only... i want to do project management wants the minimum requirement?
Where do i go to restore my lost matric certificate
Certification Services - Department of Basic Education
www.education.gov.za/Informationfor/CertificationServices.aspx
  1. Cached
A change to an original certificate will not be considered unless the original certificate (not replacement) is returned. To change your name on your matric ...
Replace matric certificate ' South African Government
www.gov.za/node/727532
  1. Cached
  2. Similar
Apply for replacement of your matric certificate at the Department of Basic Education if you have lost or damaged your original matric certificate. You can request ...
Career Planet ยป Where can I get a replacement matric certificate?
www.careerplanet.co.za/where-can-i-get-a-replacement-matric-certificate
  1. Cached
  2. Similar
I lost my matric certificate. I damaged my matric ... Replacement (re-issue) matric certificate? I need a new ... (2) I damaged my matric certificate! What must I do?
Youth Village How To Recover A Lost Or Damaged Matric Certificate ...
www.youthvillage.co.za/.../heres-how-to-recover-your-matric-certificate-after-losing-i...
  1. Cached
Nov 26, 2015 - Please note: Applying for your lost or damaged matric certificate might differ from one province to another. Below is a guide to applying for ... restore my lost matric certificate Google Search
Jan 04, 2017 | Office Equipment & Supplies
I can't remember my matric examination number, can you help me please?
sadly we have no way of getting that information here on FIXYA
Jan 03, 2017 | Office Equipment & Supplies
How to write a letterhead to apply for an internship?
Normally a letterhead is a professionally printed blank sheet of paper with your name/address/logo/etc. pre-printed on the top. You could design your own letterhead using a word processing program to print as a header on your application letter. It seems pretty unusual to require a letterhead, especially for an internship. Perhaps they mean a letterhead from your university?
Aug 30, 2016 | Miscellaneous
What do you have to do to become a Wiz in FixYa? I am new and have put in 41 solutions but am still at Master status. When will I be a Wiz and how long until I am a premium expert?
Rank Average Rating Minimum Number of
Solutions Posted guru.gif Guru 85% or higher, 5 votes minimum. 50 wizard.gif Wiz 80% or higher, 5 votes minimum. 30 master.gif Master No Ratings Required 10 expert.gif Guide No Ratings Required 5 nonexpert.gif Apprentice No Ratings Required Rank Average Rating Minimum Number of
Solutions Posted guru.gif Guru 85% or higher, 5 votes minimum. 50 wizard.gif Wiz 80% or higher, 5 votes minimum. 30 master.gif Master No Ratings Required 10 expert.gif Guide No Ratings Required 5 nonexpert.gif Apprentice No Ratings Required You need to visit the Expert FAQ's section to get answers to this, link is http://www.fixya.com/FAQexp.aspx
but here is an extract:
Ranks are calculated by dividing the total value of the ratings cast on an Expert's Solutions by the Expert's number of rated Solutions. Unrated Solutions, Premium ratings, and Live Chat ratings are not factored into Experts' averages.
Wizz needs 80% or higher ranking, 5 votes minumum and 30 solutions minimum.
The help screens are good so just have a look around and you'll find out lots.
Aug 22, 2011 | FixYa Service
Is there Liebert NFORM software for normal PC windows 7? and if there please send me A demo .
Liebert ® Nform Software
GUIDE SPECIFICATIONS
1.0 GENERAL
1.2 SYSTEM REQUIREMENTS
A. All material and equipment used shall be standard components, regularly manufactured and available and not custom-designed especially for this project. All systems and components shall have previously been thoroughly tested and proven in actual use prior to installation on this project.
B. The manufacturer will furnish or supply a site-specific Critical Infrastructure Management software system based on customer requirements. The system must be a software-only solution; no substitutions will be accepted.
C. The system architecture shall consist of network interface cards that will be installed in all critical infrastructures that at a minimum support HTTP and SNMP simultaneously.
D. The system shall receive SNMP traps from managed equipment and display the alarm notification in a graphical user interface.
E. The system shall be based on SNMP Open Protocols and integrate seamlessly with Emerson Network Power, Aperture® software suite and Network Management Systems.
F. Open protocol support shall include:
· HTTP(s)
· TCP/IP/v4, TCP/IP/v6
· SNMP v.1, SNMP v.2
G. The system will have the capability of being remotely monitored and managed 24 hours a day, 7 days a week by the manufacturer.
H. The system shall have the ability to be deployed world-wide.
I. The system shall operate as a client-to-server application.
J. The Web interface of each managed device shall integrate directly into the system.
K. The system shall support Enterprise level databases including Microsoft SQL.
L. The system shall support exporting of all recorded parametric trend data.
M. The system shall operate on a server defined by the customer. Specific server brand or function is not permissible.
N. The system shall support virtual server environments by default.
O. The system shall include at no additional cost one (1) year of Software Assurance.
May 09, 2011 | Liebert OpenComms Nform for PC
I can't get football manager 2010 to run on my acer aspire one netbook. is there anyway of getin it to work
Check the minimum requirements listed on the game box. Many laptops, especially those that are older, do not have the minimum requirement. Also, download the latest DirectX package - it is used by most games to 'bridge' to the display driver.
Mar 11, 2010 | Acer Computers & Internet
I cant install the software that comes with the product. should i download something else online? Sorry, im new with recordings.
Make sure you have Administrative privileges to install software, in the User account settings. you can download Ableton live lite here. I always used Fruity Loops to record, it takes a little time to understand how the software works but it's really intricate, great software to record music and you should be able to use this hardware with it.
Here are system requirements:
Compatibility
ASIO 2
MME
Sound Manager
DirectX
Mac OS X Core Audio / Core MIDI
Minimum System Requirements (PC)
Windows 98SE / Me / 2000 (SP4) / XP (SP2)*
Pentium II 350 w/ 64MB RAM
* Home and Professional Edition only. Windows Media Center Edition is not supported.
** M-Audio suggests you also check the minimum system requirements for your software, as they may be greater than the above.
Minimum System Requirements (Mac)
G3* 300MHz/G4* 350MHz
OS 9.2.2, 64MB RAM;
OS X 10.2.6, 10.3.6, 10.4, 10.5.1 w/ 128MB RAM**
* native USB port required; G3/G4 accelerator cards not supported
Jan 02, 2010 | M-Audio Mobilepre USB Bus-Powered Preamp...
Football manager 2009
Your graphics might be incompatible.use a higher graphic card.also check the RAM .if the RAM i slow games wont work.check the minimum requirements of the game and check if the system meets them .
Jul 06, 2009 | Sega Football Manager for Windows
Some thing about good project...?
  1. Project managers must focus on three dimensions of project success. time, within budget, and to a level of quality that is acceptable to sponsors and stakeholders.
  2. Planning is everything -- and ongoing.
  3. Project managers must feel, and transmit to their team members, a sense of urgency.
  4. Successful projects use a time-tested, proven project life cycle.
  5. All project deliverables and all project activities must be visualized and communicated in vivid detail.
  6. Deliverables must evolve gradually, in successive approximations.
  7. Projects require clear approvals and sign-off by sponsors.
  8. Project success is correlated with thorough analyses of the need for project deliverables.
  9. Project managers must fight for time to do things right. Project manager responsibility must be matched by equivalent authority.
  10. Project sponsors and stakeholders must be active participants, not passive customers.
  11. Projects typically must be sold, and resold.
  12. Project managers should acquire the best people they can and then do whatever it takes to keep the garbage out of their way.
  13. Top management must actively set priorities.
Jan 27, 2009 | Microsoft Windows XP Professional
20 people viewed this question
Top The Office Equipment & Supplies Experts
James Cagle
James Cagle
Gareth Cockram
Gareth Cockram
Peter March
Peter March
Level 1 Expert
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
