Question about Dometic Rooftop RV Air Conditioner
Air conditioner fan comes on then surges for compressor and stops
The fan comes and fine and when the compressor trys to kick start it surges and clicks off the compressor start up with fan still blowing. Is there a way to check if compressor is shorted out or something with a volt meter. I have check it my self with no reading which means to me that the compressor is still good. Anybody have any shortcuts to recommend.
  • 4 Answers
Comressors cycling on and off is usually a sign of a low refrigerant charge, which likely means you have a leak in the system. there is no such thing as a perfect compressor seal so you may just need to charge it up.
Posted on Jul 26, 2009
  • 356 Answers
You can check if theres power to the compresor by pulling the wires off it and turn it on with the volt meter at its terminals if there's power the comprresor is either burned out jamed or grounded.
What causes compressor to work fine then shut down and not come back on for an extended amount of time?
Sometimes these AC's need to be removed and given a damm good cleaning with a spray hose, and any filters replaced. Clean the internal fan(s).
This can sometimes fix overharting of the compressor or misleading air temp sensing..
Jul 08, 2015 | Frigidaire FRA296ST2 Air Conditioner
The air conditioner makes a loud sound when the ac trys to kick in. When i put it under fan it works fine and makes no noise.
Sounds like your compressor is seized/stuck and the unit needs a new compressor. If this is the case it should make a loud buzzing noise for a while and then click when it stops trying.
Aug 14, 2011 | Amcor Heating & Cooling
Its been working great and now for the last two days it works fine the compresser kicks on but when it kicks off and trys to come back on it pops the electric breaker. its been working fine on the same...
Whether its a central air unit or a wall unit, make sure the condensor is clean and air can flow thru it
make sure the condensor fan is running, the condensor fan keeps the compressor from over heating
if the condensor fan stops running the compressor will over heat and trip the circuit breaker. good luck!
Aug 05, 2011 | Heating & Cooling
I noticed some straining noise coming from my a/c unit today. The fan on top of the condenser runs fine but as soon as the compressor tries to kick on the fan stops for a split second and you get a kind of...
You amy ahave a bvad capacitor on the outside unit. It starts the fan and the compressor. You can change this yourself. Open the outside panel and you will see a silver canister with terminals out the top. Replace this and I think your problem will go away. On the cap. it will say something like 30uf 5uf 370 ot 440 Just get these numbers and get a new one. Russ
Aug 14, 2009 | Goodman CKL24AR24 Air Conditioner
Compressor won't kick off
What happens when started in just fan mode? Sounds like relay stuck.
Jul 28, 2009 | Dometic Rooftop RV Air Conditioner
Carrier air conditioner cycles on and off
The compressor/condenser is being called all the time. The reason it goes off is because the evaporator (indoors) freezes up when the fan is told to turn off by the thermostat. This further cooling lowers the low side pressure below the low limit switch point turning off the compressor unit.
Solution: Make sure the thermostat is wired correctly. Green wire is usually the compressor wire but maybe not.
Jun 17, 2009 | Carrier 38BRC036 Air Conditioner
Air conditioner fan will not come on and unit will run for 1 minute and stop
You hear the compressor kick in (Hum) but no fan comes on? Will the fan come on when just in fan mode, not cool, or do you have that set-up?
Aug 13, 2008 | Dometic Rooftop RV Air Conditioner
Compressor is not kicking in
Probably power surge shorted out the main board. If so it will need to be replaced. Gotta call for service.
Jun 09, 2008 | Danby Portable Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
261 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
