My mag 254 remote has just stopped working properly its not the batteries its a fault with the remote can you help
2 Suggested Answers
SOURCE:
gopakumarg43
  • 76060 Answers
SOURCE: Mag 254 remote control drop and stop working ?
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
http://schematicscom.blogspot.com/
http://electrotechnician.blogspot.com/
Posted on Oct 20, 2016
I have a mag 254 iptv and a Hisense TV. The remote codes clash and the two are unusable in tandem. Can the remote control codes on the Hisense be changed?
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://homenol.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; to which you want set-up codes; in the "Search box at the top right of the display window" to get gathered related posts.
Jun 29, 2017 | Hisense Televison & Video
Oct 20, 2016 | Televison & Video
How to change date and time to MAG 254 Box.
Enter the "System settings" - by pressing «Setup», «Services» or «SET» on the remote control (depending on the version the remote control)
- Select "Servers"
- In the input field "NTP server" enter "pool.ntp.org"
- Confirm "OK"
- Reboot mag250
Oct 15, 2016 | Computers & Internet
MAG 254 remote control stop working.
Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. Surf the site with patience. In some cases, the remote control might need to clean.
Search the site by type in this key phrase "how to test a remote control "in the "search box at the top right of the display window of the Homepage" to get the related post quickly.
https://www.youtube.com/watch?v=jsSCNCW3IbQ [open and clean]
https://www.youtube.com/watch?v=Qp-l1uh-5gE [open and clean]
Oct 15, 2016 | Televison & Video
How to stop a continuing beep on my Cordoba scooter when I turn the key on? The scooter don't move at all.
Hi Mag,
I have this steps that might help you with beeping sound on your Scooter. Hope it helps.
UNIT LIGHTS UP/HORN WORKS BUT UNIT WILL NOT MOVE
Possible Cause:
  • This often occurs when the scooter is in free wheel mode and is not in drive mode. Re-Engage the free wheel lever which is located down near the rear wheels (normally a yellow or red lever).
  • If you hear a beeping noise, the beeping you hear is a fault beep indicating the scooter main control box has detected a problem. Contact your dealer who can diagnose the beep code.
  • Check batteries with load tester - If either battery drops more than 1 volt under a load, the battery(s) are bad. Replace "both" batteries.
I also find these additional steps on how to know beep alarm indicators:
This main control box has a self-diagnostics feature & cannot be tested with a volt meter. When a
problem is present the main control box will diagnose the fault, prohibit the scooter from being driven
and sound an alert beep. Each alert beep indicates a different issue which helps to determining the
problem by narrowing the fault into one of a few main areas of the scooter. Reference this information
below for the alert beep indications.
Very Rapid beep- Batteries are low. Charge & test batteries.
Medium Fast beep- Motor/brake wiring fault. Free wheel lever disengaged.
Solid beep- The charger is plugged into the scooter (some models may vary).
Very Slow beep- The throttle pot was not at center when you turned the unit on. Throttle pot off
center or wiring (yellow & orange wires) fault.
Apr 24, 2014 | Shoprider Health & Beauty
AVR 254 is not responding. None of its front panel buttons are working (except volume). Same thing with the remote. I noticed that in the front panel area, the speaker icons in the Speaker/Channel Input...
ok
The reason your receiver is causing you issues is cause of a 2 time Delay fuse's on the transformer board all you have to do is to by pass them.
Check the connector on the top front of the HDMI board. at the bottom of the connector it tells you the voltage of each wire the middle one is GND. should read 1.8v and 5.6v if the 5.6v line is dead. you key's in the front panel and sometimes video and audio as well.. will also stop working. all you have to do is to by pass them.
I will be posting a video later today on how to fix this issue. Regards,
Search for AVR 254/354 fix
Mar 16, 2010 | Harman Kardon AVR 325 Receiver
Hi i use this remote to program my toshiba tv,it work for while ,it stop working.could you me what happen with this remote. thank you.
That is like asking How long is a piece of string!
The batteries are flat
It's got an internal fault
It loses its code
contacts are corroded
and 1000 other faults that may cause it to stop.
The common onbe is faulty batteries and dirty contacts where batteries connect
Best we can do for you
Please rate my help++++Thanks for using FIXYA
Feb 07, 2010 | RCA RCU811 LCD Remote Control
My Harman Kardon AVR 254 is not responding. None
I am having the same problems with my AVR 254, did you find a solution?
Thanks
Mar 15, 2009 | Harman Kardon AVR 325 Receiver
Televison & Video Logo
610 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
