My mag 254 remote has suddenly stopped working correctly its not the batteries and the thing is only weeks old what can be done
SOURCE:
  • 43 Answers
SOURCE: LCD TV Remote quit working
First thing, turn off the TV and unplug it for about 2-3 minutes. Remove also the batteries on your remote. Re-install the batteries on the remote and plug in your TV. Power on your TV using the remote. No luck?
Norcent may not be supported by a universal remote. If you just bought your unit new (maybe Best Buy who carries this brand) you are still covered by its warranty. Below are ways you can reach Norcent.
http://www.norcent.net/main/contact.asp
909) 305-2121
support@norcent.net
Posted on Mar 24, 2008
dnewcombe1
  • 1564 Answers
SOURCE: remote control not working on brand new series 4 42 inch samsung
Make sure the remote is set to operate your tv and not a cable box or accesory. It's in the menu
Posted on Jul 24, 2009
sabreusa
  • 271 Answers
SOURCE: Remote for one month old LG 37LG30 TV suddenly
Must be the IR receiver usually is soldered on a circuit board. Time to call your warranty..
N Sabre
Posted on Nov 07, 2009
SOURCE: Myota Watch Batteries
Try a Maxell 391 silver oxide
Posted on Jun 27, 2010
Rider On Way
  • 1679 Answers
SOURCE: My Panasonic Lumix DMC-FX8 suddenly stopped
My suggestion would be to try with new set of battery.
You can also try this.
Remove the battery and clean the contacts between the camera and battery and insert it. Sometimes tapping the camera on the palm 3-4 times bit gently too fixes the problem.
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Posted on Dec 29, 2010
Mag 254 remote control drop and stop working ?
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
http://schematicscom.blogspot.com/
http://electrotechnician.blogspot.com/
Oct 20, 2016 | Televison & Video
How to change date and time to MAG 254 Box.
Enter the "System settings" - by pressing «Setup», «Services» or «SET» on the remote control (depending on the version the remote control)
- Select "Servers"
- In the input field "NTP server" enter "pool.ntp.org"
- Confirm "OK"
- Reboot mag250
Oct 15, 2016 | Computers & Internet
MAG 254 remote control stop working.
Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. Surf the site with patience. In some cases, the remote control might need to clean.
http://remotesearch.blogspot.com/
Search the site by type in this key phrase "how to test a remote control "in the "search box at the top right of the display window of the Homepage" to get the related post quickly.
https://www.youtube.com/watch?v=jsSCNCW3IbQ [open and clean]
https://www.youtube.com/watch?v=Qp-l1uh-5gE [open and clean]
Oct 15, 2016 | Televison & Video
The remote has suddenly stopped working? Only 3 weeks old
i would suggest you reeturn the entire thing to place of purchase for a replacement .WARRANTY
Nov 03, 2015 | Televison & Video
ML 320 Remote Control doesn't function
Have you tried replacing the battery in it?
Jan 16, 2015 | 2001 Mercedes-Benz ML 320
Tv won't stop changing channels
You need to isolate the problem.
1) Unplug the set for a few seconds then plug it in.
2) Operate the TV with the control/buttons on the TV. (Channels etc)
If the TV operates correctly then do the following.
3) Try operating with the remote unit. If the problem returns then it's the remote failing.
Sometime remotes can be reset.
Try this;
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly.
New batteries should be used if you're not sure about the old ones.
Try it again. If the problem is still there then the remote is bad.
Since this is a new TV you should use your warranty to replace any bad parts.
Mar 16, 2009 | Vizio L32 32 in. LCD HDTV
My tv is on aux how do i get it off aux i dont have remote
unplug your set. it will reset the tv computer. replug in and you should be all set. had the same thing happen last week. was about to throw away when son, upset about losing the tv plugged it back in and it worked. hth.
Feb 22, 2009 | Broksonic CTGV-5463TCT TV
909) 305-2121
support@norcent.net
Mar 24, 2008 | Norcent Technologies LT-2722 27 in. LCD...
Televison & Video Logo
1,363 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
