SOURCE: Hotpoint BS 21 fan oven Broken door hinge
Pull the door down as far as it will go, and at the lower end of the hinges, there you should see what looks like 2 round discs, with a step cut out, rotate the discs with a scewdriver as far as they will go,then close the door and pull it towards you, the door should then pull off.
Replace both hinges, not just the one ,or it will close unevenly.
Slot the hinges back into the hinge slots, pull the door down, rotate the disc back to their original setting, and that should be it.
Plz rate this solution. Thanks.
SOURCE: remove door and glass on whirlpool gbd307pdq1 double oven
hi there sometimes glass will just pull up on sliders on the side just open door etc and the glass panel should simply slide up.
SOURCE: reinstalling oven door which was removed by overseas movers
Have a look on You Tube, there are a number of videos that demonstrate how oven doors can be removed, it normally revolves around latching the hinge. Refitting is a reversal of the process.
The following video shows a number of different methods to remove and refit the oven door
Hopefully, one of the methods shown in the video will help you.
