My window ac is still showing Ch,after cleaning and fixing the filter.After pressing temperature up and down keys together. Its control panel is not working.. Then what to do. Is it safe to use ac
  • 1362 Answers
SOURCE: Toshiba 1360 C7 Error Code
TOSHIBA 1310 C7 Fusing unit warm-up error, defective thermistor, fusing lamp or thermofuse
The codes are good for several models.
Posted on Oct 25, 2007
  • 121 Answers
SOURCE: "CH 01" shows on the display screen
This will need to be serviced. LG has a 5 year warranty on these models. They usually will tell you of a service center nearby which will service it free of charge since it is under warranty. If you do not live near a service center they may ship you a replacement and you send your old dehumidifier back to them. Make sure you have your reciept when you contact them so they can verify it is under 5 years old.
Posted on Aug 04, 2008
  • 80 Answers
SOURCE: "Jacuzzi j-400 series" hot tub- F1 code flashes on control panel
There are two things you can check, there is a tranformer that plugs into the main circuit board(usually a four wire plug). Unplug and check pins for good connection and then reconnect There are usually one or two fuses inside the control box mounted on or near the circuit board. Turn off power to spa and pull fuses and check continunity. This is a good start.
Posted on Aug 19, 2009
  • 4 Answers
SOURCE: Stopped Running - Control Panel CH 01
All, I had this same problem as well. I called the LG Support Line and they told me the unit needed to be serviced. I went through the motions of getting the service providers and what have you, but I wasn't going to go through with it because the closes service provider was a 45 minute drive. I posted how disappointed I was because I had only had the unit for a year, but could not find my earlier post.
Anyay, I am glad I went through the motions, because a few days later LG called and told me they would be shipping me a refurbished replacement. Wow. That was a treat. They shipped me a refurbished unit and had me send the old one back. I did not have to pay a dime. The sent me the Fedex shipping label via email and I called Fedex and they came by and picked it up.
I cannot remember if I had registered the unit when I initially purchased it. Sometimes I won't do that because it seems only to serve as a license to sell me stuff. They took down all my contact information and sent me the unit so I don't know. I would simply encourage everyone with the CH 01 error code to give LG a call via the support number from their website at Good luck!
Posted on Sep 28, 2009
SOURCE: "Ch" is displayed on the display
Appearance of "Ch" on the AC screen is an reminder to clean the AC filter. Whenever it appears you clean the filter and connect the AC to power but, do nut run it is (it should be in switch off mode but, connected to power).
After that press the up and down buttons together on the control panel of the AC (not on the remote) till a beep comes from the AC.
Posted on Sep 07, 2010
What is the pin code for Aiwa HVFX5500 vcr
hi ,
Power on,
Press both CH/UP key and REC/OTR key for more than 2 seconds,
OK will appear in the display panel.
or try
Press CH DOWN key on VCR while pressing the 7 key on remote and hold for more than 5 seconds.
The display should then show OK.
but First disable the child lock by pressing the "lock" button on the remote,
and only then press "Ch-" and "7".
Oct 02, 2014 | Televison & Video
Hi my samsung ac disply showa Ch what does it means
It is just the reminder to clean the filter of the a/c this error display automatically every after 336 hrs, so just clean the filter and reset the CH display by pressing temp up and down arrow key to reset it, so no worries on this one just clean it and reset the timer and all is well.
If this was helpful, a vote with the thumbs up would be greatly appreciated for the free advice.
Aug 22, 2011 | Samsung AW1203B Air Conditioner
My samsung window ac ,at the display showing ch ,what does
It is not a problem it is just the reminder to clean the filter of the a/c this error display automatically every after 336 hrs, so just clean the filter and reset the CH display by pressing temp up and down arrow key to reset it
Jun 22, 2011 | Samsung AW1203B Air Conditioner
Ch is displayed even ac is off
Hi this is Santhosh, you can solve it easily, Just clean the filter and then insert it again, and then just press up and down keys of temperature directly in AC not with remote, for 3 secs, then it will turn automatically to normal .
Aug 06, 2010 | Samsung Heating & Cooling
just press the arrow keys up down and hold it for few sec till beep comes..(on ac scree not on remote)... this indicates cleaning of air filters..
If problem still persists, let me know.
Jun 19, 2009 | Samsung AW1203B Air Conditioner
AC & Rear wiper switch button indicator lights blink
The procedure for re-setting the HVAC control panel on a 1998 Dodge Grand Caravan follows:
With ignition on but not running
1. turn knob to air vents
2. turn fan knob to ON
3. temperature setting on COLD (2X) {I have dual temp controls}
4. hold top(rear wiper) and bottom (rear wiper with wash) buttons pressing down together until all the buttons cycle through (this will require 1 to 2 minutes of continuous pressing)
I learned this from a very helpful local Dodge service adviser
May 09, 2009 | 1998 Dodge Caravan
Samsung bio-sleep air conditioner. 1 ton capacity. the display is keep showing me 'ch'. How to remove that
press the temparature up and down key simulteneiusly for 5 seconds on the unit when it is on.It is CHOKE indicator stating that it is time to clear your a/c filter.It happens after ever335 hrs of use
Apr 29, 2009 | Heating & Cooling
"CH" is only getting displayed in A/C
Apr 11, 2009 | Samsung AW1203B Air Conditioner
" CH"
if ch error is displayed on your samsung ac . press and hold the up and down arrow mark(in the ac control pannel and not in remote ) simultaneously for few sec untill u get a beep sound from it ... this is a default seting to remind u to clean the air filter
Jun 08, 2008 | Samsung Heating & Cooling
In doing some research, I found this link to Samsung which may or may not be of any value. However,I did discover that "ch" possibly means "chill", what it does is not clearly explained.
Jun 03, 2008 | Samsung AW1203B Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
