Question about The Office Equipment & Supplies
We have changed our WiFi to Superfast and our MG3200 printer is no longer printing. How do we get the printer to communicate with the new router?
Raysagem
  • 1017 Answers
SOURCE: computer will not communicate with printer
The Router won't affect the printer. Try a repair, go into Start/Settings/Control panel/Add remove programs, find the printer software in the list and if there's an option to repair, go for it. If not...
You may need to update your driver:
http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=143:1:0:537:0:0&emeaframe=&fileID=8165&searchLang=en
"Pentiums melt in your PC, not in your hand."
Posted on Apr 08, 2008
marketex
  • 371 Answers
SOURCE: new printer, cannot get the wifi or network to recognise
Is it possible that you have limited the number of nodes on the print server and need to reset that number?
Posted on Mar 29, 2009
the_fire
  • 432 Answers
SOURCE: print from laptop without using router to lexmark 6600 wifi printer
only if you get a wi fi access point and have a switch to connect the wi fi access point to but then you would have issues with NAT ( Network Address Translation ) which is used to be able to connect many computers to the internet through one internet connection.
Posted on Apr 30, 2009
  • 264 Answers
SOURCE: I am having Communication errors
The following check-lists will help in solving the issue.
1.Most probably the problem will be the driver so update the driver to the latest version.
2.If you able to print from the mac pc which was wired to router then the problem may be in also a router since it may block some ports.
3.Ensure good signal strength between Mac pc and router
Thanks for using fixya
Posted on Sep 09, 2010
Printtech
  • 1087 Answers
SOURCE: 1. The printer is printing everything in
1. You could try to reinstall the Z2420 driver on your computer. 2. Try to reset the wireless network adapter of your printer. Follow the instructions in this article from the Lexmark website on How to Reset the Internal Network Adapter on Lexmark Z2400 Series Printers. Open Lexmark Wireless Setup Utility to reconfigure your printer to connect to your wireless network.
Thanks.
Posted on Mar 08, 2011
My PC will communicate with my printer but my printer won't communicate with my PC, so I can't scan anything. HELP!
Uninstall all of the software and then reinstall it. If still issues contact Brother tech support for assistance. They are really wonderful and will get you up and running. Your wifi is working so the router is not an issue. Check out your usb cable and try another one or a different usb port on computer.
Mar 26, 2017 | The Office Equipment & Supplies
I cannot print with my Mac Book Pro. Correct printer is added already.
The mapping info is lost after the router and wifi change . Reconfigure the laptop settings for this . My previous answer would be invalid because you dis not mention WiFi
Jun 24, 2015 | Office Equipment & Supplies
Connect to bt infinity
Set up the wifi links again.
Nov 06, 2013 | Computers & Internet
Wireless printing
Blinking orange means one of the following: 1. The printer is out of range of the wireless access point (wireless router). 2. The printer is trying to communicate with the wireless access point, but the wireless access point is turned off or not working properly. 3. Either the configured printer or the wireless access point has been turned off and back on, and the printer is trying to establish communications with the network. 4. The wireless settings of the printer may no longer be valid.
May 10, 2012 | Lexmark X7675 AllInOne InkJet Printer
My printer/scanner will no longer scan something and send it to documents? it instead prints out the test sheet like the one used when you change cartriges?
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
Oct 03, 2011 | Lexmark X2500 All-In-One Printer
SIEMENS SE587 ROUTER AND NEW WIFI PRINTER
pile of ****!.. the edimax print server doesnt seem to regonise and connect to wireless networks if they have a "space" in there name!.. took me ages to figure that out!.. and now its conected it constantly comes up with a communication error during printing!
Jan 02, 2009 | Computers & Internet
I have a new Kodak ESP 7 printer and have not been able to set it up to communicate with my Mac OS 10.5 laptop. I can print if I have it plugged into the USB. I understand I might need an extra unit to...
Hi. I can help you connect your wireless ESP 7 to your Mac laptop.
The first step is to connect your printer to your wireless network. Navigate to the menu on the LCD of the printer and select Network Settings/WiFi Setup Wizard. The blue WiFi LED should be illuminating steady if the printer is connected to your WiFi network.
The second step is to add the WiFi printer to your Mac using the Print & Fax System Preference...
1. Under the Apple Menu, select System Preferences
2. Select Print & Fax
3. Click the "+" sign to add a printer
4. Select the Kodak ESP 7 listed with the Bonjour connection
5. Click the Add button.
The final step is to verify that you are printing to the WiFi printer when you attempt to print. In the Print Dialog box, verify the selected printer is named "KodakESP7+1234" where the last four digits are unique to your printer. If the printer you have selected is "Eastman Kodak Company KODAK ESP 7 AiO", then you are attempting to print using USB and this will not work unless you have a USB cable connected.
I hope this helps.
Dec 04, 2008 | Office Equipment & Supplies
20 people viewed this question
Top The Office Equipment & Supplies Experts
Jerry Greenberg
Jerry Greenberg
old marine
old marine
Mitch Vass
Mitch Vass
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
