When the boiler turns itself off it makes a noise like a blown- up balloon deflating. Can I fix it?
2 Suggested Answers
  • 1779 Answers
SOURCE: Whoopie cushon/balloon noise
Try disconnecting the air intake and see what happens (that won't harm the engine). I don't believe it will harm the engine w/ this noise, although it might be a little embarrassing. They have been using corn to make gasoline, I wonder if they started using beans?
Let me know the results and any new clues you may think of or the truck may develop. Have someone under the hood when u shut truck off to see it they can figure exactly where it's coming from. Beano in the gas tank? No, No, don't do that. countrycurt0
Posted on Sep 09, 2008
Lumbar seat for 2006 trailblazer will not deflate
could be a problem witch air solenoid inside the seat or the balloon itself or line not connected
hope it helps
Mar 27, 2014 | 2006 Chevrolet Trailblazer Ext
What are hi-float balloons?
Hi-float balloons is basically a way to extend the life of helium balloons that would otherwise deflate in around 8-16 hours. The hi-float treatment coats the inside of the balloon and helps them to last up to 25 times longer (depending on the quality of the hi-float treatment).
Feb 25, 2013 | Event Planning & Celebration
Air trapped in boiler making noise
If the air is in the boiler itself you can't vent it through the pressure relief valve on the side. If the air is in the loop (baseboard or radiators) then you should go to the highest point in he loop & bleed the air out using the bleeder valves on he baseboard or radiator. You need to follow the pipes & see where they turn colder & that's generally where the air is.
Feb 24, 2013 | Heating & Cooling
Ariston euro-combi boiler not giving hot water
odd noise like popping or singeing fire....clicking noises.....sounds like you have a water leak putting out the pilot.......or your thermo coupling is bad....or the noise is the tank full of calcium buildup and that will make noises when the burner is on
Jan 19, 2013 | Water Heaters
Hi, my son has just kicked his balloon into the return air vent and been taken into the pipe of our ducted heating system.
no louver cover over the vent? If you can see the balloon spray peroxide on it to deflate it and fish the balloon out with an electricians wire feeder
Jul 16, 2011 | Heating & Cooling
My worcester bosch 24i junior pressure keeps dropping if i have heating off for an hour i have to top up boiler and reset also when i have heating on the pressure jumps right up to over 4.0bar
When water is heated it expands. To deal with this all boilers are fitted with a small expansion vessel which is like a reservoir which holds the excess water.
This expansion vessel is like a balloon in a metal pot. When the water goes in the metal pot the baloon squashes a bit to make room for the extra volume of water. When it cools the balloon pushes the water back into the heating system.
What has happened is your expansion vessel no longer works. When the water heats up there is nowhere for it to go so the pressure jumps up to 4 bar. The Worcester boiler lets high pressure water escape (most boiler allow this to go through the safety valve at say 3.5 bar).
When the water cools the pressure drops very low as the volume of water contracts.
The problem is your expansion vessel - normally a little red painted metal cylinder inside the boiler.
Dec 22, 2010 | Bosch Water Heaters
My coleman 424 stove has been sitting in shed for a coulpe of years, now got it out again. Filled with petrol when pumped up I can light it but flame only lasts a few minutes then it dies as if no...
My best answer is that your pump seals have dried out and are allowing pumped up pressure to leak back past the pump seal
Try this: DO NOT LIGHT THE STOVE
Pump it up hard then quickly attach a small balloon with a rubber band around the base of the pump - where it contacts the tank. A deflated balloon or a small plastic baggie - does the balloon begin to fill with air after a few minutes - if yes then your seal is leaking.
You might try taking the pump apart and soaking the seal overnight in fuel reinstall and see if it cores your problem
Good Luck
Mar 22, 2010 | Coleman 2 Burner Dual Fuel 424-700G Grill
Francis Francis X1 Popping noise - stopped working
Hi There are a couple of things that could have happened. The fuse could have blown, but you wouldn't get a pop usually. The main board could have blown, that will pop. There is a hole below the steam arm. up inside there is a screw that you can loosen. Then you can unscrew the steam knob. There are 4 screws on the bottom side of the cover that will allow you to remove the top. Make sure that the machine is unplugged.
Feb 13, 2010 | FrancisFrancis! X1 Espresso Machine
Boiler making clicking noise
contact baxi and ask ther service people there was aproblem with this but i cannot recall it now ,hopethis helps
Jan 09, 2010 | Heating & Cooling
My air suspension deflates often
hi, im sensing a fault in the bag itself. sticky valves make noise. i would check the valve but, im sure its the bag itself.
Feb 20, 2009 | 2000 Ford Expedition
Heating & Cooling Logo
32 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
