Question about Indesit Washing Machines
I have an Indesit IWB71250 washing machine. For a while now it's not been doing a good job at cleaning or softening my clothes, as if the softener doesn't get to them. What can I do?
I have tried descaling it but it made no difference, and I've thoroughly cleaned out the detergent drawer. No change. The machine is about 3 years old and all the programs work. Clothes smell and feel clean but still look dirty and not softened as they used to be.
ngafm
  • 166 Answers
SOURCE: HE Washer leaves clothes smelling bad
Peace,
ngafm at your service,
How old is the washer?
And how long has it been smelling bad?
Some front loaders over the years have had this problem and the worse used to be the Maytag Neptune!
This is what I tell my customers to do:
Friend,
ngfam1 At your service!
It is normal for some frond load washers to have a little water left in the inner tub after the wash finishes!
I do tell my customers to run the washer once a week without clothes and with hot water and 1/4 cup of bleach. And then make sure to do only white clothes directly after wards as not to get a drop of beach water on a colored article of clothing!
Then leave the door open after every load when not in use!
If this will not help I would call frigidiare and tell them you must have it replaced that it is affecting your family because of the mold smell!
Believe me they will swap it out after all the money you spent on it, you deserve it! BUT REMEMBER MANY people have this problem with some front load machines!
if it's not new then perhaps the pump is faulty or the lint is clogging int he pump of the machine!
Let me know what happens!
Bless You,
please give me a rating before you sign off!
ngafm
Posted on Sep 05, 2008
SOURCE: Fabric softener stays in drawre
We just had a tech come out to fix this problem for us. Essentially, the problem is that the fabric softener builds up and gets clogged. He cleaned out a solid hunk of frabric softener gunk, and suggested that we dilute our fabric softener with water to keep this buildup from happening again.
Posted on Apr 11, 2009
hattonhall
  • 349 Answers
SOURCE: I have a quite normal front load whirlpool washing
Oh angel!
a rose by any other name!
If your clothes smell worse after washing then the machine is full of gunge from all the previous washes. One of the worst things that puts a gluggy deposit inside machines is of all things Softener!
You could try putting a generous two cups of Sugar Soap Concentrate into your machine and filling it with warm water. Then let it stand for 24 hrs, Then start the wash cycle.
This may clear the gunge. If not the only sure remedy is a strip down and degunk and that will cost you a few dollars.
Posted on Oct 20, 2009
blueextc3221
  • 15935 Answers
SOURCE: MY FABRIC SOFTENER JUST SITS IN DRAWER
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub.
Pull the dispenser drawer completely out.
There is a tab that needs to be depressed to release the drawer and remove it.
Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening.
Reach down into this opening to see if an item is inside the hose.
This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
heatman101
  • 43501 Answers
SOURCE: How is the liquid fabric softener dispenser
Here is a tip that I wrote about what I found out about the fabric softener notdispensing into the washer...
Fridgidaire Washing Machine Fabric Softner not going intowasher
heatman101
Posted on Apr 30, 2011
Iwd71250uk fabric softener staying in dispenser.
Compartment 3: Additives (fabric softeners, etc.)
The fabric softener should not overflow the grid.
Cleaning the detergent dispenser drawer
Remove the dispenser by raising it and pulling it out (see figure below). Wash it under running water; this operation should be
repeated frequently.
25825864-ineink0kisfnom0atbkujjcx-3-10.jpg 25825864-ineink0kisfnom0atbkujjcx-3-3.jpg 25825864-ineink0kisfnom0atbkujjcx-3-6.jpg
Dado
Aug 17, 2015 | Indesit Washing Machines
How do I remove detergent tray from Indesit washing machine
there might be a push down button on your model inside the draw if not it should just pull out
Sep 26, 2012 | Indesit Washing Machines
My washer cannot wash off liquid fabric softener so good. Some softener sticks into the clothes. Guess the the bottom of dispenser needs cleaning or maybe theres a lot of fabric softener left under it. How...
Hope this helps.You need to remove the washer to see whether debris blocked drain hoses.there might be clothes metal that blockes the drain hose..Hope this helps.
Jun 19, 2011 | Maytag PAV2300 Top Load Washer
I have an indesit 1100 washing machine, but it does not take the softener in from the draw. i have cleaned the draw out nad tested the draw over the sink. it seems to work ok but once its back in the...
You need to clean the drawer box top, the holes get blocked and the pressure is only low on the conditioner section..you will need a lengthy object to clean the hole properly
Oct 05, 2017 | Indesit Washing Machines
Fabric softener doesnot seem to work
Open soap drawer and remove little 'hat' from it's post in the fabric softener compartment. Make sure both are clean and free of softener residue.
Mar 18, 2010 | Washing Machines
My GE Adora front loader- our clothes stink!
Clothes washing rules for mildew stink: 1) never leave clothes in machine for more than a few hours 2) never add too many detergent or clothes 3) clean the machine itself. Also if your fabric softener port is gummy there is a good chance you got some funk from that so clean all places where you have fabric softener contact. After all that, if this doesn't help you may need to run an empty load of strong hot bleach water and follow it with a hot empty rinse then a load of whites
to becareful not to ruin your colored clothes
Aug 09, 2009 | GE WSXH208A Front Load Washer
Compartment 3, detergent dispenser, fabric softener.
Grasp the drawer firmly, and give it a good tug to pull it out.
Remove all parts, and thoroughly clean, then just line it up with compartment and push it back in.
Plz rate my solution.
Thanks.
Jan 17, 2009 | Indesit W 123 Front Load Washer
Clothes softener does not drain out of the holder
Do your clothes smell funny? Does it take forever for a load to wash? That happened to me and there was a wire loose in the machine somewhere and it would quit mid cycle and never finished a rinse or spin cycle. My fabric softener never drained either!
Oct 03, 2008 | GE Energy Star WCVH6260F Front Load Washer
Indesit washing machine W103 softener drawer
The softener could be retained in the drawer due to a defective release or controller fault but washing machines are designed to flush the drawer with water to ensure no residue is left to congeal. It may take a service call to find out what the real problem is.
Apr 21, 2017 | Washing Machines
Fabric softener compartment problem.
I have this problem as well.. All washing machines manufactured nowadays are energy effficient, which means that they don't use as much water as the older models. This can result in a build-up of bacteria in the top part of the washing machine, which is clogging up the bit where the water comes through to flush the fabric conditioner into the drum. What I have to do every so often, is to take the top off the washing machine and clean out the layer of black slime that has built up, blocking the holes where the water goes into the washing machine. Another contributory factor is that the usual program used is a 40 degree wash, which is not hot enough to completely flush the machine through. Manufacturers recommend running a 90 degree wash once a month with just washing powder in iit, no clothes. Hope this is some help
Dec 12, 2007 | Washing Machines
Washing Machines Logo
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
