Question about Ben Sherman Watches
Need help on how to repair ben sherman portobello touch watch. Thanks.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Ben Sherman Master
  • 572 Answers
A jeweler probably best resource.
Posted on May 18, 2017
    Top Expert:
  • 34,725 Answers
A jeweler probably would be your best resource.
Posted on May 15, 2017
I need a replacement brown leather strap for Ben Sherman watch R472
Hi call watchsupermarket .co.uk 0845 600 1511 for availability ...cheers
Jul 15, 2017 | Ben Sherman Watches
Set time on Ben Sherman R424
Press and hold the top right button till it beeps. Then press the bottom left button to scroll throught the hh:mm:ss, use the top buttons to increase or decrease the number. Finish by pressing the bottom left button until you cycle through back to the time display.
Mar 27, 2011 | Watches
CANNOT REMOVE LINK FROM BEN SHERMAN WATCH
If it's similar to my Ben Sherman watch it will have what looks like a screw on one side. It is in fact not a screw but the 2 sides of the split pin - which you simply push out using a map pin, small strong screwdriver, or similar. If you look inside the links you should find arrows to indicate which direction to push the pins out - usually pushing the end opposite the "screw" end. Note: It takes a fair strength to get the split pins moving.
Jan 15, 2011 | Watches
How do you remove a watch back
Locate a very small tab (or recessed area) on the edge of the back cover. This is the access point for removal. You can find this sometimes by running your fingernail around the back rim, as this tab or indentation can be hard to see. Pull out the stem, which releases the back on some watches.
Get a small flathead screwdriver it needs to be a thin inflexible tip. Use a kitchen knife as a last resort. Wrap the hand you are holding the watch with in a towel or protect your hand in some manner so you don't injure yourself if the screwdriver/knife slips.
Very carefully slide the blade under the tiny metal protrusion on the back cover (or across the length of the recessed area, depending on which type of cover your watch has). Do not attempt to insert the point of the knife. Use the length of the blade.
Get under the tab or recessed area and gently but firmly turn the blade upward, popping the cover off.
When you replace the cover, make sure you line up the stem slot on the cover with the stem of the watch.
Or take to a local jewelry store/watchmaker!!
Aug 16, 2010 | Ben Sherman Strap Watch
Wanna set time on my ben sherman R424
I cant find my manual for my ben sherman r424 watch. it only has four buttons. why cant i figure this out?
You will not find BEN SHERMAN watch manuals online. Visit www.bensherman.com and click on CONTACT US or SUPPORT tab. There you'll be given contact phone number.
Mar 30, 2010 | Watches
Hi. I leave in Wayne, PA 19087 and would like to get the battery of my Tssot T TOuch replace without altering the water resistance etc... Where can I go? Thanks for the answer, ROb
I've never owned one of these watches, but I would take it to a reputable Jeweler/Watch Repair Shop- they have the tools and access to any gaskets that might need replacement to ensure the watch's water-tight enclosure, but they can probably replace the battery without changing any parts, if they're in good shape. Hope this helps.
Mar 25, 2010 | Tissot T-Touch T33759851
I bought Ben Sherman R424 watch from Amazon Marketplace. It has arrived with no manual, and I cannot figure it out. Any help please??
Solution 1 seems a little off for mine it's the bottom right button you hold in which brings up the date and then the country its set to starts flashing. Then the bottom left hand button to move to the time. Use the top right button to scroll and left bottom to move to the next input. When your done push the bottom right once.
Hope this helps.
Feb 25, 2010 | Ben Sherman Strap Watch
T button broken
The manufacturer? Maybe watch repair shop can order it for you? Make one from crazy glue and cast?
Nov 06, 2008 | Tissot T-Touch T33159851 Wrist Watch
Battery Change on T-Touch
there usually is an AC contact point to reset digital watches. Touching the + and the ac point with a conductive wire usually resets the watch. Not sure about the spring- I'm not going to open my Tissot up unless I have to.
Oct 28, 2007 | Tissot T-Touch T33759851
Watches Logo
22 people viewed this question
Top Ben Sherman Watches Experts
Tom Chichester
Jeff Tilburn
Jeff Tilburn
masud
masud
Are you a Ben Sherman Watch Expert? Answer questions, earn points and help others
