Question about The Audio Players & Recorders
Boston horizon Duo-i switch off on this morning the body on TOP and bottom very hot.changed power cable and nothing happend , then Waiting it cooler ,after that plug in and still remain as dead.
dugiehowsa
  • 114 Answers
SOURCE: Netgear JGS524 appears to be dead...
This is an un-mamaged switch, so it is very difficult to get any kind of diagnostic information out of it. Some times, this may mean that the switch is on and active, but at those times, there is some times a mode button to switch through the different types of indicators on the switch. This switch doesn't even have that. There is almost no documentation on this device. The only thing I could find was this install guide, and it doesn't mention anything about the lights indicating some type of diagnostic code. If you connect two machines to the switch, and both these machines have Static IP addresses (do not use DHCP), can they ping each other? If the can, then I say the switch is fine and its just a cosmetic problem. If they cannot, then I am afraid you will have to return this one as well.
Posted on Sep 18, 2006
jumptrout51
  • 3361 Answers
SOURCE: refrigerator no power
Plug some other device into these same outlets or use a volt meter to verify power at the outlet.
You definitely have a house wire problem if the interior light does not come on and the bulb is good.
Also check 120 volts power at the fridge cord where it attaches to the terminal box.
Posted on Feb 21, 2009
SOURCE: all over sudden my boston horizon doesnt allowe increase the vol.
To fix: turn on unit, turn volume all the way down to 00, push and hold volume button for 10 seconds until beep then release, then turn volume all the way up to 50 (max) and push and release volume button.
Posted on Jun 06, 2009
issikiki
  • 563 Answers
SOURCE: My remote control stopped operating my Boston
You can contact the BA. As they will make arrangement to take it back and replace it. BA is a good company and they give consumer feedback as soon as possible. Well, only if you haven't got an answer to your question.
Posted on Jan 26, 2010
  • 10 Answers
SOURCE: boston acountic horizon duo, how do I open it, It
hi i'm looking for that solution too but found by myself you just need to remove the 2 front speaker grille just pull off and after remove the eight rubber that retained the grille the screws is under these rubbers and after gently pry the front cabinet
Posted on Jan 12, 2011
How do you fix a boston Horizon Duo - I as the unit just turns on and makes a load humming sound and then th edisplay switches off
If you are lucky, it only went in protection mode and after disconnecting the power for a little while and reconnecting things could come back. But if the system did not have an overload protection, a fuse can be blown, or worse the power supply or power amp can be blown to pieces. There is one thing semiconductors don't like is work over their limit.
Sep 12, 2014 | Boston Acoustics Duo-i Horizon Clock Radio
Display light out on boston acoustic duo-I plus
In my case the blue LEDs were dead. It is pretty difficult to replace them by new SMD-LEDs but I managed it. Open the front, take out the board from the front part (5 screws). On one side of the LCD-screen you can see a white stripe with 3 resistors 101 (100 ohms). You must free this stripe form the plastic body on the left and right side (eg. by soldering iron). Solder out this stripe, on the other side you will find 3 very small smd-leds. Break them out and solder 3 new leds onto the board (left side = K). For control you can put 3 Volts to the Anode (A=+) and the Kathode (K=-) of this stripeboard before fixing it on the frontboard by soldering.
Jul 09, 2014 | Boston Acoustics Duo-i Horizon Clock Radio
Why will my volume will not go past 10 on my boston duo i plus radio?
To perform a "soft reset"(all settings are erased)
Unplug radio
Hold alarm 1 button and plug in radio
Keep holding alarm 1 button until 3 numbers appear.
Release alarm 1 button and unplug radio.
Plug radio in and all will operate normally
May 21, 2014 | Boston Acoustics Horizon Solo Clock Radio
I have two horizon duo radios and both have problems now with the on off center button. It dosesn't work. Can't turn radio off
Control micro is damaged due to leaky memory cap, .33F/5.5v on display board. Yellow glue used on these units turns brown and becomes both conductive and corrosive to the circuit board traces. built in obsolescence in my opinion to get you to buy new.
Feb 25, 2014 | Boston Acoustics Duo-i Horizon Clock Radio
Dear Support, I have a Boston Horizon Trio Radio. The screeen remain blocked with the word "BOSTON" the buttons dont work. I have tried to plug the service cable to my PC, but nothing. Please, can you help...
Hi Roberto, I have the same problem after not using the Trio for about 2 month while it was unplugged. BA told me to unplug for 48 hours - of course this didn't help. Have you found a solution?
Oct 06, 2013 | Boston Acoustics Horizon Trio Clock Radio
Power button won't turn radio off
I've got the same problem. All other functionality is fine, however I can't turn the unit off once I've turned it on. I can use the power button to adjust volume, just not turn it off, so I have to unplug it to get it to turn off.
Jun 17, 2013 | Boston Acoustics Duo-i Horizon Clock Radio
Boston acountic horizon duo, how do I open it, It was connected to a 240 V and after that it stopped working. I thinking of opening it and fixing the power supply component.
Nov 13, 2010 | Boston Acoustics Duo-i Horizon Clock Radio
My remote control stopped operating my Boston Acoustics Horizon Duo-1. I know it is not the remote because I have a 2nd Duo-i Horizon that can be operated by both remote control units. Thanks, Booker
Jan 26, 2010 | Boston Acoustics Duo-i Horizon Clock Radio
Unit looses time
I just received a email from BA re this issue. They were amazingly prompt and friendly. Here is what I was advised to do:
"One thing to try is to let the radio recalibrate itself, this is done by leaving the unit completely unpowered and unplugged for 48 hours to let the cap drain and the unit will recalibrate itself"
Aug 13, 2009 | Boston Acoustics Duo-i Horizon Clock Radio
All over sudden my boston horizon doesnt allowe increase the vol.
May 17, 2009 | Boston Acoustics Duo-i Horizon Clock Radio
37 people viewed this question
Top The Audio Players & Recorders Experts
bihug
bihug
Level 1 Expert
D. E. Hev
AliennoisE
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
