Celestrial Split Type Air Conditioner Outdoor Unit KFR-70GW/K1. Needs new motor because the fan stops every 1 hour.
  • Heating & Co... Master
  • 1,863 Answers
Did you check the capacitor first?
Posted on May 15, 2017
I got a C9 error on a C12AWR artcool split ac which doesn't work anymore i replaced the mainboard of the outdoor unit which didn't help i replaced the fan motor which didn't help either does...
Split = Outdoor unit fan problem. Check Outdoor fan motor is plugged in, Electrically & Mechanically sound, if not replace motor, otherwise replace PCB. Multi V
= indoor PCB failure. Replace PCB.
Let me informed again if problem persists,.
Oct 25, 2011 | LG LA185HV Split System Air Conditioner
Outdoor unit fan stop after 3 mint?
checking out the capacitor that goes to wire the fan and if it is OK then he NEW fan motor.
Aug 19, 2011 | LG LS-L1210CL Mini Split Air Conditioner
We have a spit system air conditioner.Celestial KFR-70GW/K it is leaking water/condensation internally behind the fan.I think it it from therear grill and for some reason it does not go into the drain...
Leaking water from indoor is a common problem. Please check the following:
1. Cooling coil and air filter blocked-Clean it. 2. Drain pan and hos dust blocked-Clean it. 3. Non insulated pipelines-Insulate properly. 4.Less rpm of blower motor.-Replace capacitor.
Helpful?
Jan 01, 2011 | Heating & Cooling
Require instructions and wiring diagrams for Celestial KFR-70GW/K
If you pull the unit out of the case it should have a wireing diagram in a envelope near the compressor
Jul 17, 2009 | Frigidaire FAA065M7A Air Conditioner
I have a split air conditioner my out fan keeps
It depends on the effiency of the unit. The fan could be cycling because the condensor coil is not hot enough. When it get hot enough the fan will turn on. If not you have a bad fan motor
Jun 25, 2009 | LG LSC091PMA Split System Air Conditioner
I have purchased 1.5 split air-conditioner of Electrolux model 18SCRDA1 from NEXT and got it installed. Till now it is working fine. suddnly we observed abnormal noise from the outdoor unit.Condenser fan...
hi there.dont touch the untit.its under warranty and if you touch the unit and try to repair it.the warranty will be non existant.im one of the serivc agent for eletrolux.
Jun 08, 2009 | Soleus KFR-18GW Split System Air...
Amani Whisper Series Model KFR 70GW keeps turning itself off
Just had the Amani service guy out. Had the same problem. It was the capacitor. Took about 15 mins to fix. The machine turns off to protect itself because it knows something's wrong
Jan 05, 2009 | Heating & Cooling
Soleus kfr 18gwda
The fan blade can be purchased by calling 1-888-8soleus.
Mar 11, 2008 | Soleus KFR-18 Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
