Question about Filter Vacuums
How to remove the 2 screws that hold in the rug doctor filter basket? Ive never seen screws like that before.
The switch on my machin will not go on what do i do their or whats wrong with that what do i do to fix it?I plug in the rug doctor then i flip the switch but it wont go on.
bad switch or broken wire in the cord . use a continuity tester to check from the plug to the switch. if the cord is good check the switch itself good luck
Apr 27, 2015 | Rug Doctor 95730 MP-C2D Mighty Pro Carpet...
No water from spray on base
I had same problem. Remove all fluid from machine, I used a wet dry vac. As someone else said unscrew the 2 screws that hold the filter basket. Take out the filter basket and clean thoroughly. Find plastic hose that is now visible under basket and pull up and remove that (noticing where the slot is to put it back when finished) and pull the screen off top of hose and clean that as well. I then vacuumed out that hose with my wet dry vac. Reassembled everything and now works perfectly.
Oct 15, 2014 | Rug Doctor Mighty Pro X3 Value Pack - Blue
Rug doctor pro won't start
if you are renting it return it and be sure that they know of the problem if you bought it call the number in the label on the back of the cleaner and check your warrantee it will be able to cover it as long as you are still in the time period that they gave you if you are renting one they should give you your money back or rent you another one for the same time at no cost to you
Mar 21, 2014 | Rug Doctor Vacuums
Rug doctor repair manual
<Consumer.Support@rugdoctor.com> said: "Thank you for your inquiry about a schematic for the Mighty Pro machine. The only place that can be acquired is through Rug Doctor's manufacturing facility. You can contact our manufacturing facility at 800-964-4362 and ask for Parts. They will be able to provide you with what you are requesting."
Rug Doctor Consumer Support
Rug Doctor, LLC ' 4701 Old Shepard Place ' Plano, TX 75093
http://www.rugdoctor.com
Sep 07, 2013 | Rug Doctor Mighty Pro X3 Value Pack - Blue
Find water pump rug doctor
is it your own machine or a hire machine?
Your best bet would be your nearest rug doctor distributor or try ebay.
Tony from DirtMaster
Feb 25, 2013 | Rug Doctor 95730 MP-C2D Mighty Pro Carpet...
Rug doctor won't spray water
I had the same thing happen to mine. I looked at the hose in the water tank and the screen at the end if the hose was slimy and clogged. I took the screen off and cleaned it up, put everything back together and it works like new again. Only 2 screws and a screen.
Oct 17, 2012 | Rug Doctor Mighty Pro X-3 Ready Pack...
I have a Hoover Elite Rewind vacuum. Actually,this is my second one. However, after about 4 months of use, it emits a "sour" smell when I'm using it. I empty the cannister before each use and clean out the...
does it smell like an electrical burning odor? could very possibly be the motor going bad already. ive seen it happen. but if not try freshwave odor absorbing pearls. i carry it in my store and we do have shipping. Truly the only thing you should use to get rid of odors in a bagless vacuum, it wont clog your filters
Jan 03, 2010 | Hoover U5507900 Elite Rewind Bagless...
Will not spray
The heater is probally clogged. Remove the upper housing and locate a rectagular shaped object in the middle of machine. Remove six bottom screws and clean with stiff brush, clear all lines then run 3 tanks of hot water trhought he system to clear it.
Apr 10, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Can't get Bissell carpet cleaner back together
I've purchased 2 of these both are broke again, although I may fix one again and give it away instead of throwing it in the trash. You can tell by all 10 pages on this site that these machines are just **** that is poorly designed. Just ordered a Rug Doctor Mighty Pro from Kohls with 30% off for $503. You won't even find 1 problem on this site on a Rug doctor. Also you can research them as I did and 98% of their owners was very satisfied, alot of whom used bissell prior to Rug Doctor. You will also see that the performance is way, way better and not even close on cleaning.......
Feb 10, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
Brushes don't spin
Take out the screws from the bottom, there will 2 longer ones, they got into the turbine, turn it upright and take the top cover off. The turbine sits near the front, center, remove the 2 screws on the front of it, remove the hoses, then you can remove the turbine(#23).
Aug 10, 2008 | Hoover F7220900 SteamVac V2 Upright Vacuum
Vacuums Logo
Top Filter Vacuums Experts
gbob59
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Filter Vacuum Expert? Answer questions, earn points and help others
