Question about Vacuums
My Rug Doctor is not spraying out any water, Ive checked out the simple things and nothing is working. How do i check the spray nozzles for blockage?
SOURCE: Eureka Atlantis 2591A Extractor - Won't spray
no sray water
Posted on Jul 23, 2008
SOURCE: hoover steam vac model F5853-900 series 17.9
Make sure that the recovery tank is completely close.
Posted on Jan 20, 2009
SOURCE: Bissell ProHeat Carpet Steam Cleaner stopped spraying.
The problem was a clogged heating unit which is located in the lower handle. There are two clear hoses going up the inside of the left leg of the lower handle that go to the heater and to the in-line water switch all within the lower handle. I unplugged the metal heating unit water lines and electrical connections (label the connections as you take them apart if you have a hard time remembering things...there were seven connection in all be it water and/or electrical). Removed the heat unit out and then removed the 6 screws holding the heater cover. Inside was a white powdery pasty debris (lime deposit ?) and the water path was clearly blocked in four different places. I cleansed the water trough with a little water and soft toothbrush and several toothpicks then reassembled. If you need new washers go to Orchard or ACE hardware. Take the old rubber washers(they are red) with you for comparison. I didn't need new washers...I just gently cleansed them. I immediately ran clear water through the machine and actually cleaned the carpet with a water rinse only. Will go back and finish the carpet the right way tomorrow. I had only used my machine three times before this happend over a three year period. A friend told me to always rinse it two maybe three times with clear water after using it and before storage. This took me exactly 42 minutes to disassembly and reassemble. Cost savings is several hundred dollars since I have a 5 bdrm house and would need a professional cleaner to do the small dirty traffic lanes all around the house.
Posted on Sep 19, 2009
  • 294 Answers
SOURCE: My floor mate won't spray out any of the cleaning
sometimes the nozzle holes get plugged above the brushes. if you remove the solution tank you will see where the trigger rod connect to the resevoir to release solution. also you should see that a small amount of solution in the top of the resevoir if no water then the resevoir needs replacement and you are not gettingn the plunger pushed up far enouhg to release solution.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Posted on Oct 21, 2009
SOURCE: scunci steam cleaner not spraying steam
Unscrew the screw on the handle and remove handle. Remove rubber where top screws on. Remove two screws and the top and now unscrew the black pipe where the steam comes out. Now remove the button and see the small metal protrusion on the pot where the button was. Hit it with a hammer a few times softly to remove the scale buildup until the metal starts moving in and out again. I also sprayed it with a little silicone spray. Now put everything back together again. My steamer now works beautifully again!
Posted on Jan 11, 2010
The Rug Doctor stopped spraying.
did you run out of water ???
Sep 30, 2015 | Vacuums
No water from spray on base
I had same problem. Remove all fluid from machine, I used a wet dry vac. As someone else said unscrew the 2 screws that hold the filter basket. Take out the filter basket and clean thoroughly. Find plastic hose that is now visible under basket and pull up and remove that (noticing where the slot is to put it back when finished) and pull the screen off top of hose and clean that as well. I then vacuumed out that hose with my wet dry vac. Reassembled everything and now works perfectly.
Oct 15, 2014 | Rug Doctor Mighty Pro X3 Value Pack - Blue
Rug doctor will not spray what should I do?
check your spray pump is working a little pump inside machine is operating .check switch is working as well
Sep 02, 2014 | Rug Doctor Mighty Pro X-3 Ready Pack...
How do I get my carpet shampooer to spray wate
If your machine was designed to spray hot water, detergent cleaner or a combination of both, chances are the filter/strainer inside the reservoir may have become clogged, the feed tube may be twisted and pinched closed or the spray nozzle may be clogged from various contaminants. Try and get a look down inside the container where you fill it with fluids and see what you can determine, also check the spray tip or nozzle where the fluids are supposed to be expelled for a clog. If the small service pump is the culprit, servicing or replacing the pump will be a bit more involved and parts are available from most manufacturers websites these days. Hope this is helpful :)
Aug 27, 2014 | Dirt Devil 1700912044 Carpet & Rug...
Rug doctor won't spray water
I had the same thing happen to mine. I looked at the hose in the water tank and the screen at the end if the hose was slimy and clogged. I took the screen off and cleaned it up, put everything back together and it works like new again. Only 2 screws and a screen.
Oct 17, 2012 | Rug Doctor Mighty Pro X-3 Ready Pack...
Bissell pro heat wont spray
Not to be negative but I fixed one Bissell, and it worked for a while then it broke again. My Daughter bought one and it broke on her after using it only 3 times.
buy the rug Doctor or some other brand . That is my advise. Otherwise you will have to keep fixing that one.
Oct 22, 2017 | Bissell ProHeat Turbo Deep Cleaner Upright...
I have the hoover automatic dual vac 5. this is the 3rd hoover rug cleaner i purchased and always the same problem the spray underneth the rotator bars hardly dispenses and the floor hardly gets wet, this...
The carpet is not intended to get soaked, like what you see with a spray application. If you are seeing a stream of water in the nozzle/tank during the recovery stroke, this is working properly.
Jan 17, 2010 | Hoover Steam Vac Dual V w/ SpinScrub...
Will not spray
The heater is probally clogged. Remove the upper housing and locate a rectagular shaped object in the middle of machine. Remove six bottom screws and clean with stiff brush, clear all lines then run 3 tanks of hot water trhought he system to clear it.
Apr 10, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Vacuums Logo
26 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
