Question about Tower Dryers
I have a Hawaiian breeze tower fan model FZ10-10N. There are 5 wires connected to the switches under the top. One of the wires brown isn't attached to the box. Is it possible for me to reconnect it?
worldvet
  • 859 Answers
SOURCE: Trying to replace 3 speed ceiling fan switch
The black goes to the L connection the others are a guess. You can do this two ways. Connect the colored wires in any sequence and then see what switch sequence give you high and lowest, the other one will be medium. Once you determine that, mark the wires with a piece of masking tape as high, medium and low. Otherwise you connect them, turn power on and use a multimeter to see which color gives you the highest voltage and which gives you lowest. Since you aren't comfortable using live wires and a meter, go with the first option and use the process of elimination to find the wires giving you the speeds you need to find the highest and lowest. Next, you need to determine how your switch sequence works. First pull has to give you highest speed. so you may end up wiring them in reverse if your first attempt is backwards. There is a reason the first pull needs to be highest, it powers up the motor so you can then chose a lower setting. A low setting first will over tax your motor and wear it out eventually as it has to work harder at first.
Let me know if you need further clarification and perhaps this is all you need to get fixed.
Regards,
Worldvet
ps I checked on the Internet of a wiring diagram and I bet you did tok all to no avail.
Posted on May 27, 2008
SOURCE: hunter cieling fan switch replacement
My switch broke, so I'm in the process of replacing it.
Before taking it apart, I made note of the wire colors:
L=Black
1=Grey
2=Brown
3=Lt Blue
Posted on Nov 29, 2008
walesarumi
  • 6993 Answers
SOURCE: Installed new ceiling fan with
the spark was as a result to a bridge. Positive and negative wire has touched each other, that's why the circuit breaker tripped off.
Before you turn the circuit breaker back on, make sure you disassemble the fan, to avoid another spark.
Check the area that sparked, it must have turned to black, or has a burnt odor. Make sure that wires and metal in the box and fan are distinct/separated from each other. After that, switch it on again.
Good luck.
Posted on Oct 30, 2010
  • 6771 Answers
SOURCE: My Hawaiian breeze floor fan just stopped working
One of the most common problems is the switch, bad ac cord, an open winding in the fan motor. The on/off switch and ac cord should be checked first, now! if the motor is humming but not working it is seized, the bearing is burnt, or scorched, and possibly cracked.
Posted on Mar 21, 2011
  • 436 Answers
SOURCE: how to assemble the hawaiian
I cannot find exact instructions but I did find a general guide to assembly. they are usually very easy to assemble.
A standing fan is a portable fan that has a set of three oscillating blades on a long neck. The neck, also called the pole or the leg, is mounted on the floor. Standing fans have evolved from their origins as noisy accessories that blew away papers in their vicinity to silent fans whose direction can be controlled remotely. When placed at a convenient location, a standing fan can distribute air evenly to the entire room. Its speed can be controlled, and many standing fans can be programmed to stop at a set time.
  1. Installation Requirements
    • The only requirement for installing a standing fan is making sure it is near a power source. The entire unit can be assembled manually with only a screwdriver. A single standing fan, either an oscillating or pedestal fan, is very simple to assemble for basic home use.
    Pole and Base
    • The first step is to lay the parts on a floor. Then assemble the pole on the base of the stand. This is very simple, because the grooves for the screws are already drilled, so the screws just need to be inserted and screwed in. Screwing the pole into the base of the fan is required on some models; on others, the pole and the base are molded together and no screws are needed.
    Motor and Fan Installation
    • One some fans, you have to install the motor and oscillating arm to the pole. This again is done by screwing screws into predrilled holes. Grooves for long screws are at the top end of the pole, where they attach to the motor of the fan. Once the motor is placed on the top of the pole, insert the screws in the predrilled holes and tighten the screws. The next step is to wire the three blades. This is done by taking the wires from the motor and joining them to the sockets in the pole. This finishes the assembly procedure.
      To turn the fan on, ensure that the wires fit securely together. A loose connection cannot not only hamper the performance of the fan, it can also lead to problems such as electrical shocks or burning wires.
I hope this helps
good luck
Please rate FIXYA
Posted on Apr 07, 2011
Where can I find replacement mister nozzles for a Hawaiian Breeze misting fan
They are not available Debbie. What is wrong with the ones in yours? If they are clogged you can clean them with CLR or white vinegar. Or set up a patio misting nozzle in front of it.
Patio misting nozzles are readily available. Your fan is discontinued.
http://www.bing.com/search?q=+Hawaiian+Breeze+misting+fan+nozzles&qs=n&form=QBRE&pq=hawaiian+breeze+misting+fan&sc=0-27&sp=-1&sk=&cvid=EBB007E7ED6D49A6BD8E6A22CCCC31E0
Jul 09, 2016 | Dryers
How do I connect the purple,brown,grey and black wires to a harbor breeze fan?
Try this; Purple - 3
Brown - 2
Gray - 1
Black - L
If this doesn't work you probably have the wrong switch. Just because they look the same on the outside doesn't mean they're the same on the inside!
Jun 09, 2015 | Dryers
Westinghouse 3speed fan switch 77288
It's the westinghouse switch. Many results on search. I just wasted 2 hours playing switching wires all combos. Others suggested the switch from Lowe's. Harbor breeze #0033905 . Plug wires back in as you listed Black L, Grey 1, Brown 2, Purple 3. Works perfectly for $3.98 plus tax.
Others said you can call Hampton Bay and get the replacement also.
Sep 24, 2013 | Hampton Bay Dryers
My hawaiian breeze 16" fan isn't working properly.
try wedging a paper clip in between to hold the gaurd in place.
Jun 17, 2013 | Cars & Trucks
How do I clean a Hawaiian Breeze tower fan?
All Equipments has a provisions for servicing even for cleaning only.
Jun 18, 2011 | Tower Aloha Breeze Fan
Unplug fan. Lay the fan face down. Remove the four screws holding the stand to the base. Slide the stand all the way off the cord. Look at bottom of fan and find the small half circle indent just to left of center. There is a screw there, remove it. Go to the hand grip at the top of the back and pry out the two white rubber plugs to reveal two more screws, remove them. Back cover can now slide downward. May take a little squeezing at the center of the grille where internal clip is. Remove two screws at top of squirrel cage. Turn squirrel cage and loosen screw at bottom collar on motor shaft. Tilt the top of the squirrel cage outward slightly and slide upward to remove the squirrel cage. You can slip upper metal bracket off and set aside. Motor is held in by two screws, remove them and flip motor out of the way. There are two screws below where motor sat that hold in base of front grille, remove. Front grille has a series of clips along edges, carefully pry them inward from bottom to top and push grille gently outwards. You can now clean the rear grille, front grille and squirrel cage in warm soapy water and allow to dry. While they are drying, use a vacuum and dust rags to clean interior. When parts are dry, reinstall front grille and reinstall 2 screws. Reinstall motor with two screws. Turn motor shaft so flat notch is pointing up. Recommend to spray a tiny bit of WD-40 or a tiny dab of moly grease on shaft at top of squirrel cage, then replace upper bearing bracket on top shaft. Slide collar end of squirrel cage onto motor shaft and align screw with shaft flat and tighten. Reinstall two screws at bracket at top of squirrel cage. Align back cover just a bit toward bottom, then slide upward and clips will snap into place. Reinstall two screws in hand hold area, then reinstall screw at bottom of cover at half circle notch. You'll need either a magnetic tip screwdriver or a pair of long needle-nosed pliers to get screw in hole before tightening. Feed cord back through base and reinstall 4 screws. It took me about half an hour to do this whole process on each of my two Hawaiian Breeze fans, but they now look brand new and run very quiet.
Aug 05, 2010 | Tower Aloha Breeze Fan
Ceiling fan wires
is the old fixture still installed?
Oct 16, 2008 | Hampton Bay 24002 Ceiling Fan
Aloha breeze tower fan model fz25-50d (84001)
How to take apart the MODEL FZ25-50D[84001] INSTRUCTIONS ARE NEEDED
PLEASE EMAIL BACK WITH INSTRUCTIONS
TO val_bella49@yahoo.ca
Jul 14, 2008 | Tower Aloha Breeze Fan
Tower fan 07586 parts (screws)
I have an Aloahbreeze Tower Fan. The remote control does not work,I put new batteries in and it still does not work. I am disabled and need the remote. It was a gift, as I have no income, so I cannot buy a new Tower Fa. Thank you, Sheila Pike Model No. 84001(FZ25-)
May 29, 2008 | Tower Aloha Breeze Fan
Dryers Logo
56 people viewed this question
Top Tower Dryers Experts
Henry  Thomas
Henry Thomas
Jay Finke
Jay Finke
Are you a Tower Dryer Expert? Answer questions, earn points and help others
