Question about Tablets & eReaders
My tablet keeps turning off even when charged it will use up battery and stay on for about two min .it is almost like shorting out I checked my settings but I can't figure
4 Suggested Answers
  • 992 Answers
SOURCE: why won't the battery stay charged
Maybe the battery didnt work out of the box. I am not familiar with this tablet. Check the documentation on how to turn it off and also to see how many apps are running. The more you have, the shorter the batteryclife
Posted on Jun 06, 2014
  • 5631 Answers
SOURCE: My android nextbook tablet keeps powering off itself even tho thw battery says full charge
Try a factory reset
Nextbook Android Tablet Hard Reset
or
Nextbook Factory Reset Reboot
Posted on May 22, 2015
  • 10137 Answers
SOURCE: Is it possible for a tablet's battery to be affected by a faulty breaker in a home if plugged into the direct route of the damaged circuit?
Make sure the charger is providing the correct voltage and current. Batteries that are older and have a lot of charging cycles on them do wear out, so that's a possibility.
Posted on Feb 14, 2016
Testimonial: "Thanks,but that isn't or doesn't appear to be the problem. Although I wish it were that simple."
My galieo will not keep a charge
The battery may be unable to charge/recharge.
Feb 03, 2018 | Tablets & eReaders
My tablet won't even charge or turn on
it's a factory thing, all You need to do, is open your tab, remove the battery cable for about 10 mins and plug it back again, unplug the screen from the motherboard, and charge it for about, two hours, then plug back the screen connector, and turn it on, if you see it works, turn off the tablet again, and plug in the power cord again, you'll see the charging animation starts, leave it charging for the time you think it's necessary to reach 100%, unplug the cable and turn it on, your tablet is alive, the only problem I've found about this, is that you'll need to turn the tablet completely off whenever you want to charge it, and finally this, VERY IMPORTANT! When your tablet is below 15 or 10% battery, charge it, because if you let the battery die, probably you'll have to do all the steps again.
You need more help give me a call at 1800-204-4427...
Sep 13, 2017 | Tablets & eReaders
Why does it keep turning off unless attached to power, even if it is fully charged?
The fully charged battery may be in need of replacement. It is unable to stay charged.
Sep 15, 2015 | Samsung Galaxy Tab 3 Tablet 10.1" TFT 1280...
My tablet wont turn on unless connected to a power supply and when its connected the screen stays black
I'd check the tablets internal battery and also the cord and plug from the charger. Though the cord powers it enough to run the connection may be too insufficient to -keep- the battery charging. I would also turn the device completely off while troubleshooting.
Jun 27, 2015 | Tablets & eReaders
My Tablet keeps shutting down, uses Battery quickly, won;t even find wireless, when it stays on long enough.
You neglected to provide the age of the tablet. If it's a couple years or older your battery might be on the way out. They don't last forever and some of them aren't of the best quality to begin with. Charge it all night long. In the morning when you turn it on if it still doesn't work right be sure to check the battery level with the A/C adapter unplugged. The level indicators are based on the voltage. If the voltage doesn't come up to spec, it might show less than 100% charge even when charged overnight.
The wi-fi problem could be battery related, too, as wi-fi is a radio transceiver that sends as well as receives signals. Wi-fi doesn't work so well if the transmitter produces a weak or intermittent signal.
Mar 08, 2015 | Ematic 7" Touch Screen Tablet
What's wrong with my device? It powered off even with batterly life left and won't turn back on even when plugged into the charger.
can you pull the battery out for awhile (30 mins to an hour) the put the battery back in and charge the device without turning it on until it is fully charged.
Oct 01, 2014 | Tablets & eReaders
Battery charing very slow, can't open tablet - won't turn on when button is pushed
The battery on the Asus does take a very long time to charge (over 12 hours before you use it the first time, then 8 hours or more each time). It takes even longer if you charge it from the USB port in a computer rather than connect it to its dedicated charger, or if you use it while it's charging. If you've already charged it for 8-12 hours, try turning it on by pressing the power button *and holding it down* for a couple of seconds before releasing it. Then, when using the tablet, try keeping it hooked up to the charger when possible, or at least recharge it overnight.
You can check on battery charge by tapping "Settings" at the bottom of the Home screen, then tap "Battery" in the Device category. The % charge will be at the top of the screen. I enjoy my Asus tablet, and it's good for several hours at a time between charges, but you do have to keep it charged up. Good luck!
Dec 18, 2013 | ASUS Transformer Book T100
Will not turn on
If tablet keeps burning out charges it is due to the fact that an internal short in the tablet is making the charging unit exceed its parameters and allowing it to burn itself out. The issue is with the tablet, not the chargers.
Mar 13, 2017 | Ainol 10" Novo 10 Hero 16GB Dual Core IPS...
Tablets & eReaders Logo
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
