Question about Shurflo Plumbing
My shurflo water pump was accidentally left running when the water tank was empty. It is making a noise but no water is being pumped through. Have I ruined the pump?
    Habit-Forming:
  • 154 Answers
Yep
Posted on May 15, 2017
Need to know the location of the shurflo water pump in my 2007 starwood lx 5th wheel trailer
hard question
cant find an internal design layout on that RV
will have wiring and plumbing pipes connected to it
check under removable seats on the sink side
side inspection panel if there is one
older pumps needed to be primed and sometimes lower than the water tank
or close where the water tanks are
Sep 26, 2016 | Cars & Trucks
Bought a new shurflo pump for our motorhome it is sucking in air and does not stop running
fix the air leak or fill the water tank under the motor home
once you have no air in the plumbing , it will stop running unless there is a faulty pressure switch as well
Jul 27, 2016 | Shurflo Plumbing
Trouble shooting shurflo water pump problem
Try bleeding all the air out of the system or the new pump might be faulty.
Jul 09, 2016 | Shurflo 2088-554-144 Delivery Pump -...
Water not pumping from the tank
If the pump is primed, water will come out of the tank when the pump is running. It make take a little time for the tank to fill, but you should hear the pump making some noise. An un-primed pump just makes a motor noise, not very loud.
Aug 12, 2015 | Plumbing
Krups XP6010 won't pump water after running dry
The pump should not refuse to pump just because it was momentarily run dry. We do not have that model here in NZ so I'm not familiar with it. Is there a way to apply some air pressure (lungs) to the top of the tank and operate it, or maybe you can find some plastic tubing (2 feet of garden hose maybe) that fits the tank socket, full the hose with water and pressurise the top of the hose while operating the pump. If that doesn't work you are doomed to have to open it up and look inside.
Mar 08, 2014 | Krups XP Coffee Makers & Espresso Machines
Extreme pro blaster 5901-2112 pump.will not pull water 6ft. Drained and ran rv anti freeze thru the past 2 winters and pump performed well last three seasons. Placing finger over intake side with pump...
I can't find your particular model pump but, in the picture shown, if thats yours, it looks like two pumps in one. Anyway, I'm pretty familiar with Shurflo pumps and they are diaphram pumps and, the antifreeze may have taken out the diaphams. I'd like to see a bigger picture of it.
http://www.shurflo.com/files/Education-Center/Product%20Data%20Sheets/Fresh%20Water%20Pumps/pds-Extreme%20SS%205.7%2012v%205901-0201%2011.pdf
The pump head should look something like this. I'd replace the diaphram assy.
Jun 15, 2011 | Shurflo Extreme Series High Flow Strainer...
We have just installed a new shurflo pump in our trailer. The pump is working but we cannot get it to stop and there seems to be air in the line. We have tried leaving the taps open but does not seem to...
Hello;
Water water everywhere.... The pump you installed has no way of knowing when to stop. Shurflo also has a pump with a pressure switch that senses pressure drop to turn on and back pressure to stop. I'm sure the dealer that sold you the one you now have will have the proper modell for your application.. Good luck and be sure to put a filter in the line coming from the fresh water tank. You should be all set with this recommendation._Ned_
Apr 16, 2011 | Shurflo Plumbing
I have a Snyder Industries sprayer for and ATV with a Shurflo Diaphram Pump 1.4gpm, 12V 7A 60 PSI. Seems to run ok, when first spraying it flows well then turns to a trickle or drip....I have disconnedted...
There is a filter screen on the pickup tube in the tank (or there should be) if there is a lot of debris in the tank it will slowly start to plug up the screen and reduce the liquid intake for the pump. If that is not the case then take the spray nasals off and clear the debris from them. Hope this helps you.
Apr 14, 2011 | Shurflo OnDemand Diaphragm Pump 28 GPM 12...
Motor on reverse osmosis runs constantly
If this is a booster pump, many booster pumps like Shurflo have an adjustment at the top (allen screw) to back off on the pump pressure, turn to left to back off on pressure. If it never shuts off this can be an indication of a bad membrane, capillary tube, flow restrictor or automatic shutoff, causing all the water to run to drain. If you have low quantities of water, but pump always runs, this could part of the problem. Also high TDS (total dissolved solids) will cause the pump to work more. The higher the TDS 500+ppm the harder it is to produce quality water. With high TDS it's almost like taking muddy water, running it through filters and getting drinkable water. So the RO and pump have to work much harder to produce any quantity and quality of water.
RJ
May 01, 2010 | Culligan Under Sink Water Filter
Plumbing Logo
60 people viewed this question
Top Shurflo Plumbing Experts
Gil Shultz
Robert Larose
Bill Boyd
Are you a Shurflo Plumbing Expert? Answer questions, earn points and help others
