Question about Radio Communications
Way won't my aath200hbc power on and how do I pair it with my blue studio G plus
I have a BlueAnt model # BTSVBC3 I have a new I-phone 6 plus how do I sync the new phone to my BlueAnt? Thank you.
The standard procedure is of course to go into setting, turn on your bluetooth services and wait to locate all bluetooth enabled products to show and if prompted for a password you enter 0000. On the BlueAnt you turn on and hold the button down until you get a flashing blue light, often blue/red combo but flashing to go into pairing mode.
If you've tried all of this already and it's not connecting, you might want to refer to this article to reset the BlueAnt...
BlueAnt Wireless Supertooth 3 Why Won my BlueAnt Pair
Jan 03, 2015 | Apple iPhone 6
I have a Motorola t305 speaker for car it won't let me pair it i put in pass code oooo it says it is right code but make sure device is ready and it is solid blue just like it says but still won't pai
I have found that you need to turn off the Bluetooth and the phone or what you are trying to pair with before you pair this will give it a plane start and it should pair
Feb 13, 2013 | Cell Phones
MY VOYAGER PRO .. LIGHT FLASHES BLUE RED BLUE RED ... CAN'T TURN OFF, CAN'T RESET, CAN'T RE PARE
If you manually turn the headset off, make sure that it is by itself, no other phones in the area, no WiFi hotspots. Once this is done make sure that there is not a bluetooth already installed on the phone itself, if there is, delete it. Make sure that the headset has a full charge. Try the pairing again. If this still won't work, you can try Plantronics Tech service line 800-544-4660.
Here are two links that may be helpful:
Plantronics Voyager Plus User's Guide
Plantronics Voyager Plus Pairing Instructions
Good luck from Headsets Direct!
Jun 04, 2011 | Plantronics Voyager PRO Bluetooth Headset
I lost my pinacle studio 11 plus serial key pls i need assistant
Hey there,
Contact Pinnacle Systems and explain to them that you need a new product key. They'll likely charge you for the product key, but won't charge you the full cost of Pinnacle Studio Plus.
You can reach Pinnacle via Live Chat: http://na2.salesforce.com/secur/login_portal.jsp?orgId=00D400000007GIT&portalId=060400000000a8u
May 03, 2011 | Pinnacle Studio Plus Version 11
Hi I have a samsung AATH200HBC bluetooth headset that was a gift and I've had it on charge for 24 hrs. Blue light is working but dont seem to be able to get any connection with it. Trying to pair it with...
this works with the Samsung range quite well also but you must get the sequence correct - phone blue tooth active BEFORE you turn on the headset then press and hold the on button until the blue light stays solid blue.
Jan 15, 2011 | Eforcity Samsung Bluetooth Headset WEP200...
Problem opening Pinnacle Studio Plus 9 Project
Updates and/or patches may need to be reinstalled for Pinnacle Studio Plus 9. Check here: Downloads
Feb 28, 2017 | Pinnacle Studio Plus 9 for PC
Missing photos
One solution is that the pictures Have been moved or their directory re-named while Studio was closed.
Nov 09, 2009 | Pinnacle Studio Plus 12 for PC
Blue led problem in alesis mk1 active
I dont think its anything to worry about, if the unit didnt turn on at all or the LED flickered then you would need a capacitor or 2 changing; check here; http://www.neufeld.newton.ks.us/electronics/?p=232
Apr 18, 2009 | Alesis M1-Active-MK2 Powered Studio...
Radio Communications Logo
29 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
