Question about Cell Phones
Bluetooth won't turn on - Cell Phones
Lost pairing of iPhone 5 to Panasonic kW tg7841. iPhone will not pair.
I recommend turning the Panasonic back to pairing mode. It probably came with instructions on how to do it.
Jan 28, 2015 | Apple iPhone 5
While using Bluetooth I hit forget this device. I need to use the device now but it won't recognize it. How do I reset the Bluetooth?
Easy; Go to settings and tell the device to scan for devices. Obviously make sure the device you want to use is turned on first and all going well, your phone will tell you your ready to use that pareticular bluetooth device. Good Luck. George
Mar 30, 2013 | Apple iPhone 3G
When I turn my iPhone Bluetooth on it won't find the Craig blue tooth speaker!
Any Bluetooth device MUST be discoverable for the phone to find it.
Does your Craig have any setup program / configuration where you can set it to be 'discoverable' ?
Feb 17, 2013 | Cell Phones
My iPad won't find my Bluetooth speaker
Go to settings, General, blue tooth and remove any "other" previous paired BT devices & Turn off BT, then go to Sett. General, scroll down to reset and reset network settings, this will not delete anything. Power off BT speaker. after iPad re-boots turn on BT Speaker First, make sure BT is off on iPad as well as WIFI-wait like 10-15 seconds and then turn BT on in iPad it should see your speaker now and let you pair it up.
Jan 14, 2013 | Harman Kardon JBL Flip black
Bluetooth inspiron 1420
check the bluetooth driver is installed
Dec 04, 2011 | Dell Computers & Internet
My 220 won't turn on. Red light stays on when charging but when unplugged won't do anything
The link below on page 7 has the sequence for turning on your headset (Explorer 230 and 220 work the same). If you're still having problems, then it needs to replaced.
Plantronics Explorer 230 User's Guide
Good luck from Headsets Direct!
Oct 04, 2011 | Plantronics Explorer 220 Bluetooth Headset...
My plantronics 220 won't turn off. The blue light won't turn off and I can't get it on or off.
Try letting the battery go completely dead on the headset and then recharge it. This should fix the problem.
Here is the link for the Plantronics 220 User's Guide.
May 09, 2011 | Plantronics Explorer 220 Bluetooth Headset...
Bluetooth not charging
The internal battery is bad or your charger is faulty, got a kink in the cord.
Jan 22, 2008 | Motorola Mobility H700 Wireless Headset
Cell Phones Logo
24 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
