Question about Refrigerators
Palm Springs ice machine YT--E 005B manual
Not pumping water up to make ice and the low water beeps
5 Suggested Answers
  • 828 Answers
Check the condenser if it is restricted in any way it will decrease ice production. Check for water overflow from the sump. Any more water than necessary entering the sump will also cause a decrease in ice production.
Posted on Sep 05, 2008
  • 3 Answers
SOURCE: waterpump of Ice Machine KM-500MAH-E
Always attempt to have Hoshizaki pumps rebuilt when possible. The parts are cheap compared to buying a new pump. Check ebay from time to time I have just started tearing units down and selling the used parts, that are still functional. Sold that pump for $75 last week
Posted on Nov 17, 2008
  • 3 Answers
SOURCE: I have a palm springs ice cube maker, it normally
get a new 1. its easier and cheaper than buying new parts and getting it fixed.
Posted on Dec 14, 2009
SOURCE: user manual for Palm Springs
I will advice you check to search for the manual of your device as requested.
Take care.
Posted on Aug 25, 2010
Hosizaki ice machne 3 beeps then after i reset it it runs for 7 seconds and shuts off?
the 3 beeps means that the freeze cycle is longer than 60 minutes. This could be because: float switch stuck, water valve leaking water into the sump, low on freon. If not one of those, it is a more technical issue that would require a service tech. Reset button is a small white button on the control board. Press it while the power is on to reset it.
May 21, 2014 | Hoshizaki Freezer Commercial Ice Machines...
Palm springs icemaker no ice
replace the inline water filter,if no filter it is clogged in the water inletfeed to ice maker,run a piece of wire or coat hanger threw it ,to break theclog up.
Dec 24, 2012 | Refrigerators
3 beep alarm, machine is clean, has new float ***. but still locks out after dumping ice
Did you clean the float switch water tube going into the water trough when the switch was replaced?
Does it make 1 drop of ice,then shut off immediately?
What is the age of the machine?
3 beeps every 3 sec. = Freeze Back Up Timer. Freeze > Specified Setting
Yellow LED marked "F Timer" energizes. Check for F/S stuck
closed (up), WV leaking by, HGV leaking by, PM not pumping, TXV
not feeding properly, low charge, or inefficient comp. Dip switches 9
& 10 allow for factory adjustment of this back up timer feature.
Aug 10, 2011 | Hoshizaki KM-1300S Stackable Crescent...
I have model 630 mwf water cooled keeps beeping twice i reset clean machine water well clean float will cycle a few times and then beep again what should i do next
Hi, I have worked on these machines many times, air and water cooled. Do you have a code chart on a panel to tell you what the 2 beeps are on the control board? Do you have the original troubleshooting manual? This would be of a lot of help. This KM900 is a good size ice machine. I would pick up a gallon of nickle safe ice machine cleaner at a refrigeration parts house, read the instructions and run the machine through the cleaning cycle again. Hand clean everything you can get to again, this is the biggest problem I find on water cooled units. The nickel safe is an excellent cleaner made for this problem. Do you have a water softener for the inlet water on this machine? If not I would recommend having one installed. This will cut down on a lot of problems you will have in the future. Try this and get back to me and let me know. In the mean time I will research this ice machine to see what I can come up with.
Feb 16, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Beeping 3 times every 3 seconds
The 3 beeps indicates that the unit was in the freeze cycle for 60 minutes. Causes: 1.) Water valve leaking, allowing water to continually enter the system. 2.) Float switch stuck, sending false signal to board. This indicates ice not being produced. 3,.) Low freon level causing long freeze cycle. 4.) Hot gas valve leaking thru causing warmer than normal evap plates=low production. 5.) Expansion Valve not feeding freon properly to evap plates.
Items 1 and 2 are the most common. Number 3 possible due to freon leak in the system. Number 4 and 5 are usually a very rare occurance.
Hope this helps ya.
Sep 05, 2009 | Hoshizaki Freezer Commercial Ice Machines...
I have a palm springs ice cube maker, it normally bleeps when it needs water or it is full of ice but now whenever I put it on before it makes any ice it continually bleeps and it is not making any ice I...
Sorry - no solution.
I have the same problem also with an error code HHCC on screen
Nothing in manual, suspect maybe a regas?
Cant find anything on internet, may try ringing a supplier and finding out the makers info!
May 10, 2009 | Kitchen Appliances - Others
Sep 04, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki ice machine repair?
seems that its low on water or float switch is bad. try to clean float
Sep 02, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Beeping Ice Machine
I have a Hoshizaki KM-250BAF that is making 3 beeps then pauses and them makes 3 beeps again. If I unplug the ice maker and plug it in it continues to make the 3 beeps. The manual does not mention anything about beeps. Can anyone help?
Jul 09, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
