Question about Bowflex Exercise & Fitness
How do I calibrate my bowflex tc5500? - Bowflex Exercise & Fitness
4 Suggested Answers
  • 49 Answers
SOURCE: My bowflex tc5000 will not calibrate
Check the speed sensor and make sure it is no farther than a credit card away from the drive pully. Unplug unit Located...remove left and right rear covers and back cover. 3 screws in each and 4 screws in back. Follow 2 black wires up to drive belt pulley under back of left treadle. slide sensor in with cc between it and the pully. Recalibrate
Posted on Aug 31, 2009
ercupa190
  • 12223 Answers
SOURCE: bowflex TC5500 fuse for motor board. When staring
You can order the part:www.fitnessrepairparts.com
or www.gymparts.com
www.treadmillpartszone.com
You must locate to side from the power switch you must find the fuse holder and replace the fuse with THE SAME SIZE+CAPACITY+VOLTAGE INDICATED FROM THE SAME FUSE.
Remember if the fuse is Blown again or continuing you have a short circuite in a) Transformer b) Main Motor c) Main Controller Board d) Faulty ground in your receptacel from the wall very carefully.
11_28_2011_7_10_12_pm.gifattached the block diagram that I did for to illustrate to person like you, good luck. sincerely.
Posted on Nov 28, 2011
ercupa190
  • 12223 Answers
SOURCE: I have a Bowflex TC5500 When I tried to use today, I got a error message on display that says: ERROR Belt Shutdown error code: NIPP COMM Error
LUBE THE DECK BELT, INMEDIATELY THIS HAPPEN BECAUSE THE LACK OF MAINTENANCE, ACCORDING THE SCHEDULE MAINTENANCE, READ YOUR OWNER MANUAL OR DOWNLOAD FROM WWW.ICONSERVICE.COM
GOD BLESS YOU
Posted on Oct 02, 2012
How to correct Tread climber TC5500 error code NIPP COMM (Belt Shut Down).
If you wiah to get some details about treadmill error codes and solutions then check the following link
http://electro-medical.blogspot.com/
Oct 02, 2016 | Bowflex TreadClimber TC5500
TC5500 sometimes shuts down after a few minutes. Error is 9,0,9. Takes 1 hour to come back on. why does this happen?
Hi Craig, this sounds like a motor temerature cut-out gets activated due to high internal heating, do you smell hot motor at all? These cut-outs are temp driven- opening at a set temp, and then reclose after cooling via the Circuit-Breaker theory of heated bi-metals ;o)
You can also contact jatinah electronics for further help if needed.
Good Luck!
Jan 16, 2015 | Bowflex TreadClimber TC5500
Lights up but when pressing Quick Start it automatically shows the lady liberty,etc for a moment then goes back to the Bowflex logo and nothing else. Help!
I was having the same issue to a T. I called Bowflex tech support, they told me that without a doubt the main pc board that is under the treads needed to be replaced for $515. I then trouble shot myself and got it up and running in minutes for $0. Take of the plastic top from the pc board area, unplug the little clipped in 2 wire plug labelled Fan. It litterally says fan on the board and you can see 2 wires going right to the fan. Once that is disconnected try to Quick Start. It should work. You can either replace the little fan for $6 @ radio shack or run a fan your self simply by facing your own in the same area. Most people are running a fan for themselves anyway, just aim for both. Good luck.
Mar 06, 2014 | Bowflex TreadClimber TC5500
When I go into a user profile, it freezes up and I have to turn the machine off and back on to use. I have use the quick start to use it. how can I fix this?
Try to re-calibrate unit. Also there may be settings already in unit. Clear all settings and reset to factory settings.
Dec 31, 2013 | Bowflex TreadClimber TC5500
I have a tc5500 with a shutdown code 080
Resetting the button with Stop +Speed by 10 sec.
However you must LUBE the deck belt AND rollers bearings. This happen because the lack of maintenance schedule, You must do it every 150miles aprox.
See the video
Jan 21, 2013 | Bowflex Treadclimber
Lost add user on welcome page
you must try to call them, for to fix this problem , is more easy.
God bless you
Dec 11, 2012 | Bowflex TreadClimber TC5500
GOD BLESS YOU
Sep 21, 2012 | Bowflex Treadclimber Walking Belt Tc5500
Calibrate bowflex tc5500
That model does not have a calibration option. You may want to download the operation manual from the manufacturer at bowflexcatalog.com, there is a product manual link at the bottom of the page.
Jan 07, 2012 | Exercise & Fitness
Bowflex TC5500 fuse for motor board. When staring the machine for work out, the motor kicks off then reboots. How do we order and replace a fuse?
or www.gymparts.com
Oct 03, 2011 | Bowflex Treadclimber
Dec 07, 2008 | Bowflex Treadclimber TC5300
Exercise & Fitness Logo
35 people viewed this question
Top Bowflex Exercise & Fitness Experts
Electro Med Services...
Shehu Pro
Shehu Pro
Are you a Bowflex Exercise and Fitnes Expert? Answer questions, earn points and help others
