What does error message s09 for scanncut canvas
No Blue Screen Canvas in FCP-Enjoy HD video editing in FCP with AVCHD to ProRes...
No More BlueScreen Unrendered Message in Canvas Window in Final Cut Pro <br />AVCHD to ProRes No Blue Screen Message-Edit ProRes files in FCP without rendering <br /><br />Do you ever face the error <b>Blue Screen Message in Canvas Window</b> saying that the file is unrendered, even if you have already use Aunsoft Final Mate for Mac to convert the AVCHD footage to MOV or Apple ProRes 422? Some of the customers have reported about the issue of files need to be rendered in FCP when they bring the output MOV files to the timeline. <br /><br />Actually, it could be done by making the sequence settings in Final Cut Pro the same as that of the MOV file. Then you could import the MOV files from <b><a href="">AVCHD to ProRes conversion</a></b> by Final Mate for Mac, and edit HD videos in FCP without rendering. <br /> <br />The guide below will show you the simple steps for converting AVCHD to Apple ProRes 422 for Final Cut Pro 6 or 7, so that there is <b><a href="">No more Blue Screen Unrendered Message</a></b>. <br /><br />Step 1. Import AVCHD files to Aunsoft Final Mate for Mac. <br />With Final Mate for Mac, you can import files with camcorder connected to iMac/MacBook, or AVCHD folder from hard drive. You will get pop-up message for camcorder wizard if camcorder is connected. Follow the wizard to import files. Alternatively, go to the Resource tab, and click the Add file path button to browse the AVCHD folder with .mts or .m2ts clips. <br /><br />Step 2. Select files for <b>AVCHD to Apple ProRes conversion</b>. <br />Select the files from the Camcorder tab or Resource tab, drag and drop to the Movies tab, and you will face the message asking you to create one movie, or one movie for each clip. Choose "Create A Single Movie", if you want to join and merge the files. Choose "Create A Movie for Each File", if you would like to keep the number of files. <br /><br />Step 3. Choose Apple ProRes 422 format with 1920x1080 for FCP. <br />Click the Export button, and go to the third button for editing software. Choose Final Cut Pro &gt; Apple ProRes 422 as the output format. Choose 1920x1080 from the drop-down list of the output video size. <br /><br />You can also change the output folder for the ProRes files if you like. Then click the OK button to start <b>MTS/M2TS to ProRes 422 conversion</b>. <br /><br />When the conversion is done, just click the Browse for Export Path button on the Conversion window, and you will find the <b><a href="">ProRes files for FCP editing without rendering</a></b>. Run FCP 6 or 7, and choose File &gt; Import &gt; Files to browse the .mov files exported by Aunsoft Final Mate for Mac. <br /><br /><b>To get rid of the unrendered message, you can use the following method</b>: <br /><br />1. When you import the file to timeline, FCP shall automatically pop up a message like below asking you to change the sequence settings to match the clip settings or not. Click Yes, and there will be <b><a href="">No BlueScreen Unrendered Message in Canvas Window</a></b>. <br /> <br />2. If you do not get the pop-up message, you can change the sequence settings manually. Just right click on the sequence ID, and choose Settings, you will face the Sequence Settings window. Change the settings to that you choose in the output window of Final Mate for Mac. <br /> <br />For example, click the drop-down box for Aspect Ration and choose HDTV 1080i, choose Square for Pixel Aspect Ration, and choose Apple ProRes 422 Codec. Click OK to save, and import the .mov file to timeline. <br /><br />You can easily Enjoy the HD video editing in FCP 6/7 with the AVCHD to Apple ProRes 422 conversion from Final Mate for Mac.
on Jul 07, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
I want to replace canvas on jayco camper
take the camper to a jayco service center and get the correct replacement items for that camper
then it is a matter of removing all the fitting strips to allow removal of the old canvas and the fitment of the new items
a clue her is to when the new canvas id fitted is to leave the camper opened up and to wet the new canvas with silicon fluid and allow it to dry put before folding it away
why , it stops water coming through the canvas when touched in the rain and prevents mould if folded away when wet
Jun 14, 2016 | Jayco 2008 Baja 10Y
Need to get directions for putting together a extra wide canvas closet
Manual for extra wide canvas closet - Fixya
Feb 24, 2014 - manual for extra wide canvas closet - Real Simple 60 Wide Canvas Closet question.
Sep 27, 2015 | Cars & Trucks
What are the benefits of linen canvas?
Linen canvas is one of the strongest types of canvases on the market. Liner canvas will hold together over time much longer in comparison to other types of canvas.
Feb 03, 2013 | Crafts & Hobbies
I have an Epson R1800 and when I load Roll 13X19 matte media and try to print I either get a "jammed media" message or the printer trys to print without feeding the media.
I had a similar problem trying to print epson pro canvas. I finally learned the "trick". First I generally cut an appropriately sized pice of canvas from the roll. Then I attach a HEADER. This is dome by cutting a piece of 13" wide photo paper in a three inch length (so you have a piece 13" x 3") . Draw a line at 1.5 inches and place some sort of adhesive (I use a double sided tape gun) on one side of the line. Line up the canvas/paper with the line and make sure it sticks to the header.
Now you should be able to manually feed the header/paper into the printer - once the header passes the correcct point the printer will "grab" it a position it correctly for printing.
Hope this helps
Oct 26, 2009 | Epson Stylus Photo R1800 InkJet Printer
Stops printing half way through a canvas
The service manual says
"0001001B Head driver (TG) temperature error"
Head failure or head cable splicing defective/breaking of wire
 Head cable joint
 Head Assy exchange
You might try pausing the printer for 10 minutes, before it gets to the halfway point to let it cool down, then un-pause it.
You don't say how large the canvas is. If it is 44" by 60" or something large, above might be OK, if it is only 24" x16", it might be more trouble than it is worth, unless you are only printing a few.
Mar 24, 2009 | Epson Stylus Pro 10000 InkJet Printer
Computers & Internet Logo
154 people viewed this question
David Payne
David Payne
