Question about Konica Minolta Office Equipment & Supplies
Konica minolta 206 call c3452 - Konica Minolta Office Equipment & Supplies
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 79 Answers
FIXING HEAT UP ERROR
RESET BY OFF AND ON BY HOLDING UTILITY BUTTON OR RESET BUTTON
Posted on Aug 13, 2017
SOURCE: konica minolta bizhub 350
• The Fusing Roller Sub Thermistor does not
detect the required temperature within 30 sec.
after a warm-up cycle has begun; therefore, the
copier does not complete the warm-up cycle.
• The temperature of the Fusing Rollers does not
reach the required level even after the set period
of time has elapsed during a warm-up cycle.
Check that the H1[ fuser lamp] comes on when the Main Power
Switch is set to ON, and correct or replace as necessary.
Check that the H2 comes on when the Main Power
Check the installation of the TH1 and the TH2, and
correct or clean as necessary.
Check the operation of the TH1.
Remove CN80 (4P), and then check that the resistance
across CN80-2 and -3 on the Thermistor is
infinity.
5
Check the operation of the TH2.
Remove CN81 (4P), and then check that the resistance
across CN81-2 and -3 on the Thermistor is
infinity.
6
Check the continuity of the H1.
Correct or replace as necessary.
7
Check the continuity of the H2.
8 Change PU1 - -
9 Change PWB-A
Posted on Nov 19, 2007
osiriscompu
  • 16 Answers
SOURCE: konica minolta 2430
Most likely you received this message after a toner was replaced. Reseat the cartridge and restart the printer. If that doesn't work remove all of the toner cartridges manually and reinstall.
Turn off the printer and open the top cover. Follow the toner cartridge all the way to the right side of the printer (on the white part). You should see a hole that looks like a cross. Take a pen or key and push down on the black button in that hole. While you are holding it down rotate the toner cartridge towards you. You want to get the colored roller on the cartridge about 1/2in away from the metal bar that says "consumable reorder". You should be in a position to take out the toner. Let go of the hole and remove the cartridge. Repeat the steps until all of the cartridges have been removed.
Turn the printer back on at this point. You are going to get toner not installed messages on the printer. Open the top cover and the cyan tray will be in place. Shake the toner and install. Close the cover and let it cycle to the next color (black). Repeat the process until all cartridges are installed.
If you are still getting the error you either have a bad cartridge or the carousel that the toners sit in is damaged.
Posted on Jul 19, 2008
  • 3 Answers
SOURCE: konica minolta 1350w status display comes on at start up
Open c:\windows\system32
find a file called MSTMON_Q.EXE
right click and rename the file to anything with a file extension .exe, I named it MSTMON.EXE
Create a shortcut to this new file in case you need it in the future and put the shortcut on your desktop
also, write the original name of the file down or put it on notepad, in case you want to change it back.
restart windows
Posted on Apr 16, 2009
firecontrol7
  • 6680 Answers
SOURCE: what does code 2454 mean on the konica minolta
Developing motor for the Black, working in conjunction with Toner Control Sensor.
Posted on Jul 31, 2009
xeerie
  • 347 Answers
SOURCE: desbloqueo del codigo m2 en konica minolta bizhub 163
Este código significa que la vida las partes de su desarrollo + unidad de imagen se ha caducado. Ahora es el momento de reemplazar las partes.
Posted on Jun 19, 2010
Error code C-C134 - konica minolta C6501 Pro - Konica Minolta Office Equipment & Supplies
Has the IPB been replaced? It may be the wrong one.
A03U H020* is for 6500/5500
A03U H0200* is for 6501/5501
Mar 15, 2018 | Konica Minolta Office Equipment & Supplies
No drum replace & developed replace how to sole konica minolta bizhub 206 error code m2 reset
did you clear the counters for the drum and developer FIRST if not get a new drum and new developer as both are replaced at the same time. As the machine uses the counters to determine a a new unit and adjust certain voltages to certain units accordingly. Other wise machine thinks it is old when it is new and causes image issues and codes
Apr 23, 2017 | Konica Minolta Office Equipment & Supplies
Konica minolta bizhub 206 maintainance service m2 how to set this problem
Did you clear the counters for the drum and developer FIRST if not get a new drum and new developer as both are replaced at the same time. As the machine uses the counters to determine a a new unit and adjust certain voltages to certain units accordingly. Other wise machine thinks it is old when it is new and causes image issues and codes
How to resolve bizhub215 error c3452
FIRST, if this code comes back. Have a technician look at it DO NOT CONTINUE TO RESET the code!!!! AS this is for the Hot Part called the FUSER. It can catch on fire! And that will ruin a perfectly good day!!!!
Reset: "Turn on the power with the clear/stop button depressed"
Mar 30, 2017 | Konica Minolta bizhub Office Equipment &...
129 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
