I think the fuse in my PRO TECH 150 amp mig welder has blown,I wish to find out where it is located in the machine
Can you advise if the machine has a fuse thanks Darryl
luxur4
  • 92 Answers
SOURCE: need wiring schematic for miller 140 wire feed welder
No problem,email, write or phone for this information, Miller personel are very obliging as are most Welding manufacturers.
Posted on Jan 23, 2009
  • 4 Answers
SOURCE: WILL THE LINCOLN SP125 MIG WELDER WELD ALUMINUM AND STAINLESS?
The mig welder should be capable of welding aluminum not stainless but the makers should be able to give you more detail. mig is used for steel and aluminum normaly but I do not know this transformer
Posted on Apr 08, 2009
  • 19 Answers
SOURCE: Clarke MIG welder parts??
what model is your clarke? i have a 125en which is the exact same welder as a craftsman, you could probably get a new feed motor or other parts for the welder itself from sears, the gun is a tweco style gun same as lincolns, so if you need tips or anything you can get those just about anywhere welder stuff is sold. i hope i helped.
Posted on Apr 22, 2009
SOURCE: Century mig welder. The wire speed is spinning at
My Century 225 mig has lost its power ...with adjustments to max it leaves a high weld deposit and low penertration.
What is the fix ?
Posted on Nov 05, 2009
SOURCE: lincoln mig welder 180, 230 volt 20 Amp Input.
Inspector is correct! In wall or conduit wiring awg will always be greater than "open air" wiring. IE: the size of wire coming from your pole ... it's smaller than from your service riser into your meter. Code allows the cord to heat up... open air will cool it down.
Posted on Dec 13, 2009
What make & model mig gun is fitted to this machine
Mig Guns & Mig Gun Spares - The Welders Warehouse
www.thewelderswarehouse.com/Welding/Mig-Welder-Gun.html
We have Mig Guns and spares to suit a wide range of Mig Welders. ... Torches are usually Euro Fitting and are typically fitted to professional mig welding machines of ... attitudes from people one is giving money to ! its great to get good service.
[PDF]POWER MIG ®(140, 180 MODELS) - Lincoln Electric
www.lincolnelectric.com/assets/...public/.../im890.pdf
Lincoln Electricshipment must be made by the purchaser against the transportation company at the time the shipment is received. SAFETY DEPENDS ON YOU. Lincoln arc welding and cutting equipment is designed and built with ... properly fitted and with proper grade of filter plate .... Semiautomatic DC Constant Voltage (Wire) Welder.
Millermatic® 211 MIG Welder - MillerWelds
Dec 20, 2015 | Welding Tools
What causes the 4 amp slo burning fuse to blow on a hobart beta mig 200
You are exceeding 4 amps? I have to believe this is a fuse for the control wiring and not the weld current or primary circuit. Likely you have a blown circuit board in the control area.
Sep 03, 2014 | Welding Tools
Amperage required to run a 180 amp welder
If you mean the plug rating, you can run a 180amp mig welder on a 13amp plug, however above about 150 amps the fuse in the plug will blow, you then need to up grade to a 16 amp plug and wall socket, with the wall wiring going back to a fuse box with a 20amp fuse.
Jun 16, 2011 | Miller 041969 Secondary Contactor Kit
Wire feed speed was surging & now the motor just clicks & turns about 1 degree on the rollers. I suspect it may be the relay for the drive motors. Any help with this problem is...
To test your theory you'd need to check the voltage going to wirefeed motor with a multimeter set to DC voltage. This is dangerous as you'd need to have the covers off the machine. If the motor was getting voltage the whole time you pressed the trigger the fault would lie in your wire feed motor gear box. If it is a small mig welder, i would think from the sounds of your fault that it is the gear box that you're having trouble with. To find a replacement you'd need to write down the model number of the mig welder and order a replacement part through a repair shop.
Jun 07, 2011 | Pro Line Welding Tools
My welder only welds for about 2 seconds then trips house breaker. i have a good dedicated 20amp breaker for the welder. what could cause this? the welder breaker in back of machine does not trip.
Is enough for this machine, but probably is not a fuse dedicate it just for this end side.
If you can turn all lights off and other items that might be in use with the fuse. If you can't then upgrade the fuse to a 30amp.
Jan 10, 2011 | Miller MilWeld MLL907263 /AutoArc XLT142...
Why does my mig welder keep popping the fuse?
House fuse??. If that's problem... then you need a dedicated line to your machine with a 20 amp minimun fuse, or upgrade the current one to 30amp.
Dec 21, 2010 | Welding Tools
Lincoln 135 PRO MIG Welder feed stops after a few minutes
1/4" plate with a 135 amp machine is probably beyond it's duty cycle abilites. If you are using a mixed gas, and pushing the max on the settings, it will be cutting out because it is designed to.
You might want to get a higher amperage welder for consistent welding of 1/4"
The 140 Pro maxes out at 5/16" using inner shield wire. and 1/8", or 10 guage with gas.
Mar 19, 2010 | Welding Tools
SIP turbo 150 mig welder instructions wanted
for welding cars or similar thickness steel use it on number1 setting speed 6-7 and practise max and min should be used when you want a bit more power A gose onto number 2 and then 3 these are amp settings and are for thickness of steel to be weled your welder can weld up to 8mm of plate steel on setting 3 max i use 0.9mm gasless flux cored wire great for working out doors the wind tends to blow gas away on standard wire yours is easly converted to gasless as so was mine
Nov 02, 2009 | Welding Tools
Welder wheel motor not working ,no power
I would look for a blown fuse....
On or in the main box of the welder.
Jun 06, 2009 | Welding Tools
Wire does not feed on MIG welder
my lincoln mig welder did the same exact thing!! I thought what you did, drive motor bad. But it wasn't, on mine there is a reset/breaker button, it's like a 25 amp fuse that can be reset, it was bad! so I took the 2 wires that went in and out of it and jumped them together (not advised) to see if it would work then. BINGO!! now I have to find replacement. Look inside for a fuse or some thing like that.
hope this helps, oh yeah, when I ask the mechanic at the welding store he said that drive motors rarely go bad!!
Hawk
Apr 10, 2009 | Welding Tools
Washing Machines Logo
Top Washing Machines Experts
