Question about Cameras
What is the 4 digit code for screen cast? - Cameras
Chevy engine block identification numbers V0710FSC TEJ528846
Small Block Chevy Engine Block casting and code identification
www.nastyz28.com/sbchevy/sblock.html
Sep 14, 2012 - Small Block Chevy engine identification. Code identification, Casting Number info.
Chevy Casting Number identification - Block casting numbers
outintheshop.com/faq/casting/castings2.html Chevy Casting Number identification including Block casting numbers, cylinder ... 2-bolt Chevy II Nova Recessed filter .... 2 & 4-Bolt Mexico cast Crate engine.
Reference: Chevy Engine Block Casting Numbers - Chevy ********
www.chevyhardcore.com/news/reference-chevy-engine-block-casting-numbers/ Sep 19, 2013 - The engine block casting number for both BBC and SBC engines is found at the back of the block where the transmission mounts to the engine.
Chevy Identification Numbers - 73-87.com
www.73-87.com/chevy_ids/sbcid2.htm If you have a small block Chevy engine, and need to identify any parts you have laying around, or maybe the engine that is in your truck, I think you will find the ...
Chevrolet - Browse - Casting Numbers .info: engine blocks, heads ...
www.castingnumbers.info/site/browse/m/chevrolet 12562932, Category: Cylinder Heads Type: Big Block V8 Date: 1991-1995. Notes: oval port, open chamber, Gen.V, truck crate motor, 118cc chambers gm chevy ...
http://outintheshop.com/faq/casting/castings2.html
Jul 04, 2017 | Cars & Trucks
I have a GM 350 I can't identify. Casting number is 14093638. Date code is J284. Engine ID is v1117pjf. Engine VIN is CSE131557.Both head casting and date codes are 10110810 L094.
Casting # 14093638
87-95 350 Car & Truck 2 & 4-bolt Passenger stick 1-piece seal
Oct 25, 2016 | GMC Cars & Trucks
Thanks for the help I just noticed my typo my casting numbers are 3858180 my apologies the engine is a 1965 327 I just cant seem to find what kind of car it was put in if anyone has any suggestions on were...
"You need to get the suffix code off the front pass side, on pad in front of the head. It will be a code thats 6, 7 or 8 digits long. The 1st one will be a letter, next 4 will ne bumbers and last 1, 2, or 3 will be letters.. Like say V0621KH. V0621 if the prefix which tells plant, mo. and day, KH would be the suffix code which tells engine size, HP, induction system, and car it was used in Your 3858180 is not a vin #, it's the casting number and no it does not decode as a corvette. The casting # does not tell what car it was installed in. Its just the size and year range. That # is added before the engine was ever thought of being built and installed. 3858180....327...1964-67...2 bolt main thats all the casting number decodes as."
Aug 06, 2014 | Cars & Trucks
LOCATION ON ENGINE NUMBER OF KIA SPORTAGE 2005 MODEL
Find the engine identification tag. Attached at the factory, this tag is normally found on the engine block around the coil bolts. The top line of the tag identifies engine size and model year.
Search the block for the engine block casting number. The numbers are raised, not stamped into the block and consist of seven numeric digits. The digits can be located on either side of the block. The seven-digit number may be followed with a dash and further numbers. These are change codes and are not normally necessary to identify the engine.
EX.:
Locate the casting date is located on the block. It is in standard date coding, 2.25.93, for example and may be located on either side of the block, but is commonly located on the driver's side of the block, above the freeze plugs. The example 2.25.93 decodes as February 25, 1993. The casting date may be near the casting clock, which designates the hour the block was cast. Magnum engines were manufactured from 1993 to 2002, so verifying the date code helps identify the engine.
Jan 15, 2011 | 2005 Kia Sportage
S1 IS faulty autofocus and purple cast Pictures have a purple cast , this is also visible in the display screen and viewfinder. At the same time the focus (manual or auto) does not appear to be working,...
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check this link for more info.
Applicable cameras include: A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 30/30a/200a/300a/D320/400/ 450/500
Dec 21, 2009 | Canon PowerShot S1 IS Digital Camera
Fault in view and image.
As the price to fix my camera was over 2/3rds the price i paid for the unit i am using it as a paper weight. Dave.
Sep 04, 2008 | Canon PowerShot G7 Digital Camera
LCD display
Hello!
You can get your LCD repaired for $84.95 from this website.
I wish you luck in resolving your cracked LCD screen!
Jun 20, 2008 | Canon PowerShot A720 IS Digital Camera
Pinkish screen and green blurred picture
Sounds like the image sensor is malfunctioning (common symptoms: distorted images with purple or green cast, completely dark images, flickering lines across the screen.)
Oct 26, 2007 | Kodak EasyShare C643 Digital Camera
Pictures have colour cast
Sorry if this sounds obvious, but this might rather have to do with White Balance. Rather than relying on AutoWhiteBalance, try setting it to "cloudy" or "shade", this may help the blue cast.
Jan 29, 2007 | Canon Digital Rebel / EOS-300D Digital...
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
