Question about Bosch Ovens
When I try to select the correct temperature on my Bosch Oven it wont let me.
The temp jumps all over the place. when I turn the dial it goes from 150 to 155 to 160 to 450 to 455 to 310 to 305 to 100.... any ideas on this? I have tried killing the power to the oven for 1 minute but it doesn't help.
    Dedicated:
    Visited the website for 20 consecutive days.
  • Bosch Expert
  • 84 Answers
Good Morning! Do you have the model number of your appliance?
Posted on May 19, 2017
Bosch oven will not turn off
New oven? What about the supplier warranty? Bosch is a top make, get hold of a dealer.
Nov 14, 2014 | Ovens
I have a Jenn Air JJW9830DDP double oven electric, and the temperature in the oven is about 100' less than what it reads on the display. I tested the temp sensor and it ready 1073 ohms. Any s
Well, your temp sensors can still be bad. If not, there's always a new control board you buy!
However, I wouldn't drink water from that oasis without making ABSOLUTELY sure I'm not seeing a mirage.
The only common denominators between your upper and lower oven temp readings is the firmware and the oven thermometer you are using to visually check the temps.
What type of thermometer are you using to check your oven temperatures with?
If it's not a digital thermometer used specifically for testing ovens, you might just be leading leading yourself astray.
You need a calibrated thermometer. If I don't have a calibrated digital thermometer on me, I use two or three oven thermometers (the dial type) and average the readings.
It's the only way to be as close as possible with a digital probe.
If you have thoroughly verified that your oven is in fact not reading the correct temperature, then you can adjust it +/- 35 degrees F via your oven's control panel.
To adjust the oven temperature:
1 - Press Setup pad.
2 - Select the down arrow to scroll to the next screen.
3 - Select Temp Adjust using the Quickset pads.
4 - Select upper or lower oven (select models).
-"Set temperature offset using the Upper Set Knob" is displayed.
5 - Enter the desired temperature change using the Set knob.
The temperature can be increased or decreased up to 35 degrees.
The temp. change is displayed at the top of the window.
6 - Press the Set knob to accept the change.
Now, if you are still worried about the temp. reading being off, replace both the upper and lower temp sensors. That's all you can do besides replace the main board.
Oct 24, 2014 | Jenn-Air JJW9830D Electric Double Oven
Thermostat broken?
If your oven has a dial that is used to set the temperature instead of a digital control then yes, the thermostat has gone bad and is not shutting the heat off at the appropriate time.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 17, 2012 | Smeg S20XMF.1 Stainless Steel Electric...
Bosch gas oven heating slowly - takes about 1 hour to reach 150 - 200 degrees. When trays placed in oven, temperature decreases cooking very slowly
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
May 19, 2011 | Bosch HBL 5032 Electric Single Oven
Main Oven Overheating
Try putting thermoter in oven take off main dial you well see a small screw ajust slowly and check every 30min.tell temp is correct.and put dial back on
Jul 26, 2010 | Bosch HBN 9163 GB / 9163 GB hot-air Double...
My bosch double fan oven has cut out and has blown the fuse
there is a little control board that might be defective on .
Feb 24, 2010 | Ovens
Oven not achieving correct temperature, 50 degrees too low
Thermostat is not working properly and needs replacement.
Apr 14, 2017 | Ovens
OVEN TURNS ON BUT WONT HEAT UP.
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Aug 25, 2008 | Whirlpool RBD305PD Electric Double Oven
Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Jul 08, 2008 | Ovens
    Ovens Logo
    50 people viewed this question
    Top Bosch Ovens Experts
    Oloyede Monsuru
    michael_t919
    Are you a Bosch Oven Expert? Answer questions, earn points and help others
