I need to set the time on the hand piece so the ans machine stops flashing
Please can u show me how to change the time on this watch.
Set the time on your Baby G by switching to time mode. The button on the bottom left-hand side of the watch is the mode button. Pressing it once to will set the watch to time mode. The time digits will begin to flash.
  • 2Start by adjusting the seconds. Press the button on the top-right side of the watch once. The second digits will start to flash. Press the bottom right-hand button until the correct second time is displayed. Hold down the button to cycle through the digits. Once the correct time is displayed, press the bottom left-hand button and the digits will stop flashing. Press the bottom left-hand button again to set the hours.
  • Sponsored Links
  • 3Follow the same procedure to change the hours setting. Set the time and date by cycling through the digits in the following sequence: seconds, hours, minutes, year, month and date.
  • 4Press the bottom right-hand button to set the seconds to 00. When the second display is between 1 and 29, the digits will change to 00. If the display is between 30 and 59 seconds, the seconds will revert to 00 and one minute will be added to the minutes display.
  • 5Change from an a.m. to a p.m. setting by pressing the button in the middle of the bottom of the watch when any of the time display digits are flashing.
  • Nov 03, 2012 | Watches
    The bobbin casing stopped working. On closer inspection we discovered the time piece hal become unscrewed, but how to you get it back in time?
    This is how I do it. Rotate the machine by hand until the needle is at the lowest point that it travels. Now tighten the bobbin casing set screws with the thread hook slightly ahead of the needle. As the needle begins to rise the hook should pass by it and grab the needle thread and loop it around the bobbin. Be patient. You may have to adjust it several time before you get the timing back to perfect.
    Good Luck!!
    Chris
    glfi.com
    Jan 20, 2011 | Brother LS-2125 Mechanical Sewing Machine
    How do I set clock?
    In your left hand hold the beverage of your choice, with your right hand, push in and hold the time (disp) button (which is black in color) until the time display starts flashing. While the time is flashing, start pushing the #5 lighted button ( it has a small 'H' on it for 'hour') until the hour time is set. Then start pushing the #6 lighted button ( it has a small 'M' on it for 'minute' ) until you set the correct minute time. If you wait too long after the time starts flashing and you have not started pushing the 'H' or 'M' buttons, the time will stop flashing and you will need to get it flashing again to procede. You may now consume the beverage while leaning back, feeling superior once again for having leaped ahead of the ever burgeoning technology, nodding your head up and down and saying out loud, " Yep, this stud (or babe) is still a genius !"
    Sep 27, 2010 | Alpine CDM-7834
    My power was off 2 days. My GE phone shows
    the time needs to be set on your answering machine. If you buttons on your base press and hold the day/check button to set the day of the week.
    Most likely you don't have the base buttons on your model so on the hand set press the flash button to enter the answerer remote mode. Press the 8 key to enter time set menu. Set hour an dmin using num buttons. Set am/pm using caller id buttons. Press #pause to confirm the setting. Set day of week -/+ and #pause to set them.
    Jan 31, 2010 | Uniden Cordless Phone
    Need instructions for my sr927w accurist watch
    QUICKSTART - SET THE TIME
    1. Push the bottom right hand button until the mode hand indicator points to TME.
    2. Press and hold the upper left button for three
    seconds. The hour and minute hand will retract to the 12
    O’clock position.
    3. Select the time zone on the digital display by pressing the
    upper right button or the lower left button.
    4. Pull the bottom right button out one click. The bottom part of
    the digital display will start flashing. Press the
    bottom left button to adjust for daylight saving time.
    5. Press the upper right button. You will see the seconds
    flashing on the lower half of the digital display. Press the lower
    left button to reset the seconds to 00.
    6. Press the upper right button. You will see the minutes
    flashing. Press the lower left button to set the minutes to your
    current time.
    7. Press the upper right button. You will see the hours flashing.
    Press the lower left button to set the hours to your current time.
    8. Press the upper right button. You will see 12H or 24H
    flashing. Press the lower left button to switch between 12 hour
    and 24 hour.
    9. Push the lower right button back in.
    SET THE CALENDAR
    indicator points to CAL.
    2. Press and hold the upper left button for three seconds. The
    hour and minute hand will retract to the 12 O’clock position.
    4. Pull the bottom right button out one click. You will see the
    month flashing on the digital display. Press the lower left button
    to change the month.
    5. Press the upper right button and the date will begin flashing.
    Press the lower left button to change the date.
    6. Press the upper right button. You will see the year flashing.
    Press the lower left button to change the year.
    7. Push the lower right button back in.
    SET THE ALARMS
    indicator points to AL1, AL2 or AL3.
    4. Pull the lower right button out one click. You will see ON or
    OF flashing on the digital display. Press the lower left button to
    turn the alarm on or off.
    5. Press the upper right button. You will see the hours flashing.
    Press the lower left button to change the hour.
    flashing. Press the lower left button to change the minutes.
    SET THE TIMEZONE
    1. Setting the time zones allows you to add or remove cities on
    the digital display or switch between daylight saving and
    standard time. Begin by pressing the lower right button to move
    the mode hand indicator to SET mode on the bottom dial.
    2. If the hour or minute hands are obscuring the digital display,
    press and hold the upper left button for three seconds. This will
    cause the hour and minute hand to retract to the 12 O’clock
    position.
    3. Now pull the lower right button out one click. You will see the
    digital display flashing. Press the upper left button to select
    SET to display the city or OFF to not display the city. Press the
    lower left button to turn summer time on or off. Summer time is
    indicated on the lower part of the digital display. Daylight
    savings time must be manually set for each city.
    4. Pressing the upper right button will allow you to scroll
    through all the cities. After setting, push the lower right button
    back in.
    USING THE TIMER
    1. Press the lower right button to move the mode hand
    indicator to TMR mode on the mode dial.
    position.
    3. Pull the lower right button out one click. You will see the
    minutes flashing in the digital display. Change the minutes by
    pressing the lower left button. Once you have set the minutes
    on the timer, push the lower right button back in.
    4. Pressing the upper right button starts and stops the timer.
    5. Press the lower left button when the timer is stopped to reset
    the timer to its initial preset time.
    USING THE CHRONOGRAPH
    1. To use the chronograph press the lower right button to move
    the mode indicator hand to CHR mode on the mode dial.
    3 .To start or stop the chronograph press the upper right
    button. If you press the lower left button it will display the split
    time for 10 seconds.
    4. When the chronograph is stopped press the lower left button
    to reset back to zero.
    SET THE TIME ZONE
    the mode indicator hand to SET mode on the bottom dial.
    savings time must be manually set for each city..
    through all the cities. After setting, Push the lower right button
    back in one click.
    Hope this helps. =)
    Oct 10, 2009 | Bulova Watch
    I need instruction manual for servis m6723w
    if theres 4 buttons on facia they are from left to right pre wash extra rinse spin cancel and start depending on which button is flashing you may have a problem if the dial is at 12 oclock and the start button is flashing set the dial to any program and the light should stop flashing if it does not you will need a new board for it and it will need resetting with a servis hand set as servis are now no longer you may have a problem... hope this helps
    Jun 26, 2009 | Washing Machines
    Need to fix time on Casio G-Shock
    The hands are set independent from the digital display
    Setting CASIO G-Shock Watch
    1) Home City
    2) Setting the digital time
    3) Adjusting hands
    4) Alarm set/on/off
    5) Snooze
    6) Hourly Chime
    A -- B
    ( ) Button reference
    C __ D
    1) Select home city first (if equiped):
    Press C until regular timekeeping mode is reached. Hold A until seconds flash. Press C to get to city code. Use B and D to move city east or west to your home city. Press A to set and exit.
    Press C until timekeeping mode is reached (high beep).
    2) Set time, Date, etc:
    Hold A until seconds flash. Press C until item to adjust is flashing. Press B or D to adjust. Press C to go to next item. Press B or D to adjust. Press A to exit.
    3) Adjust hands (if equiped):
    Press C until H-Set is reached. Hold A until time flashes. Press D to advance minute hand. Press B while holding D to set faster and continuously. Press D to stop hands before correct analog time is reached. Press D to step to current time (hands only go forward). Press A to exit H-Set mode. Press C to return to timekeeping mode.
    In Timekeeping mode B is illumination and D is time/day/date display advance.
    4) Alarm set/on/off
    Press C until alarm mode is reached (AL1 - AL4 + SNZ and SIG). Press D to select alarm to adjust. Hold A until alarm time flashes. Press B or D to adjust alarm time. Press C to toggle between hour and minutes set. Press A to exit. Press A to turn alarm on and off. Repeat for AL2 - AL4. Press C to return to Timekeeping mode.
    To stop any alarm, press any button.
    5) Snooze (SNZ):
    Press C until alarm mode is reached (AL1 - AL4 + SNZ and SIG). Press D to select snooze alarm (SNZ). Hold A until snooze alarm time flashes. Press B or D to adjust snooze alarm time. Press C to toggle between hour and minutes set. Press A to exit. Press A to turn snooze alarm on and off. Press C to return to Timekeeping mode.
    To cancel the next snooze: Press C until the timekeeping screen is reached or go to the Snooze alarm (SNZ) screen.
    6) Hourly Chime (SIG):
    Press D to select hourly chime (SIG). Press A to toggle chime on and off.
    Good luck,
    Techjoel
    Apr 18, 2009 | Casio G-Shock GW300CA-1V Wrist Watch
    Espresso extraction time
    You will need to reprogram the computer. To do this, it is relatively simple. take your grounds and tamp into your portafilter (I usually start with a double). make sure that you tamp it correctly.
    Then, hold down the start/stop button until you see the lights flashing on the panel (if you want to program both groupheads at the same time, then hit the start/stop button on the other side as well.) Then with your portafilter inserted in the grouphead, hit the button that you would like to represent your double shot. you should see a water stream about the width of a cooked piece of spaghetti. After around 18 seconds to 22 seconds, you should have your shot levels filled. then hit the button that represents your 'double' shot to stop it. then hit the start/stop button. You will see the start stop button flash a couple times and then turn off.
    That should do it. remember, that the preferred timeframe for a shot of espresso is 18-22 seconds. Your setting on the coffee grinder would then need to be set to make sure your getting a full shot in that amount of time.
    Good luck
    Dec 09, 2007 | Astra Mega II Espresso Machine
    Program don't start, flashing ligths (start and "delay start" button) for 5 times.
    What does the error code mean do you have any idea Is it mentioned in the Hand book. At any rate logic suggests a watewr supply problem that the first thing a washing machine needs - water. So a tap not turned on a Kinked hose An inlet valve solenoid failure- Three things for you to check
    Jul 31, 2007 | Hoover Nextra HNWL 3136 Front Load Washer...
    Washing Machines Logo
    Top Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
