Question about Splendide 2100 Vented Washer-Dryer
Machine fills with water drains and the knob goes around + around
Fills with water drains immediately without wahing and the control knob goes around and around till you stop the machine
    Novelist:
  • 123 Answers
I had a friend who had a similar problem, She called out an engineer and found that it was blocked, the items over time had filled the trap (A large pipe hanging down under the tub before the pump) which collects items that have been left in pockets etc before they reach the pump to avoid any damage. It was full of allsorts of things including coins which had overflowed and entered the pump casing and stopped the motor from running. The computer always checks that all the motors run before a wash cycle, if it finds a fault, the only way it can tell you apart from doing absolutely nothing (dead) is to keep rotating the dial so that you know that it`s found a fault with one of it`s systems. Hope this is helpful, Ian
Posted on Jul 25, 2009
I have a 6 year old Frigidaire washing machine. It does not fill with water. All water lines have been checked and are okay. Washer goes immediately into the wash cycle without filling with water.
This is symptomatic of a malfunctioning water control valve- the hot water one if the washer is hot and cold fill, and the cold one if it is just cold fill!
Sorry but it needs replacing and a service call to confirm that it is not something else like the control board or connectors ;-0(
Good luck,
John C
Mar 29, 2011 | Washing Machines
Water does not drain automatically wahes and spin
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Mar 04, 2011 | Washing Machines
Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Aug 23, 2010 | Kenmore Washing Machines
My White Westinghouse 833ES never stops filling, it seems like as water goes in, it is draining right out. Any ideas of what to check would be appreciated. Thank you.
you have to have the drain higher than the water level of the wahing machine, plus ther is no stopper for the water so if you have the drain hose connected directly to another hose and there is no air gap at the top it will just siphon out
Aug 11, 2009 | Westinghouse Washing Machines
Kenmore 80 Series Overflow
We've now had this happen three times and the exact same thing caused it all three times.
If the water level selector knob hasn't "clicked" into one of the given load levels on the control panel(i.e. the knob is in between levels) it will continue to fill until you discover water everywhere and turn the knob until it "clicks" into a level.
As far as I know, it has nothing to do with loose hoses or bad switches, it's bad design. There seems to be no safety mechanism to turn off the water if you over- or under-shoot the desired water level.
Apr 29, 2009 | Kenmore 24032\24036 Top Load Washer
Washing machine wont wash or spin, just fills and drains
THE MODEL NUMBER IS USUALLY FOUND SOMEWHERE AROUND THE OPENING OF THE TUB OR ON THE LID ITSELF
Apr 24, 2009 | Washing Machines
Hi, my switch keeps going around and around without stopping
Hi I fixed the problem by removing the filter at the bottom right hand corner of the washing machine and removing 2 x £1 coins that had got stuck there
regards
Michelle
Jan 24, 2009 | Indesit W 123 Front Load Washer
Machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Splendide 2100 Vented Washer-Dryer Logo
166 people viewed this question
Top Splendide Washing Machines Experts
Philip Diggins
Level 1 Expert
Are you a Splendide Washing Machine Expert? Answer questions, earn points and help others
