Cant undo lid to clean pump on my hotpoint washer wfp556p. never tried to before as it is less than one year old and i need to get bra wire out. my son in law has tried too and the lid is completly rigid and wont turn either way, washer is just under a year old.
  • 28 Answers
It can be something blocking the lid. Then you must dismount drainpump housing.
Posted on Jul 27, 2009
Hotpoint washer won't spin or agitate
Jump the lid switch and see if it works, then you'll know it's the lid switch
May 16, 2017 | Washing Machines
Hotpoint washer dryer wdf 740 showing error code F-13
F13 error code is a dryer NTC problem.
What you need to do is take off the top of the washer. From there you will see the dryer chamber on top. Towards the front of this is the NTC it will have 2 thin wires going to it.
Make sure the wires are on ok and not broken. If the wiring is fine then you will need a multimeter and test the NTC. It should give a reading in Kohms.
If the NTC is fine then its possible the control board at the back is the problem.
Oct 15, 2012 | Washing Machines
Hotpoint ultima wd860; My washing keeps coming out smelling musty even though I use conditioner regularly. Is ther a filter I need to clean out. Thanks
you need to clean the draw and the inside of the draw and clean the rubber door seal all way round when you done that use a washer clean detergent whitch should be at a super market. and run it at 90 or 95 temp cottons wash it should stop the smell beacause dirt is buliding up so a good clean should stop it.hope this helps.
Sep 02, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hello-belt has come off hotpoint wf430 1300 washer-cant work out how to get lid off-anyone got a clue?
at the back of the machine at the top near lid there should be screws undo the screws and then slide back the the lid and it should come off. hope this helps.
Apr 21, 2009 | Hotpoint WMA64 Front Load Washer
Something caught between drums
I will try to explain open the door remove the screws that hold the door on lift up on the door it should come off now remove the other two screws on the other side of the door two white clips should come off now grab the top of the front panel and pull it out now you will see insides remove 2 screws that hold the clip that hold the lid down make sure you undo the screws in the dispencer before lifting the lid goood luck
Mar 29, 2009 | Maytag MAH6500 Neptune Front Loading...
I can't undo the filter cap
i had same problem so removed the inlet pipe on the pump at the back of the filter and removed debri from back of filter [screws coins and a darning needle] because of this the design of the lid would not allow it to open.........
Mar 18, 2009 | Bosch Classixx WFL 2066 Front Load Washer
How do you remove underwire lodged between drum and outer case
hi to remove bra wire from between drums ? you might try this 1st ? if you diconnect water supply hoses and unplug power supply then remove rear panel from machine you will have access to the large rubber drain hose from outer drum down to discharge pump ? ok hose is held by spring wire clips both ends remove clips then hose you may find bra wire either in hose or close to drum drain if you need ? feel inside drom via drain hole ? or probe with a piece of coat hang wire ? you may even find the mysterious missing sock/ thong / etc when you disconnect the hose too?? any debri has to lay in bottom of outer drum and so a little patience will locate them using this method instead of removing the main front door sealto drum for access to same area also with rear panel off you can check belt tension ? hope this helps/inspires you ? best wishes from uk
Feb 26, 2009 | Hotpoint First Edition FEW12 Front Load...
Hotpoint wd640 f-05 and f-11 error codes washer does not empty
f05 say pump blocked or pressure switch fault. whereas f11 say pump cannot be activated... so either an open circuit pump or fauty pcb..
Oct 14, 2008 | Hotpoint Aquarius WD640 Front Load...
Indesit wil 103 filter
stale smell may be due to using liquid detergent - change to powder.
filter may be of two types. if in the front, unscrew cap and just pull. may be difficult is a foreign object like a bra wire is stuck inside.
other type of filter is in the large diameter pipe from bottom of machine to pump. take off small back bottom panel and undo this pipe at the machine end and filter is inside this pipe. pull out and clean
Sep 04, 2008 | Indesit W 123 Front Load Washer
Hotpoint WD64 Washer Dryer
Common causes for this are kinked drain hose or clothing, like panties or socks, caught in the pump suction hose. Why, I've even heard of bra wires getting loose and getting stuck in that hose, collecting all sorts of gookus and pinching off the flow of water to the pump. Lay the washer on its side(If possible) and clean out the hose. If it still doesn't work then its time to get a new pump assembly. Good luck!
Jul 15, 2008 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
48 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
